Wheels 101?? - Page 3 - TCCoA Forums
post #61 of 72 (permalink) Old 05-02-2010, 08:51 AM
What is the tallest tire you can fit on these cars?
I've got 16" sport rims and would like to go taller for more ground clearance. I'll probably need to add an adapter up front to push the rim out a little to clear the spindle. Then do the same out back to make it match the front offset.
Has anyone gone taller than stock? What's the limit?
JasonWW is offline
post #62 of 72 (permalink) Old 05-02-2010, 09:31 AM
Superduty's Avatar
I ran some 235 75 15 in the rear with air shocks. Had to carry big blocks in the trunk thats what the air shocks were for. Now it has 225 60 16 on it finally got a truck.
Superduty is offline
post #63 of 72 (permalink) Old 05-02-2010, 12:12 PM
crash00527's Avatar
Send a message via AIM to crash00527
Not for nothing but that's what the search button is for and on top of that third a million posts on this topic... Especially in this section.... Wheels 101 for dummies. Lol
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #64 of 72 (permalink) Old 05-02-2010, 12:55 PM
If your refering to my question you are incorrect on both counts. I found one thread and it was from 2004. Nobody asks this question because no one wants to raise their car. Everyone wants to lower it or stay stock. It's okay though, I started a new thread. Still, I was expecting at least a mention of height in the Wheels 101 thread, but there's not.
JasonWW is offline
post #65 of 72 (permalink) Old 05-02-2010, 01:09 PM
crash00527's Avatar
My bad, you're right.... BUT. Same rules kinda apply to plus sizing. When I get home I'll look into more for you.
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #66 of 72 (permalink) Old 05-02-2010, 06:22 PM
I'm not talking about bigger rims, I'm talking a taller tire overall. Like a 255/65/16 which is 29" tall.
JasonWW is offline
post #67 of 72 (permalink) Old 06-10-2012, 09:22 PM
Has anyone had any clearance issues with running 20"x 8.5" wheels with a 38mm offset on
245/35R-20's?
Asapientmachine is offline
post #68 of 72 (permalink) Old 08-09-2013, 12:02 AM
Jon Hall's Avatar
How would a wheel (18x8) with a 48mm offset and 6.34 backspacing and 245/45/18 tires fit on a 95 T bird? Would the wheel be too close to the spindle?
With a 18x9 is it the tire or the wheel itself that is closest to the spindle? With a 245/45/18.
Jon Hall is offline
post #69 of 72 (permalink) Old 08-10-2013, 03:20 PM
Slightly Disjointed
48 is waaaaay too much offset. You'll likely be hitting the spindles with an 8" wheel, and if you aren't it will look and handle like crap(you're effectively reducing track width with high offsets), which pretty much defeats any and all purpose of going to 18s doncha think? Somewhere between +30mm and +39mm is what you need.
To answer your second question, the wheel. But both will hit the spindle if we're now talking a 9" wheel with the same +48mm offset
post #70 of 72 (permalink) Old 08-10-2013, 05:08 PM
Jon Hall's Avatar
Awesome. Thanks for the info.
Jon Hall is offline
post #71 of 72 (permalink) Old 03-25-2016, 10:39 AM
You can run a lower offset too
I figured I would share some pictures of my car, the wheels are my buddy's, they're Varrstoen MK3's, offset and everything made for a new Focus. The specs are 18x10 +27 all the way around, I just put them on mine to see what they would look like. The rears still sat a little inside the lip of the fender, the front sat flush with the lip. The set up looked great, just needed a lot more tire to look right in those massive wheel wells.
white93lx is offline
post #72 of 72 (permalink) Old 03-25-2016, 12:02 PM
Woodman's Avatar
Those tires are WAY too narrow for those wheels. Not a big fan of the stretched look myself.
Also, much better way to "fill" the wheelwells is to lower the car.
Woodman is offline
