Projector Headlights - Page 7 - TCCoA Forums
 2Likes
post #181 of 427 (permalink) Old 12-08-2009, 04:45 AM
They said they're the 9007 bulb but are (were) out of stock the last time I checked.
97 Laser Red Thunderbird LX 155k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
96 Ivory Mark VIII 233k, stock 4.6 32v on coils; New engine at 185k
post #182 of 427 (permalink) Old 12-08-2009, 05:45 AM
cant be 9007's, i have a set of those already and the ones here look more like an H1. Maybe i'll just order a set of H1's and dremel off the excess stuff that i dont need and see if i can get it to work.
EDIT: Ordered a set of 4300k H1's from vvme.com, should be here sometime this week or early next. Will update with news once ive got them in. If i can get these to work... 55w HID's are on the horizon
- 4.8.15.16.23.42 -
"You never even hear it when it happens, do you?"
Canadian_LX is offline
post #183 of 427 (permalink) Old 12-08-2009, 08:24 AM
At least, the 9007 from that particular site; not necessarily a "real" 9007 or H1. I don't even know what to think anymore...
post #184 of 427 (permalink) Old 12-17-2009, 02:57 AM
Black_Cat's Avatar
95-97 grand marquis headlights, they bolt right on, they just need some header panel clearancing and wiring for the high/low bulbs.
I'd bet the projectors would fit better in these than the 96/7 housings...
hmm... maybe dual projectors
Thank you so much XR7-4.6 :P I was about to buy new 94/95 headlight housings and throw some Silverstar 9007's in there....but now I think i'll get the grand marquis headlight housings and the BI-XENON kit....and I think I might sacrifice the inner parking light bulbs for dual projectors....it's a possibility.
I drive an endangered species...they are being crushed at an alarming rate. Please do your part to preserve the Cougar species, and ensure they live on into the future.
1995 Mercury Cougar XR-7 4.6L 2V 5 Speed
1998 Lincoln Mark VIII LSC Collector's Edition Car#94
2009 BMW 535i M Sport Package
Black_Cat is offline
post #185 of 427 (permalink) Old 12-17-2009, 03:49 AM
Update on my end...
A while ago I noticed my driver's side projector was out of focus a bit, so I took it out and messed with the bulb placement. Now instead of having it fully seated into the projector, I have it recessed about 1/8" and I've noticed the light fills up the area below the cutoff much more fully, rather than having a distinct focal point at the center. I need to do this to the passenger side as well to get things evened out but I'm too lazy in cold weather to do it now.
post #186 of 427 (permalink) Old 12-17-2009, 04:31 AM
^ crap... cant do this with the OE setup like mine - would like to see some new shots against your garage or steet to see the difference.
Got my new bulbs from VVME yesterday (H1 4300k). Looks like im going to be able to make them work but they will require some mods. I will probably have to dremel off most of the excess plastic. I will take some pics if i have time to do it this afternoon.
- 4.8.15.16.23.42 -
post #187 of 427 (permalink) Old 12-17-2009, 02:48 PM
i've spent a few hours trying to polish my lense to get rid of the issues to no avail. there are some pretty good dings that aren't going to come out.
I'll be saving up for new housings, and possibly an OEM projector swap still.
post up about those bulbs, I'm all ready to try something new again! lol
Left the dead platform for good. It's nice finally having a car you can buy stuff for!
ummduh is offline
post #188 of 427 (permalink) Old 12-17-2009, 10:59 PM
What were you using to polish the lens?? Did you try the Meguires stuff that I recommended?
What an epic fail today was... lol
I was able to machine down the bulbs and get rid of the excess plastic to make them fit, in fact, the fit was quite nice and colour was WAYYYY different.
However, i suppose all of that plastic is there for insulation or something because shortly after i hooked them up i noticed the right side not working. Hmmmm... pulled everything apart to find a loose connection maybe? then i heard the arcing in the other housing. The bulb was grounding itself to the housing so I guess I dremeled off too much plastic lol.
Anyways, ripped the bulbs out REAL quick (ended up dropping one too, shattering the glass) and I also fried one of my ballasts in the process, thankfully I have a few extras.
It was worth a shot and i am still going to continue working toward finding out what kind of bulbs these are.
- 4.8.15.16.23.42 -
post #189 of 427 (permalink) Old 12-19-2009, 07:08 PM
I used meguiars plastic cleaner and plastic polish. theres no way these are going to come out of the lens, they appear to be rock chips.. you can catch a toothpick in them. the good parts of the lens are crystal clear now, but that one rock chip is messing it all up.
i gotta get my front end back in shape and then i need to get the audio into shape, then I'll come back to worrying about the headlights. they're still approximately 7 zillion percent better than halogen no matter what still!
ummduh is offline
post #190 of 427 (permalink) Old 12-19-2009, 09:17 PM
KorpseofDeath's Avatar
Send a message via AIM to KorpseofDeath
I have finally had time to compare this "projector" kit to my actual D2S HID. And they do seem a bit off. I know about the 48 hour "burn in" period, so I will try to be working on that, having the lights set up here in my garage on a timer and i'll have them cycle on and off just like I would be driving my car at night for a few hours, and we'll see how the color and such appear when we get closer to finishing the burn it period.
As for the comparison, I somewhat suspect this projector kit to be the same "hid headlight kit" you see everywhere. Just in this kit is a projector, and a modified headlamp socket to fit. Because when I compare this kit to my D2S bulb, the D2S bulb has a much smoother start-up, and ignition. As for the projector kit, it's just a mere off-beat here and there... I guess a durability test is really want we need. So lets see how far and how good these last.
I did have a projector that my father got my from his work out of the salvage bin, but unfortunately it's a little to large and bulky to fit into the TBIRD housings. I have done my research, and will soon be getting some acura / infinity projector's, around 2 inch one's, and I will try and see about retrofitting those into my old housing.
As for now, I am going to install these, as everyone here has agreed that these are FAR more superior than any regular halogen!! I will be working on an actual projector retrofit within the next coming months, and will report back.
Here's a handy link for explaining D2R and D2S bulbs.
~1997 TBIRD 4.6L LX SPORT ~ Xenon Kit ~ 149K Miles ~ K&N ~ JMOD ~ Daily Driver
~1991 TBIRD 5.0L HO ~ Completely Stock ~
KorpseofDeath is offline
post #191 of 427 (permalink) Old 12-23-2009, 04:08 PM
Still nothing about bulbs from the manufacturer. However, some interesting news.
I am able to place an order for a complete kit direct from them (the manufacturer) at a price quite a bit cheaper than the cheapest of these kits found on ebay. The catch is that there I have to place an order for a minimum of five kits and the shipping is killer (the shipping and customs duties on five of these is as much as two complete kits). However I would still be able to sell for less than those found on ebay. If anybody is seriously considering doing this retrofit, let me know and if enough people show interest, I can place an order and sell them for ~$135 shipped (possibly less if I can find a cheaper shipping option), which would still be only a few dollars above the cost I'd pay per unit shipped to me.
At the time I placed my order, the cheapest kit on ebay was $145, which is what I paid. I am not sure if I can request variants in angel eye color and bulb temperature in the lot of however many I order, however I have asked about that and any cheaper shipping options and should receive an answer soon.
post #192 of 427 (permalink) Old 12-28-2009, 12:59 PM
I'm down for another one, possibly even two! I'd like to try this on my father's Nissan Pathfinder, and also on his TBIRD. So there's 2 kits put down for me already. Let me know if this is looking like a successful group buy!! We'd only need about 3 more (depending if you are ordering another one or not Brandon :P) Keep me posted, I'm subscribed to this thread haha.
I've also been noticing that these can be installed in multiple applications. So it's just depending on if the projector will fit and mount up correctly in other headlights. Thats why I'm wanting to try this on my father's Pathfinder. Get rid of those 9004 bulbs!
Hmmm... Maybe this would also work on my mother's 01 Monte Carlo. I'm going to do some investigating!
post #193 of 427 (permalink) Old 12-28-2009, 01:39 PM
Yeah, I'd be getting at least one more kit for a friend.
They told me that they'd try to accommodate me if I had variance between kits but that they prefer to keep them the same. So I'll lay it down this way:
Kits will be 9004/9007 harness with 6,000k bulbs and will include ballasts, unless you have a strong preference otherwise. Price will be $135 each, including shipping to the continental United States. If you plan on more than one let me know and I'll see if I can get you a quote with better shipping.
As of now I do not know if the price does down if I order more than five. I'll inquire if it comes to that.
post #194 of 427 (permalink) Old 12-28-2009, 04:08 PM
Wow these look amazing, wish I still had my cougar!! For anyone interested I was looking at getting some stuff from http://store.theretrofitsource.com/ !!
matts_96_xr7 is offline
post #195 of 427 (permalink) Old 01-01-2010, 09:22 PM
That's where I ordered all of my Infinity, FX-R, and Acura's projector's from. I've been using them for about 2 years now and are a great source to get from!
post #196 of 427 (permalink) Old 01-01-2010, 09:30 PM
Hmm, really ok. Cause I know I would most likely want to order a different adapter or two and also difference K temperature's. $135.00 is only a $10.00 difference from what I've seen for them on eBay now too. Is that the lowest discount they could offer..
I guess those are my only two questions.. I'm probably looking for like 2 or 3 kits also too, just to let you know.
post #197 of 427 (permalink) Old 01-02-2010, 01:15 AM
I'll see what I can do about price but it depends on how much I can ship them for. At this point I can't guarantee a whole lot, unfortunately. My unit cost is $80 each with ballasts, but the shipping for a set of five is $160. That makes the unit cost $112 and I expect US shipping to be in the neighborhood of $10-$15, leaving me at $122-$127 in cost. So as you can see I'm not making much. I can get a set without ballasts for $58 and those are $119 to ship for 5, making unit price $81.80, so I could sell those for $100-$105 depending on shipping. What temps/harness would you need?
post #198 of 427 (permalink) Old 01-02-2010, 01:21 AM
I am looking for 1 9007 4500k, 1 9006 6000k, and maybe a 1 9004 6000k.
post #199 of 427 (permalink) Old 01-02-2010, 01:23 AM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
Go to http://www.vvme.com/ for the cheap stuff !!!
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #200 of 427 (permalink) Old 01-02-2010, 01:27 AM
They don't appear to be selling any kits with projectors. I'm thinking that it's the projectors that are making the biggest difference in the lighting effectiveness for our application, moreso even than the brighter bulbs.
For a set of three with ballasts I might be able to do $125 - $130 shipped each. I need to sit down and do some rates research yet. Any preference to angel eyes color? Here is what they say about colors:
In fact,we'd like you to order the same type of kits.But I will try to meet your requirement if you can tell me which type you want excatly.I remember your order before is the 9004/9007 bulb,for this type,the bule angel eyes have the 4300K,6000K and 8000K.the white angel eyes have 5000K,6000K and 8000K.
post #201 of 427 (permalink) Old 01-02-2010, 04:12 AM
I will be going with the white angel eyes.... I think you would get in trouble with having the blue angel eyes, since blue light's on the front of vehicles is strictly reserved for emergency vehicles.. at least here in CA it is..
post #202 of 427 (permalink) Old 01-02-2010, 04:35 AM
^^ the blue is hardly noticeable when the projectors are on, the only time you can see them is if you are up close looking down at them or maybe from the side at a stop light or something but even then ... who is looking right?
When the lights are off the blue is BRIGHT though lol
I have had absolutely ZERO luck finding replacement bulbs for these projectors. So I may just order a whole new kit. Maybe i'll use the old one for HID reverse lights lol.
- 4.8.15.16.23.42 -
post #203 of 427 (permalink) Old 01-02-2010, 12:26 PM
Cops where I live. I know some people with BMW's, who like to customize their angel eyes.. I've seen Red one's, Blue ones, White, ect... I know the white are the most effective, and I know of a story where one of my buddies got pulled over in the in n out parking lot, (he wasn't even driving, just sitting with his halo's on eating). Got a $40. dollar ticket for the blue angel lights.... Cops around here, or should I say Alameda Sheriff, sometimes get bored at night and LOVE to pick on people... Trust me I know. lol
No replacement bulbs yet huh.. Didn't someone have luck grinding down an H1 bulb or something of that nature? I'm not sure how that came out though, i'll have to scroll back a page and see if I can find that. Also, weren't some found at the manufacturer who sold these kits for like $18. bucks each?
post #204 of 427 (permalink) Old 01-02-2010, 01:54 PM
When I asked them about replacement bulbs they said they sold them for $18, but were out of stock. The last time I asked about them (a week or so ago) they said they were still out of stock.
post #205 of 427 (permalink) Old 01-02-2010, 05:10 PM
That was me, and it was an epic fail that cost me one of my ballasts... i dont want to talk about it lol.
Terminator found those bulbs for 18$ and rest assured, i'll be ordering a few sets once he confirms that they are in stock.
- 4.8.15.16.23.42 -
post #206 of 427 (permalink) Old 01-02-2010, 09:59 PM
hmm.. I am determined to get this bulb situation figured out.. I really want to adapt an D2S to this! I will just have to lock myself in the garage with that bulb, projector, and all my tools and see what I come up with, lol!
post #207 of 427 (permalink) Old 01-11-2010, 11:55 PM
As far as the "group buy" goes I've got at least two kits on my end, most likely three. So combine those with KorpseofDeath's two/possibly three and we're over the minimum order threshold.
post #208 of 427 (permalink) Old 01-12-2010, 01:19 AM
I may have to order another kit as well... i ****ed up one of my ballasts stupidly and im not sure how well my spare is going to hold up lol. I also want a different colour. Any luck with spare bulbs yet?
- 4.8.15.16.23.42 -
post #209 of 427 (permalink) Old 01-12-2010, 12:30 PM
Sweet! Keep my updated. Hopefully we can order these before the end of January?? Also mark me down for 2 kits. I'll skip on the third one for now, since time and money will be a slight issue.
The two I would like is
1. 9004 4500k
2. 9007 4500k
Also, I know different sellers have different Kelvin color's, so around 4300K or 4500K would be fine for me. As long as it's not any lower than 4300K, (I don't want yellow foglights, but BRIGHT WHITE light, and I don't want anything over 5000K, which will start into tinting into the blue Kelvin color, if you know what I mean.)
post #210 of 427 (permalink) Old 01-12-2010, 12:43 PM
Okay, I think they're 4300k. I'm going to start a group buy thread in the for sale section to a) keep this thread a little less cluttered, b) possibly cultivate more interest and c) help keep track of quantity.
No update on bulbs, unfortunately...
Here is the link to the for sale thread: HID Retrofit kit with projectors GP
