97-98 Mark VIII Grill Lower Fasteners - What the Heck? - TCCoA Forums
post #1 of 4 (permalink) Old 03-24-2017, 08:24 PM Thread Starter
Mach1Motorsports's Avatar
Thumbs down 97-98 Mark VIII Grill Lower Fasteners - What the Heck?
I searched here, another Mark VIII forum, and Google with no luck.
I have removed the bumper cover and just need to remove the lower grill fasteners to remove grill from the bumper cover, but I cannot figure out what type of fastener or size it is. My eye sight is not great, but it felt like a small bolt but after trying 6 mm thru 11 mm I gave up. Please tell me what type of fastener it is.
96 Saleen Cobra 55k
98 Mark VIII 91K
97 Mark VIII LSC 175k
94 Mark VIII 122k
84 Bronco 351 HO 115K
66 Mercury Monterey 390
49 Lincoln 2 dr
70 Mustang Mach 1 351C 4V Restored
Mach1Motorsports is offline
post #2 of 4 (permalink) Old 03-24-2017, 08:43 PM
It's been a while since I did it, but my memory is that the grill comes off with the bumper cover, and then I think it was just tabs that clip into slots in the bumper cover.
post #3 of 4 (permalink) Old 03-24-2017, 09:22 PM
Thunderstruck95's Avatar
There are 4 Phillips screws holding it in from the bottom. The two outer screws are accessible from the slits in the bumper opening. The center 2 will be difficult. You will probably need a Phillips attachment for a rachet and a short extension. Good luck getting your arm in there. And try not to strip the heads.
1995 T-Bird. PI 4.6. Bullitt intake. Big MHS cams. 4,200 Dirty Dogg converter. Kooks headers. Full exhaust. 4" Drive Shaft. 4:10s.
Waiting on a tune.
1997 Lincoln Mark VIII FX2 Sand Dune Machine.
Thunderstruck95 is offline
post #4 of 4 (permalink) Old 03-24-2017, 09:56 PM Thread Starter
Ok. Bad place 4 use of phillips...
I guess that's why a socket wouldn't fit. Thanks for the info. I am hoping I can get it off.
96 Saleen Cobra 55k
98 Mark VIII 91K
94 Mark VIII 122k
49 Lincoln 2 dr
Tags
fastener type , gen 2 , grill removal , mark viii
