Mandrel Exhaust Systems - Page 8 - TCCoA Forums
 11Likes
post #211 of 697 (permalink) Old 03-19-2009, 10:36 PM
Wicked_Paintball's Avatar
Wicked_Paintball is offline
post #212 of 697 (permalink) Old 03-21-2009, 03:56 PM
Seasoned Geek
Got my exhaust put on today Exact same issues Jason had, but the guy took his own sweet time and instead of using clamps, he welded everything up. He was so impressed by his own work that he took pictures and is going to e-mail them to me. I will post them when I get them. He was so impressed by my car that he wanted to do the best work he possibly could which is why he welded everything together. Some of the prettiest welding I've ever seen. Makes a difference in the performance. Also, he hardly charged me anything to do the work because he enjoyed doing it so much. As I said, will post pictures when I get them.
post #213 of 697 (permalink) Old 03-21-2009, 04:25 PM
Cool deal! whats your impression of the sound? what mufflers did you go with?
Jason Marsh
jasonLmarsh@yahoo.com
(364 rwhp 439 rwtq) on a Mustang Dyno
jasonLmarsh is offline
post #214 of 697 (permalink) Old 03-21-2009, 04:40 PM
Seasoned Geek
Sounds great Jason And no dome noise at all guess its my 3:27 gear that made the difference the mufflers are DynoMax Super Turbos
post #215 of 697 (permalink) Old 03-21-2009, 04:42 PM
I got one too. Am using just the right side pipe for my V6 application. I will just sell the left side to someone who wants to do the same for their V6. 2.5" pipe is plenty for a 3.8L.
Click here for the post
RichardM is offline
post #216 of 697 (permalink) Old 03-21-2009, 05:29 PM
Lucky you. I hope to find an exhaust shop near me that takes that kind of pride in their work. Looking forward to seeing your pictures.
post #217 of 697 (permalink) Old 03-21-2009, 05:41 PM
Seasoned Geek
Yep Ron I believe that the welding would pass your inspection
post #218 of 697 (permalink) Old 03-22-2009, 06:17 AM
Anyone with this system on their car, do you also have a rear torsional load brace? I'm wondering about clearance issues.
Darren, if I buy one I'll come down and have your guy install it!
post #219 of 697 (permalink) Old 03-22-2009, 08:41 AM
Seasoned Geek
Cool Joe
post #220 of 697 (permalink) Old 03-22-2009, 04:55 PM
Just a couple observations with my kit.
The lengths of the pipes after they go around the gas tank could be longer. Once you put the S-bends on that go past the rearend and to get them to clear the IRS bracketry its very tight. An extra couple inches two would be helpful.
Also, the expanded ends are slightly closed at the opening, not sure if this is due to the cutting or the inside die to open it up got inserted too deep. You have to tweek the openings to get the tubing to slide in easy.
good basic kit for the price overall.
rm
RichardM is offline
post #221 of 697 (permalink) Old 03-22-2009, 06:03 PM
Seasoned Geek
FYI Guys
Yep my man had to do some mods as well. They are NOT made to fit perfect.
post #222 of 697 (permalink) Old 03-25-2009, 10:42 AM
MikeyB's Avatar
My backhalf just showed up!
95 Cougar XR-7
Sold it...
96 Thunderbird LX
Sold it...
MikeyB is offline
post #223 of 697 (permalink) Old 03-25-2009, 01:47 PM
Seasoned Geek
Nice to see mike ,But be forewarned that the bends around the gas tank will have to be modified for mine was
on my bird. For some reason they got them wrong
post #224 of 697 (permalink) Old 03-25-2009, 02:11 PM
MikeyB's Avatar
Thanks for the heads up, do you think the problem can be solved just with lengthening in a few areas of the pipe?
95 Cougar XR-7
Sold it...
96 Thunderbird LX
Sold it...
MikeyB is offline
post #225 of 697 (permalink) Old 03-25-2009, 02:14 PM
Mister_T's Avatar
sounds like there's a lot of problems with these setups.
I'm Mister_T and I approve this message.
Mister_T is offline
post #226 of 697 (permalink) Old 03-25-2009, 02:16 PM
Seasoned Geek
Yes sir I believe that is what my installer did. He also had to modify the ends that connect to the mufflers they were not big enough.Good luck to you sir
post #227 of 697 (permalink) Old 03-25-2009, 02:16 PM
Inconsistent problems too. My back 1/2 was fine and fit with no modification, but the right front downtube was wrong and needed work. Seems to be hit or miss...
Jason Marsh
post #228 of 697 (permalink) Old 03-25-2009, 02:18 PM
Seasoned Geek
Yep right Jason . He plugged the 02 holes on the front and made them to angle AWAY from the engine and trans
post #229 of 697 (permalink) Old 03-28-2009, 08:32 PM
Teeps's Avatar
I'm welding my own exhaust from the Headers back (large-tube kooks (3/4 length) headers for the 4v). I'm using SS tubing. I think I'll go with dynomax bullets instead of cats, and I'll go with the magnaflow XL mufflers (three chamber) to help with drone. I'll likely go with 3" tube atleast until the IRS after the gasses cool down a bit. I bought large mandrel bent tubes, and some straight tubing. Using SS welding wire, and tri-mix gas.
This is going to be alot of welding, but I won't have to worry about fitment!
Now I wish I had the aluminum short block machined so I could put together the motor, install it, and start welding up the exhaust!
Somebody with good cad skills could model my setup for a similar mandrel bent configuration (when I get it done later this summer / fall); (especially for those with kooks headers);
1997 Sport - Work in progress:>
MP BB 304 Teksid 4v- w IC'd / Ported M112
Need:
Eaton pulley puller (VMP or BF preferred)
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #230 of 697 (permalink) Old 04-01-2009, 03:45 AM
What was the time range from when you ordered them til they showed up at your home?
post #231 of 697 (permalink) Old 04-01-2009, 10:05 AM
MikeyB's Avatar
^Took like a week for my order to come in.
95 Cougar XR-7
Sold it...
96 Thunderbird LX
Sold it...
MikeyB is offline
post #232 of 697 (permalink) Old 04-01-2009, 01:35 PM
Seasoned Geek
About 2 weeks here I believe
post #233 of 697 (permalink) Old 04-01-2009, 07:31 PM
cause I ordered mine on March 19, which will be 2 weeks tomorrow. . .and I have not gotten any e-mails or anything from these guys.
post #234 of 697 (permalink) Old 04-01-2009, 07:34 PM
Seasoned Geek
It was the same here as well Wicked . Just one BIG box at my door one day .
post #235 of 697 (permalink) Old 04-01-2009, 07:35 PM
Darren,
Any pictures yet?
post #236 of 697 (permalink) Old 04-01-2009, 08:14 PM
Seasoned Geek
Originally Posted by Rodeo Joe View Post
Darren,
Any pictures yet?
Just have a shot of my back half. Will have more soon
post #237 of 697 (permalink) Old 04-02-2009, 06:58 AM
It took about 2 weeks to get mine as well. I wasn't home when they showed up and my wife just drug the box into the garage. I looked at the box sitting there and then walked out the door for another flight. It's been sitting unopened in the garage now for about three weeks.
I expect to have installation problems now for other reasons.
That looks great Darren. I like the way the mufflers are tucked up in under the bumper. I plan on doing mine the same way.
post #238 of 697 (permalink) Old 04-02-2009, 12:04 PM
Seasoned Geek
Thank you very much Ron for the the guy that done my install took pride in his work Yours is going to sound GOOD with the headers
I love the way good headers make a engine sound .
post #239 of 697 (permalink) Old 04-12-2009, 02:23 PM
sik97bird's Avatar
any other pics yet thunderchecken?
97 Ford Thunderbird
Check out my Gallery
vist the Man RobertP at www.robstireandauto.com
sik97bird is offline
post #240 of 697 (permalink) Old 04-12-2009, 02:26 PM
Seasoned Geek
Nope not yet, But will have them this week
