Rear Deck Recover in Black - TCCoA Forums
post #1 of 34 (permalink) Old 09-03-2011, 08:35 AM Thread Starter
I have been wanting to change my rear deck from grey to black to go with the carpet and make it blend in more. I also wanted to remove the 3rd brake light since it wasn't used anymore since I use the one in the spoiler.
I looked at some of those premade covers and ended up with a $10 roll of black Ozite and some contact cement. I replaced the 6x9 speakers with 8" woofers while I was at it.
1995 PI Tbird
1995 Lincoln Town Car
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #2 of 34 (permalink) Old 09-03-2011, 02:10 PM
Black_Cat's Avatar
Looks clean from what I can see
I drive an endangered species...they are being crushed at an alarming rate. Please do your part to preserve the Cougar species, and ensure they live on into the future.
1995 Mercury Cougar XR-7 4.6L 2V 5 Speed
1998 Lincoln Mark VIII LSC Collector's Edition Car#94
Black_Cat is offline
post #3 of 34 (permalink) Old 09-04-2011, 03:51 PM
Stryker's Avatar
I've wanted to do that myself, did you recover the seatbelt things on the deck as well?
Mods: The usual stuff... 3.73 Gears, J-mod, catless mandrel 2.5" true duals, Marauder Converter, Eibachs, Xcal2 and Phoenix Gold Audio, chrome 18's, etc. etc..
I joined the dark side...
2002 Mustang GT, FRPP Aluminator with Tork Tech MP112 intercooled S/C at 17PSI, with all the supporting mods.
Stryker is offline
post #4 of 34 (permalink) Old 09-04-2011, 04:11 PM Thread Starter
I actually got some black seat belt covers from someone on SCCOA.
It would probably be easier to dye them vs recover since they are curvey.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #5 of 34 (permalink) Old 09-04-2011, 10:54 PM
N8tiveJuggalo17's Avatar
wow that looks nice, thats actually the thing i was just looking into...what subs did you put back there? can u take some pics of your set-up? How does it sound?
---Jeremy
N8tiveJuggalo17 is offline
post #6 of 34 (permalink) Old 09-05-2011, 07:17 AM Thread Starter
No Subs, those are Dayton Audio RS225-4 8" woofers running 35-800 hz powered with a 200 watt Kicker amp. Those are 10" grills as 8" were too small.
I am not into the body thumping bass from subs.
I have JL Audio 6" mid-bass running 800-5,000 hz powered with a 150 watt Kenwood amp in the stock rear holes. I think that setup makes for some good rear fill, nothing exotic.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #7 of 34 (permalink) Old 10-03-2011, 09:30 AM
So how did you remove the rear deck piece? I see you have to pull out the seat belt covers and then take out the bolts for the seat belt assembly. But what do you do with the 3rd brake like? I was thinking about recovering mine and got about as far as that.
DDBThunderbird is offline
post #8 of 34 (permalink) Old 10-03-2011, 09:59 AM
S4gunn's Avatar
Please PM me if you guys need a set of tan seatbelt/third brakelight covers in good condition to play with dyeing (some of the last unsold things off my Lemons track car).
IMO, RIT dye should work.
Regards,
-g
S4gunn is online now
post #9 of 34 (permalink) Old 10-03-2011, 07:44 PM Thread Starter
To remove the deck I did not take out the bolts holding the seat belts in place. I removed the covers, slid the 3rd brake light cover forward and removed it. There is a screw holding the 3rd brake light in place. Take out the push-pin behind the rear seat and it the cover should come off.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #10 of 34 (permalink) Old 10-03-2011, 11:21 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
What applications would I have seen this ozite carpet in before? I am considering doing a black interior on my black sport sometime.
-Rob
RIP '94 Amber Fire Pearl Metallic Thunderbird on Bullitts 14.56@90.54MPH
96 Sport '02 Explorer PI with ported heads, 90MM LMAF, DirtyDog Marauder TC, Inject tech chip, Jmod, Magnaflow mid-mount with Tru-X core, no cats. Urethane drivers motor mount. HIDs!
Rob is offline
post #11 of 34 (permalink) Old 10-04-2011, 05:37 AM Thread Starter
I have heard of people glueing it in place of the factory floor carpet for weight savings.
I have only seen it on the rear deck in a car. It looks just like the texture of the factory rear deck carpet. I would think that is also ozite.
Speaker boxes are covered in a gray ozite.
It is also used in RV headliners.
I am sure there are plenty of other uses.
It is made from recycled soft drink/water bottles.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #12 of 34 (permalink) Old 10-04-2011, 02:40 PM
Slightly Disjointed
Feels like it too, which is why I'm on the hunt for some alcantara for mine
post #13 of 34 (permalink) Old 10-08-2011, 06:46 AM
Rob
Rob's Avatar
Yeah, I dont know what that is either, lol. I will do a search. I was going to find some black vinyl for the job most likely.
-Rob
Rob is offline
post #14 of 34 (permalink) Old 10-15-2011, 09:58 AM
jjmitch87's Avatar
Send a message via AIM to jjmitch87 Send a message via MSN to jjmitch87 Send a message via Skype™ to jjmitch87
you said they are not subs, but woofers. subwoofer.... unless i am retarded cuz i just woke up, they are the same thing are they not? i stumbled upon your thread cuz im thinking bout changing my entire interior to black, what you did looks real good.
97 green, 4.6L sport package. k&n cold air from an 01gt. so far my best at the strip was 15.808 @ 89mph at new england dragway.
jjmitch87 is offline
post #15 of 34 (permalink) Old 10-15-2011, 11:55 AM
Technically, a subwoofer fills in bass below where the woofer drops out.
For instance, my home stereo AR7s are solid down to about 50Hz. I'd use a sub to fill in from say 60 to 15 or 20.
Practically, in cars, they're used interchangeably.
RalphP is offline
post #16 of 34 (permalink) Old 11-27-2011, 10:56 AM
jjmitch87's Avatar
thank you for clarifying that Ralph. now it makes sense
post #17 of 34 (permalink) Old 11-17-2016, 09:13 AM
jco1385's Avatar
Bump!!!
I'm about to do this exact thing. I'm curious if the OP (or anyone else...) removed the old covering or just went over it. I've got the panel that deletes the 3rd brake light and I've tried to remove the covering but the 'board' is just some stiff type insulation material. It's not very rigid and is shredding as I try to peel the covering off. Also, what would be a good adhesive for this?
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #18 of 34 (permalink) Old 11-20-2016, 07:12 AM
Rayo's Avatar
I don't think it would be possible to remove the fabric from its backing..
They used some sort of cardboard material bonded to the back of the fabric..
Doing so would potentially destroy the fabric and or backing, rendering it useless..
If you planned on recovering the Rear Deck Cover anyways, maybe it would be wise to start with a new backing material..
Might I suggest 1/8" Lauan Panelling as a backing material for the fabric..
You could use your 3rd brake light delete panel as a template to cut the Lauan to the right size and shape..
Then just glue your new fabric down with some Headliner Adhesive
The seat belt pods are going to require a little more work, but the headliner adhesive should work well if you need to recover those as well..
1991 Ford Thunderbird Sport
Rayo is offline
post #19 of 34 (permalink) Old 11-29-2016, 11:58 AM
jco1385's Avatar
The panel itself is made from some sort of shredded cloth or something then pressed into shape with the carpet glued to that. Getting the factory carpet to come off cleanly is basically impossible. I found two of the delete panels so I grabbed them both to have one I could test on. I saved the better of the two for the actual project.
I ended up with THIS recycled plastic carpeting from O'Reilly and THIS spray adhesive from Hobby Lobby (40% off coupon!).
This is the panel after I got it as clean as possible and ready for the adhesive. I also trimmed off the folded fabric around the curved edge. You can see the new carpet in the background.
The directions on the adhesive say to spray both pieces for the best possible bond. I only bought the one can, and it was just enough to spray the entire panel but not the new fabric. This was not a problem for me, but if you want to spray both buy 2 cans of the adhesive. By the time I got done spraying the panel it had enough tack to apply the fabric. This adhesive stays tacky for a few minutes so it's pretty easy to work with. I paid close attention to the edges and the relief of the contours. I think it came out really nice for the effort and cost involved.
This is before I cut and wrapped the rounded edge that goes toward the glass. I'll get a finished pic up once I do that.
I'm not sure that a flat piece of lauan would work because the deck isn't entirely flat. I also wanted to keep it as 'stock' looking as possible. I already have the black seatbelts and their covers.
jco1385 is offline
post #20 of 34 (permalink) Old 11-29-2016, 12:02 PM
Slightly Disjointed
I'd like to see how this matches up with the factory black seatbelt covers. I'd like to do the same with mine over the winter
post #21 of 34 (permalink) Old 11-29-2016, 12:10 PM
jco1385's Avatar
I'll get some pics of that as well as side by side pics of my recovered delete panel and the stock black panel that it is replacing.
jco1385 is offline
post #22 of 34 (permalink) Old 11-29-2016, 02:33 PM
Rayo's Avatar
Ok, so basically you just glued the new fabric over the old fabric?
Rayo is offline
post #23 of 34 (permalink) Old 12-01-2016, 09:52 AM
jco1385's Avatar
Yes. I just wanted to share my experiences in case someone wants to do this.
jco1385 is offline
post #24 of 34 (permalink) Old 12-20-2016, 03:07 PM
Mach1Motorsports's Avatar
Most auto parts stores have 3m tri adhesive. Its really the best stuff to use, but don't get any on your paint or anything nice as it can do damage. It is spray on both sides and when tacky you can lay the fabric down. You can lift and reapply if necessary. I've used it on lots of different projects like vintageMustang headliners and after 25 years, its still holding.
If the seat belt covers are plastic, some vinyl dye in a spray can does a great job. As long as you clean the part properly it won't ever flake or peel off. The finish is amazing and does not look 'painted.'
96 Saleen Cobra 55k
98 Mark VIII 91K
97 Mark VIII LSC 175k
94 Mark VIII 122k
84 Bronco 351 HO 115K
66 Mercury Monterey 390
49 Lincoln 2 dr
70 Mustang Mach 1 351C 4V Restored
Mach1Motorsports is offline
post #25 of 34 (permalink) Old 01-24-2017, 11:53 AM
jco1385's Avatar
I finally got this finished up. Here is the recovered panel against the stock 93 panel and belt covers. The covers are faded a bit but it may not be too bad. If I don't like it, I'll shoot them with the SEM color coat that everything else is getting.
jco1385 is offline
post #26 of 34 (permalink) Old 01-24-2017, 12:11 PM
Slightly Disjointed
Better than I expected, does the texture feel the same? I'm nearing the point I'll be doing this one way or another.
post #27 of 34 (permalink) Old 01-24-2017, 12:16 PM
jco1385's Avatar
Yeah the texture is a match. It's the same type of material. I didn't notice those slight lines you can see until I looked at the pics. I'd do it again the same way.
jco1385 is offline
post #28 of 34 (permalink) Old 01-24-2017, 09:54 PM
Slightly Disjointed
Great! I know my weekend project
post #29 of 34 (permalink) Old 01-25-2017, 08:10 PM
Kenz's Avatar
On one of my previous cars I used a spray can of black carpet dye to do this. It held up surprisingly well over the years and the fabric kept about the same feel. I would use it again
Like Dusty said in 2011... might be useful for the seat belt covers at least.
- 96 Cougar Sport 4.6 -
  • Cobra Mustang Diff
  • 93 Mark Solid Driveshaft
  • Tint & Pioneer Audio
  • More in the works!
Kenz is offline
post #30 of 34 (permalink) Old 02-02-2017, 04:57 PM
Slightly Disjointed
Bought a roll of the O'reilly carpet today, definitely a decent match. The factory black seatbelt covers are a hair lighter(Cougar package trays generally don't get UV damage like the Tbirds) but close enough. As said, texture is identical, it's a lot softer though(not a negative). I should have enough leftover to do the door bottoms as well
