LED source for trunk tail lights - TCCoA Forums
 3Likes
  • 1 Post By Tattler
  • 1 Post By RalphP
  • 1 Post By XR7-4.6
post #1 of 17 (permalink) Old 12-21-2015, 06:37 PM Thread Starter
Alltronics.com Listed as 3rd brake light strips. HP #QPWR-G299.
Their #96L001, $14.
Merry Christmas
KULLER94 likes this.
Tattler is offline
post #2 of 17 (permalink) Old 03-05-2017, 02:20 PM
Natesriv's Avatar
Just bought 2! Need to replace the ones I have and have a spare.
Pain in the butt to get the OEM LED strip out. Need to be careful with the dremel and cut nice straight lights.
Natesriv is offline
post #3 of 17 (permalink) Old 03-06-2017, 01:13 PM
Glenn's Avatar
Please provide detailed information on the new LED strip and installation and if it was an exact replacement or only close to original. How does the panel lights look at night - any pictures of panel at night would be great. Did the new LEDs in the repaired panel look exactly like the opposite original panel?
The LED strips do look like the originals - see link.
http://www.alltronics.com/cgi-bin/category.cgi
Glenn
1996 TB LX, 4.6, 120,000 miles, black with tan interior.
Dark tint and OEM "Sport" spoiler.
Glenn is offline
post #4 of 17 (permalink) Old 03-06-2017, 01:39 PM
Tbird Bob's Avatar
I've never seen these on a bird. Were they an option?
Tbird Bob is online now
post #5 of 17 (permalink) Old 03-06-2017, 02:27 PM
Natesriv's Avatar
They're OEM on mine. The lights on the trunk part.
these are the exact replacements for what's in there.
It's basically a circuit board of LED's, encased in that silver chromed holders, topped off with clear plastic lenses to magnify the lights.
I'll do a write up with lots of pictures. There's one on here now but it needs more info.
You do need to be wary of cutting. I'll need a better Dremel cutting head, and I'll need to buy another junkyard driver's part as I destroyed mine in my prototype attempt.
I'll post it all up when done
Natesriv is offline
post #6 of 17 (permalink) Old 03-06-2017, 02:52 PM
Natesriv's Avatar
Just purchased two more lights on eBay for $40 free shipping...
I'll be cutting soon!
Natesriv is offline
post #7 of 17 (permalink) Old 03-06-2017, 02:53 PM
Glenn's Avatar
This will be a most interesting write-up. I have wanted to repair my PS rear panel for years. But, have been reluctant to do it without a detailed write-up and pictures. My TB looks bad from the rear at night with one good panel - all nice and bright and the PS half lit. I have recently acquired a PS panel, but just do not have enough information on the process to proceed. I am sure many other TB owners will benefit from the write-up. Thanks.
Glenn
Glenn is offline
post #8 of 17 (permalink) Old 03-06-2017, 03:53 PM
Natesriv's Avatar
No problem. luckily the lower portion of the tail light is black, so if you cut JUST below that line, straight from one end to the other, you'll get enough movement to pull that LED assembly out. You'll notice in the pic of the LED there's two screws, those are the bumps on the back of the tail light assembly. It's important to keep them, so the LED doesn't wiggle & bounce around. I'm not sure how robust 1990's LED's are!
I can't wait either!!!
Natesriv is offline
post #9 of 17 (permalink) Old 03-06-2017, 05:46 PM
Direct link for those looking:
Red LED Light Bar (3rd Brake Light) | Alltronics
Natesriv likes this.
Fuelly
RalphP is offline
post #10 of 17 (permalink) Old 03-06-2017, 06:27 PM
Natesriv's Avatar
KEEP your old LEDs if you take them out. You can de-solder them and put them in place of ones which are burnt out.
Recycle!!!
Natesriv is offline
post #11 of 17 (permalink) Old 03-06-2017, 06:32 PM
Slightly Disjointed
the brightness may vary between old and new, you'd be better off replacing the whole strip. odds are the strip is what went bad anyway, not the LEDs
post #12 of 17 (permalink) Old 03-06-2017, 07:16 PM
Kenz's Avatar
You might have seen the few pictures I posted a while back when I did mine. What I did was use a red flexable LED strip, and I hot melt glued it over the top of the factory light strip. I got two of them on amazon for under 10$ IIRC. It worked out well and is about the same brightness as the taillights when lights are on.
Getting out the strip was a lot more tedious then I expected. The black plastic housing is pretty thick and not easy to cut. I went through quite a few rotary bits. You also need to be careful you don't cut too far up in the light housing to remove the strips; or it will be noticeable due to the reflective surface being broken.
After going through all that for my Tbird... I am honestly kind of glad the Cougars never got the LED running lights.
- 96 Cougar Sport 4.6 -
  • Cobra Mustang Diff
  • 93 Mark Solid Driveshaft
  • Tint & Pioneer Audio
  • More in the works!
Kenz is offline
post #13 of 17 (permalink) Old 03-06-2017, 07:19 PM
Natesriv's Avatar
I saw your post..good write up.
You have to ensure you cut JUST A LITTLE bit below the black on the front of the assembly. Cut wide enough to be able to jostle it out too..
Don't worry about damaging the one that's in there, just be patient. WEAR SAFETY GLASSES, and take your time!
Natesriv is offline
post #14 of 17 (permalink) Old 03-06-2017, 07:27 PM
Natesriv's Avatar
It all depends on how deep you want to go into the rabbit's hole. If your TBird has a few burnt out and their dimmer you could solder some of the "good" ones into it... You can get to the LED's but need to be careful prying the assembly apart... Would be a lot of careful prying, and gluing back together...
But for the price they have online, it's just easier to buy new ones... they seem to have 42 left... wonder if that's it all together!
Why Ford didn't think to make that one part replaceable.....who knows!
Natesriv is offline
post #15 of 17 (permalink) Old 03-09-2017, 12:58 PM
Glenn's Avatar
Bought two yesterday.
Glenn is offline
post #16 of 17 (permalink) Old 03-10-2017, 11:51 PM
Glenn's Avatar
Got my two LED strips today - two day delivery. Very well made - good quality and they even have the same electrical connector on them as the original. As soon as the instructions are posted I am going to do this job.
Glenn is offline
post #17 of 17 (permalink) Old 03-13-2017, 07:50 PM
We discussed it before:
Cougar Reflector Panels
"Simpsons did it!"
lol.
