Interchangeable - TCCoA Forums
post #1 of 4 (permalink) Old 05-16-2017, 03:54 PM Thread Starter
Cobra_Bird's Avatar
Interchangeable
Had a moron hit me head on. Header panel is in crumb form, front fenders are buckled in & steel bumper bar is bent. Found a body shop with an abandoned cougar, same year as mine (95). Said I can take what I need for $75 then it's getting scraped.
Will the fenders swap?
Mark
Semper Fi til I die.
Cobra_Bird is offline
post #2 of 4 (permalink) Old 05-16-2017, 04:07 PM
Fenders will, yes.
Are you going to get the front tub straightened by a frame shop first?
I'd HIGHLY recommend it; after the shop resquared the 1991 Cougar, it tracks and drives even better than before the minor fender bender four years ago (!!)
Fuelly
RalphP is online now
post #3 of 4 (permalink) Old 05-16-2017, 04:08 PM
Yes sir!
post #4 of 4 (permalink) Old 05-16-2017, 07:59 PM
Fenders, bumper, rad support, and front frame rails are all the same. The foam bumper absorber, bumper cover, hood, grille, header panel, and headlights are different. The corner lights are the same. I would suggest getting the bird in a body shop, torn down, and on a frame machine first so you know exactly what you need before they junk the Cougar.
