Dynotune results - TCCoA Forums
 1Likes
  • 1 Post By driller
post #1 of 9 (permalink) Old 03-04-2017, 08:53 PM Thread Starter
driller's Avatar
Dynotune results
Thanks to eecdoc and 1mtncat, we had some dynotuning done on the Blue Flame.
Woodman likes this.
driller is offline
post #2 of 9 (permalink) Old 03-04-2017, 10:15 PM
Woodman's Avatar
THat is a great result! Nice broad, flat torque curve!
PI Swapped NPI motor with some port work on the heads, PI cams, 80mm MAF, CAI that feeds from fenderwell. Jmod, 3.73:1 TL in Mark VIII carrier, Mark VIII aluminum LCAs, 93 Mark VIII driveshaft, PBR brakes (soon to be Cobras), 18x9 wheels, 255/40/ZR18 Tires, Front and Rear strut/shock bracing, GR-2 shocks, Eibach 1.5" springs, 1989 SC front and rear sway bars.
Woodman is offline
post #3 of 9 (permalink) Old 03-05-2017, 08:19 AM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Awesome Results!
Great getting with you and Mike yesterday JP. Mike did his magic and the car performed flawlessly.
Too bad the track wasn't available today. Looking forward to the track tweeking and the results afterwards.
You've got a tiger by the tail now.
See you guys a little later in the spring.
Steve
"There's a bad, built 4.6L Coming in 2016"
Current Elite member of the Halfshaft snapping, Auburn eating, Tranny crunching, Piston Melting, Tire lifting Torque Club
Previous Best 11.75 @ 113.76 1.57 60', ZEX Nitrous April 2012 (346 HP, 503 TQ)
Previous Best 12.94 @ 105.25 1.81 60', Naturally Aspirated April 2012 (254 HP, 315 TQ)
"IN MEMORY OF MY FRIEND JOEL BENDER 1979-2006"
"IN MEMORY OF JOHNNY LANGTON 1975-2011- 4.6L NPI NA RECORD HOLDER"
"IN MEMORY OF MICHAEL VIVERETTE 1953-2013 aka-CHRISTINE KENNEBELL Bird"
1MTNCAT is offline
post #4 of 9 (permalink) Old 03-05-2017, 09:15 AM
Congrats JP. Its been a long time coming.
We don't call him EECDOC for nothing!
Looking forward to seeing some track numbers on the new build.
post #5 of 9 (permalink) Old 03-05-2017, 09:21 AM
Rayo's Avatar
8000 RPM!!!
At least, now you know where your hp/tq starts dropping off at..
That being said, at what rpm are you going to be shifting at?
1991 Ford Thunderbird Sport
Rayo is offline
post #6 of 9 (permalink) Old 03-05-2017, 09:27 AM
Rayo, If you notice, it peaks about 6700, and the torque is a bit ahead of that.
That's a beautiful Dyno "Curve"; although it's one of the flattest I've seen.
Straight up to the flow limit, no burbles; just sheer Rock and Roll!
Nice result, JP!
post #7 of 9 (permalink) Old 03-05-2017, 10:20 AM
Originally Posted by Rayo View Post
8000 RPM!!!
I hadn't even noticed that wow! 8K is screaming! What no videos? I'd love to hear what that engine sounds like at 8K.
post #8 of 9 (permalink) Old 03-05-2017, 10:34 AM Thread Starter
driller's Avatar
I've always heard the curve was less important than the area under the curve.
"Curve" is a bit of a misnomer in this application. I suspect the peak torque just under 5K is a result of port length harmonic tuning being just right?
We'll see what the track dictates as far as shift points but there should be adequate room to adjust as needed. I suspect it will probably be around 7500 just to keep the revs up where the next gear engages.
driller is offline
post #9 of 9 (permalink) Old 03-05-2017, 10:57 AM
1MTNCAT's Avatar
They were great pulls for sure. I'd really like to have seen how far in the low 8K range it would have gone without significant drop off. It wasn't losing much power at all remaining somewhat flat to the signoff point only dropping minimal HP.
Can't wait to see track results once he gets the rest of the track equation worked out.
Ron, It sounds wicked at nearly 8K RPM's.!!
Steve
1MTNCAT is offline
