New idea for restoring headlights - Page 2 - TCCoA Forums
 2Likes
post #31 of 50 (permalink) Old 10-23-2012, 01:30 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
Originally Posted by NetKeym View Post
Let me ask y'all something. After y'all spray the clear coat on your headlights to extend the life before they need refinishing, then the year to year and a half later when you DO require refinishing, how tough is it to sand all the clear coat AND oxidation off to start all over again?
Word! I wanna know this too so I can have a game plan for my "new" lights. The regular lacquer clear I used is all peeling and sucks now, maybe I should have used the uv blocker, or perhaps this lamin-x is the way to go. Is this something I can install myself?
-Rob
RIP '94 Amber Fire Pearl Metallic Thunderbird on Bullitts 14.56@90.54MPH
96 Sport '02 Explorer PI with ported heads, 90MM LMAF, DirtyDog Marauder TC, Inject tech chip, Jmod, Magnaflow mid-mount with Tru-X core, no cats. Urethane drivers motor mount. HIDs!
Rob is offline
post #32 of 50 (permalink) Old 10-23-2012, 02:55 AM
Seasoned Geek
I clean my headlights once per month with Plastx to keep them like new
post #33 of 50 (permalink) Old 10-23-2012, 05:22 PM
scskydivin's Avatar
Where can I get this stuff? And how is it used?
UP THE IRONS!!!
scskydivin is offline
post #34 of 50 (permalink) Old 10-23-2012, 05:47 PM
WalMart and the local chains carry it here - but you can buy it here also.
Instructions are in the package, but it's like almost any other polish.
RalphP is offline
post #35 of 50 (permalink) Old 07-28-2013, 02:35 PM Thread Starter
Raoul Duke
cougarcragar's Avatar
Thumbs up Update
UPDATE - 7-29-13
It's been over two years since I started this thread, and my headlights still haven't turned yellow. This is the original UV-blocking clearcoat that I used in 2011 that you can see in the first post. This job was certainly well worth the effort.
1996 Mercury Cougar XR7
cougarcragar is offline
post #36 of 50 (permalink) Old 07-30-2013, 05:26 PM
I'm going to buy a can of that asap.
Thanks!!
post #37 of 50 (permalink) Old 10-06-2013, 06:41 PM
Send a message via AIM to fkostyun
Followed this method today, and the end result looks great! There wasn't a huge amount of visible yellow, but, as a stop-gap I had just sprayed clear over the poor looking ones last year.
The Start
Post 120 Grit Sanding
Post 220 Grit Sanding
Post 320 Grit Sanding (First Wet Sanding)
Post 400 Grit Sanding
Post 600 Grit Sanding
Post 800 Grit Sanding
Post Clear Coat spray.
Once the clear has hardened for a couple of days, I'll do a sand at 1000, 1500, 2000, then 2500 and then polish.
fkostyun is offline
post #38 of 50 (permalink) Old 10-12-2013, 07:49 PM
I did this today; it is amazing how good it looks.
My headlights look great; and the little cracks in the corner lights disappeared, which I did not expect.
Thanks for the tip!!
post #39 of 50 (permalink) Old 11-04-2013, 09:25 PM
I used a three step polish job on my 95 Cougar headlights a few days ago, so I guess I'm good to go for a month or two. No clear coat afterward though.
By the way, what are these "clear corners" that seem to be referred to here a lot? I've never heard the expression before I joined here.
Kevin
MntnLion is offline
post #40 of 50 (permalink) Old 11-04-2013, 09:59 PM
jhiland32's Avatar
After market front corner housings with no amber.
Jason H.
Mods:
jhiland32 is offline
post #41 of 50 (permalink) Old 11-05-2013, 10:50 AM
OK, thanks Jason. I still prefer the stock ones, but that's just me.
Tbird Bob likes this.
MntnLion is offline
post #42 of 50 (permalink) Old 01-17-2014, 04:31 PM
Torinocator's Avatar
Has anyone tried Eastwood's 2k clear urethane rattlecan on theirs?
http://www.eastwood.com/review/produ.../category/978/
It's more pricey, but I would think it would be a more durable clearcoat than the lacquers and I might give it a shot on mine in the spring.
Use a tool, don't be one...
-Mark
1997 Thunderbird LX 4.6L
1970 Torino GT 351C 4V
...................................GT
Torinocator is offline
post #43 of 50 (permalink) Old 02-21-2014, 06:45 PM
Even Duplicolor has caught on! They now make a kit with a UV clear.
http://www.duplicolor.com/products/h...htRestoration/
fkostyun is offline
post #44 of 50 (permalink) Old 08-24-2014, 11:02 AM
CrystalPistol's Avatar
OK ..... Gotta check it out tomorrow morning then .... Thanks.
⦁ HLR100 - Kit
⦁ HLR200 - Spray Polish
⦁ HLR300 - Clear Coat
Restores Faded Lenses
Provides Lasting UV Protection
Easy 2-Step Process
Includes Spray Polish and Clear Coat
CrystalPistol is offline
post #45 of 50 (permalink) Old 02-01-2015, 02:20 AM
I couldn't find the original post where the wet sanding deal was explained. Wanted to tell the guy I tried it, and worked most excellent! Started with 400, then 1000, to 1500, 2000. Then used some leftover Mothers Restore from a kit a guy gave me. Awesomeness abounds! 2 decades of yellow and pitting gone. On the road at night... nice. Thanks. I like this place.
xquzzme is offline
post #46 of 50 (permalink) Old 02-01-2015, 01:52 PM
Hey. These are good tricks for the outside of the lens. Does anyone have any tricks for getting the condensation out from the inside... and keeping it out?? Thanks.
xquzzme is offline
post #47 of 50 (permalink) Old 02-23-2016, 07:07 PM
I found out, completely by accident, that Chemtool-B12 carb cleaner will completely remove the oxidation layer on these headlights, and by painting them as soon as it's dry, they look factory!!
Don't do this on the car, it will waste your paint; use it on trashed ones.
The headlights I recovered were complete 'white' trash before; I'll post pix.
I'm still using the sign paint clearcoat; it hasn't gone bad yet anywhere I've used it.
post #48 of 50 (permalink) Old 02-23-2016, 07:47 PM
Headlight Restoration Kit - Aerosol Kit | Dupli-Color
Their clear coat looks like a repackaged lacquer paint.
Does anybody here have any examples of where they have clear-coated the lens after polishing and it's lasted for more than a year?
-Mark
post #49 of 50 (permalink) Old 06-01-2016, 11:33 PM
When my car was still on the road, I seemed to need to polish them about once a year, but they'd always go opaque again in short order. I'll replace them both one of these days, as soon as I can figure out how to get those insane clips off.
MntnLion is offline
post #50 of 50 (permalink) Old 06-02-2016, 12:04 PM
Woodman's Avatar
PI Swapped NPI motor with some port work on the heads, PI cams, 80mm MAF, CAI that feeds from fenderwell. Jmod, 3.73:1 TL in Mark VIII carrier, Mark VIII aluminum LCAs, 93 Mark VIII driveshaft, PBR brakes (soon to be Cobras), 18x9 wheels, 255/40/ZR18 Tires, Front and Rear strut/shock bracing, GR-2 shocks, Eibach 1.5" springs, 1989 SC front and rear sway bars.
Woodman is offline
