19x9.5 on front - TCCoA Forums
post #1 of 3 (permalink) Old 05-01-2017, 06:26 PM Thread Starter
19x9.5 on front
I am looking at some wheels that are 19x9.5 +35mm. I know they will fit nicely in the rear but I was wondering​ if anyone has tried that size on the front? Thanks
Robe is offline
post #2 of 3 (permalink) Old 05-01-2017, 06:53 PM
Woodman's Avatar
They should fit, I run 18x9 all around, +35, and there is about 1/2" clearance with the top of the spindle. The additional 1/2" in diameter up, and 1/2" inward "should" clear the spindle as it angles inward still. Tire clearance may be an issue, depending on what size tires you run.
Woodman is offline
post #3 of 3 (permalink) Old 05-01-2017, 07:07 PM
Slightly Disjointed
I don't think they will fit.
