Wheels arrived today! - TCCoA Forums
 8Likes
  • 2 Post By jdhughes909
  • 4 Post By jdhughes909
  • 1 Post By jdhughes909
post #1 of 30 (permalink) Old 04-11-2017, 10:39 AM Thread Starter
Niche Turin's, staggered and concave for my Tbird!
Woodman and CDsDontBurn like this.
jdhughes909 is offline
post #2 of 30 (permalink) Old 04-11-2017, 12:00 PM
Woodman's Avatar
They look great!
Woodman is offline
post #3 of 30 (permalink) Old 04-11-2017, 01:01 PM
Good lookin' rims! Now let's see 'em on the car.
post #4 of 30 (permalink) Old 04-11-2017, 01:06 PM Thread Starter
Soon, for sure. I finished the hub swap over the weekend and still have to bleed the brakes. I'll have 'em on this weekend.
post #5 of 30 (permalink) Old 04-11-2017, 08:28 PM
CDsDontBurn's Avatar
Those look great! Can't wait to see them on your car.
CDsDontBurn is offline
post #6 of 30 (permalink) Old 04-16-2017, 10:28 PM Thread Starter
Finally finished it up and off the lift. They look great!
The hub swap and drum to disc swap was fairly easy. Hardest part was finding Cobra IRS hubs for a decent price. The driver rear brake hose doesn't line up perfectly and kept pulling in air when bleeding. Seems to be fine now but doesn't line up perfectly where the brake hose block mounts on the caliper. I didn't see any comments in other folks' write-up's on modifying the brake hose. Anyone had to modify theirs?
post #7 of 30 (permalink) Old 04-17-2017, 05:29 AM
TwoHaggard's Avatar
Wow that's clean!
P.i. intake,70mm tb, cai, Walbro 255 Fuel Pump, Intrax 2in lowering springs, KYB front and back shocks n sturts,
Taylor 8mm Plug Wires, True Dual Exhaust No Cats 2.25in pipe alltheway back Mid mounted dual in / dual out Jones Powerflow muffler then ran out back to 16x3 chrome tips 93Mark8 Driveshaft, 1.25Rear sway bar, 4:10s, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program
TwoHaggard is offline
post #8 of 30 (permalink) Old 04-17-2017, 07:54 AM
Great choice for that color bird.
18x9? What size tires did you put on them? What brand tires?
post #9 of 30 (permalink) Old 04-17-2017, 08:37 AM Thread Starter
Fronts are 19x8.5" +35 offset w/ 225 40 Delinte's
Rears are 19x9.5" +35 offset w/275 35 Delinte's.
No need to roll fenders, 9.5" wide w/+35 offset fits fine.
CDsDontBurn likes this.
post #10 of 30 (permalink) Old 04-17-2017, 11:23 AM
Those do look great! :drool:
post #11 of 30 (permalink) Old 04-17-2017, 12:08 PM
Slightly Disjointed
I needed to bend the rear caliper lines slightly to clear the spindle with the 11.65" Cobra conversion, not sure if that's what you mean though.
Looks great! The SC kit is very unique with that color
post #12 of 30 (permalink) Old 04-17-2017, 12:46 PM Thread Starter
That's what I mean. Thanks, helpful to know that others had to do same. Most of the write-up's didn't reference it, almost made it seem like everything just bolted up perfectly (but we know how that goes ).
post #13 of 30 (permalink) Old 04-17-2017, 06:00 PM
1995 cougar xr7's Avatar
Is that an sc or a v8 with sc ground effects. Is the paint original, I have the same color on my cougar and its faded from Florida sun and looks like crap
1995 cougar xr7 is offline
post #14 of 30 (permalink) Old 04-17-2017, 06:52 PM
Slightly Disjointed
SCs were never offered in that color, so it's gotta be an LX
I never saw the line clearance mentioned either, it was a surprise when I did my conversion last month. I think some upgrade to stainless braided lines while they're at it so the issue never comes up.
post #15 of 30 (permalink) Old 04-17-2017, 07:54 PM
Resident Gun Guru
SHADOW's Avatar
they look awesome ! Are these available in a 17x9 in black with standard thunderbird bolt pattern ?
13.66 @ 100.4 mph
1.94 60' time
"If you stick with the basics, you never have to go back to them"
SHADOW is offline
post #16 of 30 (permalink) Old 04-17-2017, 08:47 PM Thread Starter
I don't think they are available in 17". I found them in bolt pattern 5x108 in 18x8.5" and 19x8.5" sizes but that doesn't allow the deep concave in the rear. To get the concave look you have to go 9.5" or 10.5" wide. It was worth doing the hub swap for the wheels - pretty easy swap and parts are readily available.
post #17 of 30 (permalink) Old 04-18-2017, 07:25 AM
T6Rocket's Avatar
I like the paint color!
Al
97 T-Bird LX 4.6 - 68k miles
Previous cars:
T6Rocket is offline
post #18 of 30 (permalink) Old 04-18-2017, 01:16 PM
ikutoisahobo's Avatar
I have a good idea of what kind of wheels and offset I'm getting now.....
Looks great.
ikutoisahobo is offline
post #19 of 30 (permalink) Old 04-18-2017, 03:35 PM
Looks like LX taillights to me...
scottjohnston is offline
post #20 of 30 (permalink) Old 04-18-2017, 07:52 PM
Wile E. Coyote Jr.'s Avatar
Great choice man, they look great. Mine came in yesterday, just need to get tires on then they are good to go.
If you can't blow them away with your brilliance, baffle them with your nonsense.
Wile E. Coyote Jr. is online now
post #21 of 30 (permalink) Old 04-18-2017, 08:26 PM Thread Starter
Post pics when you have 'em on! I'll look forward to seeing yours.
post #22 of 30 (permalink) Old 04-18-2017, 08:54 PM
Will do, if the tires are here before this weekend you should see them on Monday.
post #23 of 30 (permalink) Old 04-18-2017, 09:43 PM
Resident Gun Guru
SHADOW's Avatar
Whats the cost to do the hub swap ? and whats involved ?
13.66 @ 100.4 mph
1.94 60' time
SHADOW is offline
post #24 of 30 (permalink) Old 04-18-2017, 10:10 PM Thread Starter
Plenty of write-up's and posts on both tccoa and sccoa on the process. I found everything needed through a few quick searches. It looks complicated but it's not. I did mine for ~$750 but I also had drum to disc swap at the same time which added some cost (brake hoses, e-brake lines, calipers/pad, you know). Biggest expense were the rear Cobra hubs - $150 each!
post #25 of 30 (permalink) Old 04-19-2017, 07:11 PM
They are and it is.
post #26 of 30 (permalink) Old 04-20-2017, 08:38 AM
Natesriv's Avatar
Originally Posted by Rodeo Joe View Post
They are and it is.
All the LED's firing in them? I know a way to fix
Natesriv is online now
post #27 of 30 (permalink) Old 04-20-2017, 11:20 AM Thread Starter
They still work. But I'd take your info. on how to fix if you're willing to share!
post #28 of 30 (permalink) Old 04-20-2017, 12:33 PM
S4gunn's Avatar
Q: Where did you find a reasonable price on rear Cobra hubs for your swap?
-g
S4gunn is offline
post #29 of 30 (permalink) Old 04-20-2017, 01:33 PM
Natesriv's Avatar
Rear Reflector LED Renewal How-To
Here you go! It's a good idea to find a spare set of rears if you can get some.
post #30 of 30 (permalink) Old 04-20-2017, 03:14 PM Thread Starter
-g
I think I got 'em from LMR - https://lmr.com/item/M1109A/1999-04-...FQ5Efgodhq4D6Q . I called them to check availability, asked for a discount, and they gave me one and shipped 'em same day.
