In the middle of installing dss level 5 axles - TCCoA Forums
post #1 of 47 (permalink) Old 12-09-2012, 12:20 AM Thread Starter
Okay guys I've got this and test fitting with the car on the ground the inner tripod about a 1/4 of it hangs out the inner [yolk] yuck, from reading EECDOC ran his the way I have it set up, but I'm not sure I'm comfortable with it a half inch longer shaft would be nice any thoughts guys?
DSS with stock Tripod
DSS Tripod slid out over clip
Stock with inner clip - DSS only has place for outer clip
DSS 33 Spline Outer
This is it installed; you can see how much hangs out this with wheel hanging
Another shot the upper goes in with wheel on ground
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 6.34@109.89
10.11 @ 139.19 best mph
RobertP is offline
post #2 of 47 (permalink) Old 12-09-2012, 11:52 AM
Any pics. I think most of us have never seen the inside of a joint. I'm sure the axles I have are setup the same as Mike did them also and no problems here to 1.52 60'
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------300RWHP est.---------who knows/who cares
10.740@127------------13.842@103.08-------16.1@
BLOWN38 is offline
post #3 of 47 (permalink) Old 12-09-2012, 12:03 PM
Send me the pix Rob and I'll post them for you.
post #4 of 47 (permalink) Old 12-09-2012, 12:50 PM Thread Starter
I'll send pics when I get back.
My thing is I just dunno how far in the tripod needs to be, also I have no way of keeping the tripod locked out as there isn't a place for an inner ring on the Level 5 axles like the OEM stock ones.
Blown38 are u running the Level 5 axles?
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #5 of 47 (permalink) Old 12-09-2012, 02:06 PM
I think mine are cobra inners and axles with the 33 spline outers. I really don't know, Mike would have to chime in.
Or maybe just the inners are cobra.
BLOWN38 is offline
post #6 of 47 (permalink) Old 12-09-2012, 03:19 PM
AED Specialist
EECDOC's Avatar
Chris has the second set of level 5 axles I built for the MN12 IRS rear. They were originally built for the Black Kenne Bell bird. This was back in the 2005-2006 era.
95 T-Bird 4.6 Twin Screw Supercharged
10.0 Best ET and 138 Best MPH
1.44 60' time on Hoosier Drag Slicks
EECDOC is offline
post #7 of 47 (permalink) Old 12-09-2012, 04:25 PM Thread Starter
Pictures are coming
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #8 of 47 (permalink) Old 12-09-2012, 05:06 PM
First post updated with pix.
post #9 of 47 (permalink) Old 12-09-2012, 05:29 PM Thread Starter
Even with wheel on the ground, the 3 rollors are all about even with about a 1/4 hanging out
Robert
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #10 of 47 (permalink) Old 12-09-2012, 05:59 PM
When I pull mine in and out of the car I can feel it moving in and out quite a bit and always afraid it will come apart, but it never has.
BLOWN38 is offline
post #11 of 47 (permalink) Old 12-09-2012, 06:00 PM
Mgino96tbird46's Avatar
Jeez, I'm not so sure how I feel about that. It does look a little sketchy, hanging out like that.
1996 Thunderbird LX. Gone, but not forgotten Oct 1995-March 24 2016
1998 Mustang GT premium. Auto, stock, and slow. Daily beater.
Mgino96tbird46 is offline
post #12 of 47 (permalink) Old 12-09-2012, 06:11 PM Thread Starter
Yea there in no way that's right, we'll if they don't have a longer shaft I can always us a stock axle part, I've got plent and I've got a pair of 01 cobra axles coming and a set of 03 also but there 2 short but extras want hurt for the cobra
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #13 of 47 (permalink) Old 12-09-2012, 10:40 PM
So the Cobra axle you were experimenting with when I was down there isn't gonna work?
post #14 of 47 (permalink) Old 12-10-2012, 07:41 AM Thread Starter
Cobra axles are shorter
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #15 of 47 (permalink) Old 12-10-2012, 08:11 AM
Well dang. That sucks. I suppose, worse some to worse, you could have a custom axle made.
post #16 of 47 (permalink) Old 12-10-2012, 01:32 PM Thread Starter
Dss rocks there gonna make a custom shaft for the tbird
They rock is all I can say
Robert
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #17 of 47 (permalink) Old 12-10-2012, 01:35 PM
Really? Awesome!
I guss you discussed the details with them over the phone?
post #18 of 47 (permalink) Old 12-10-2012, 01:39 PM Thread Starter
And a few pictures and measurements, they had no issue wanting to correct it either, a+++ service
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #19 of 47 (permalink) Old 12-10-2012, 01:39 PM
ehh, I would not feel comfortable running it like that.
post #20 of 47 (permalink) Old 12-10-2012, 02:03 PM Thread Starter
We are not there gonna make a new shaft that is a cobra shaft there
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #21 of 47 (permalink) Old 12-10-2012, 02:21 PM
Sounds like the strongest shafts yet for an MN12. Any guesses as to the next weak point?
post #22 of 47 (permalink) Old 12-10-2012, 02:24 PM Thread Starter
Yea this should be the setup 33 spline outers out of 4340 chromoly with shaft being 300m material and I'm gonna run cobra 31 spline inner with a cobra trac lok, I dunno what the next weak point is as EEC doc has pulled 1.42 60fts I believe
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #23 of 47 (permalink) Old 12-10-2012, 03:43 PM
Well, the level 5 shafts are rated to take 900 rwhp. Kinda hard to to think of what's next. lol
post #24 of 47 (permalink) Old 12-10-2012, 03:49 PM
cool.....I'm all about not running circlips in the diff, but that just scares me.
post #25 of 47 (permalink) Old 12-10-2012, 03:50 PM
As light as your car is, I would think you can get away with running wooden axles to get down the track!
~Rick
TCCoA Sig
post #26 of 47 (permalink) Old 12-10-2012, 03:51 PM
Originally Posted by NetKeym View Post
As light as your car is, I would think you can get away with running wooden axles to get you down the track!
you can do that?
I kid!
post #27 of 47 (permalink) Old 12-10-2012, 06:36 PM
My Wallet.
Delete my account.
94 Thunderbird XX is offline
post #28 of 47 (permalink) Old 12-10-2012, 07:31 PM Thread Starter
We'll I wanna see what this car can really do, I'm in process of doing airbags, dlf knuckle bushings aready have his control arm bushings, I really wish he would make me some front diff mount bushings I think that would really help
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #29 of 47 (permalink) Old 12-10-2012, 09:29 PM
I have aluminum front diff bushings. Should be pretty easy for a machinist to mill out.
BLOWN38 is offline
post #30 of 47 (permalink) Old 12-10-2012, 10:25 PM Thread Starter
Did you buy them or have them made
Robert
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
