tail light problem - TCCoA Forums
post #1 of 12 (permalink) Old 05-05-2017, 01:12 PM Thread Starter
Boost!!!
modularbird's Avatar
tail light problem
Hey guys, I didn't know if anyone has had this issue, because I couldn't find a thread on it...The bird me and my wife bought has developed a problem...Both the tail running lights have gone out completely, but not the reverse lights, or blinkers. Also the interior dash lights (gauges) quit working at the same time. We checked all the fuses, and none are blown...any ideas?
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
post #2 of 12 (permalink) Old 05-05-2017, 02:08 PM
Do you have headlights? I had a problem with mine (headlights and dash lights) and it was the headlight switch.
The multifunction switch can mess up a few things too when it goes bad, might want to look into that.
post #3 of 12 (permalink) Old 05-05-2017, 05:00 PM Thread Starter
Boost!!!
Headlights work, but they are auto. The headlight and dimmer switch do nothing to the dash lights, but the dimmer switch does still turn on the dome light.
Blake
post #4 of 12 (permalink) Old 05-05-2017, 05:32 PM
Just dont hit the brakes!!!
bulldog is offline
post #5 of 12 (permalink) Old 05-05-2017, 06:06 PM Thread Starter
Boost!!!
Brake lights work too. The running lights don't
Blake
post #6 of 12 (permalink) Old 05-05-2017, 07:53 PM
Woodman's Avatar
Did you check ALL the fuses (including those under the hood)?
I'd suspect the multi-function switch. Quite a few connections in that turn signal lever that cause lots of goofy issues when it goes bad. Motorcraft are still available on Rock Auto, and they tend to last about 20 years or so...
Woodman is offline
post #7 of 12 (permalink) Old 05-05-2017, 09:15 PM Thread Starter
Boost!!!
All fuses in kick panel and under hood are good. Any way to check the switch besides replacing it? Don't think I can get one tomorrow, and I'm only in town Saturday and part of Sunday every weekend to work on it... I'll check the auto parts store for a switch tomorrow.
Blake
post #8 of 12 (permalink) Old 05-05-2017, 10:53 PM
Woodman's Avatar
I haven't had good luck overall with parts store electronics. I'd say order a genuine Motorcraft unit from Rock Auto, and it'll be there for you to work on next weekend. It's a $35 part, easy to change, and the first step in troubleshooting goofy lighting issues.
Woodman is offline
post #9 of 12 (permalink) Old 05-06-2017, 07:41 AM Thread Starter
Boost!!!
I'll probably take the switch from my car and try it on hers before I buy parts that might fix it. Just to save time. If it fixes it then I'll buy a new one.
Blake
post #10 of 12 (permalink) Old 05-06-2017, 08:40 AM
Natesriv's Avatar
Isn't the switch for the autolight setup different than non auto units? I've a salvage yard switch, but I'm not sure it's an auto or non auto unit.
How to tell?
Natesriv is offline
post #11 of 12 (permalink) Old 05-06-2017, 11:08 AM
Woodman's Avatar
How to tell?
The switch itself is the same, the auto lamps have an extra part that plugs in I believe.
Woodman is offline
post #12 of 12 (permalink) Old 05-06-2017, 12:11 PM Thread Starter
Boost!!!
It has a dial like the dimmer switch for the autos.
Blake
