Custom Gauges - TCCoA Forums
 12Likes
  • 7 Post By MaddMartigan
  • 1 Post By VicRattlehead
  • 1 Post By lcortinas
  • 2 Post By MaddMartigan
  • 1 Post By lurch
post #1 of 27 (permalink) Old 04-03-2017, 06:57 PM Thread Starter
MaddMartigan's Avatar
Custom Gauges
I've been on a journey and I'm almost at the end.
When my temp gauge stopped working I decided to revisit the idea of a custom gauge cluster. I've attached the result. I also attached the mock up of the mounting plate. Once I get the wiring worked out I'll update this thread.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #2 of 27 (permalink) Old 04-03-2017, 11:20 PM
VicRattlehead's Avatar
nice. I still have my cardboard template for my setup but still haven't done it yet. someday ill get to it.
MaddMartigan likes this.
CMP Drag Racing
VicRattlehead is offline
post #3 of 27 (permalink) Old 04-04-2017, 09:40 AM
When you get it installed send pic. Its going to look nice.
lcortinas is offline
post #4 of 27 (permalink) Old 04-04-2017, 06:48 PM
Great job !!
Creighton
Just keeping the history on the road.
Creighton is offline
post #5 of 27 (permalink) Old 04-05-2017, 05:01 AM Thread Starter
We're wired in!
FRPP 42# injectors
3.73 gears
OMGHI2U
post #6 of 27 (permalink) Old 04-05-2017, 05:04 AM Thread Starter
....and here we go:
Grog6 and Woodman like this.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #7 of 27 (permalink) Old 04-05-2017, 10:37 AM
Slightly Disjointed
post #8 of 27 (permalink) Old 04-05-2017, 10:48 AM
Did you wire in a charging light for the alternator? If not, it won't charge.
MadMikeyL is online now
post #9 of 27 (permalink) Old 04-05-2017, 11:03 AM Thread Starter
Yep, definitely. It's the red light in the lower left corner. The other light is the check engine light. I also discovered that even though I don't want the Door Ajar light, I need it in order for it to turn off the courtesy lights.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #10 of 27 (permalink) Old 04-05-2017, 03:12 PM
OK, I didn't even look at the colors of those lights, and was just assuming they were the turn signals. But given that they aren't, did you put lights somewhere for those? If not, do your blinkers signal fast like a bulb is out?
post #11 of 27 (permalink) Old 04-05-2017, 04:08 PM Thread Starter
Well, the turn signals and high beam indicator are integrated into the speedometer. However, you may be onto something that I'm missing. I have wired a light from Painless wiring into the circuit (GY/Y-687 on one leg and LG/R-904) on the other leg of the light as per my EVTM. However, when I start the car and run it the light stays on and isn't charging. I don't have the Check Gauges light wired in but I'm suspicious that I would need to do that. However, now that I'm looking closer at the EVTM, it appears that I need to wire in a 500ohm resistor across the legs of the light. Does that sound right?
FRPP 42# injectors
3.73 gears
OMGHI2U
post #12 of 27 (permalink) Old 04-05-2017, 04:28 PM
So when are you going to start making these for us for a handsome fee?
CDsDontBurn likes this.
Black '96 TBird - Dynotech 3.5" MMX DS, SCP mounts and brackets, Art Carr 4R70W transmission, DirtyDog 2800 stall TC, true dual exhaust w/FlowMonster mufflers
lurch is offline
post #13 of 27 (permalink) Old 04-05-2017, 04:45 PM Thread Starter
Long answer: This was a pretty hack job. I made the plate with a miter saw, angle grinder and a drill press with a circle cutter. I made spacers out of square steel tubing to bring the plate forward enough to more or less conform to the front trim piece. The plate is covered with a vinyl, carbon fiber looking, self-adhesive sheet. It definitely looks better than it is. It works though.
Short answer: not any time soon.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #14 of 27 (permalink) Old 04-05-2017, 05:08 PM
In theory, it should work without the resistor. That is just there so that if the bulb burns out, it still makes the connection and still charges. Are those lights LEDs? If so, it might be wired backwards, which would prevent voltage from going through it and to the alternator.
post #15 of 27 (permalink) Old 04-05-2017, 05:09 PM
did you have the option gauge light color on the gauges. This makes me want to do one a metal with a Damascus pattern in it.
post #16 of 27 (permalink) Old 04-05-2017, 05:17 PM Thread Starter
I bought this: Painless 80209
It didn't come with any instructions and I generally can't find any specific details or instructions for it. All indications are that it's LED. However, the two wires are the same color. I guess I can swap the wires.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #17 of 27 (permalink) Old 04-05-2017, 05:39 PM
Leds draw a lot less current than a bulb, so that's the deal if it's not charging. If the led is lit, it's in right.
IIRC, at least some of the current that drives the stator flows thru the bulb and the regulator; the output current of the Alternator is proportional to that current; if it draws too much, it lights the light.
I'd probably Solder a bulb across the led leads, out of sight.
A tungsten filament is a variable fuse, kinda.
Cold, it's a low resistance, a few ohms. But once it goes over a certain current, it starts to heat up, and the resistance goes Way up as it starts to glow.
That's why light bulbs blow when you first turn them on, usually; cold, big current, blows like a fuse.
You can buy a new flasher module that won't care about the load vs. flash rate.
It's posted here somewhere in the Exterior forum; I bought one and it plugs straight in and works great.
post #18 of 27 (permalink) Old 04-05-2017, 05:51 PM Thread Starter
Couldn't I just put in a resistor like the EVTM indicates?
FRPP 42# injectors
3.73 gears
OMGHI2U
post #19 of 27 (permalink) Old 04-05-2017, 06:24 PM
Isn't that in addition to the bulb?
Led current its negligible to either the bulb or a 500 ohm resistor, but I believe it needs both.
I think the resistor is if the bulb blows out, for some reason.
Seems like the bulb is about 50 ohms, cold.
It also needs to flow both ways, thinking about it; it will light if Either the battery Or alternator fails.
post #20 of 27 (permalink) Old 04-05-2017, 06:38 PM Thread Starter
OK, that makes sense. Unfortunately it looks like I have two 4.6K ohm resistors and no others on hand. Radio Shack is dead. Dammit.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #21 of 27 (permalink) Old 04-05-2017, 06:58 PM
Use any small, ~5W incandescent bulb, 12V. it will work better than anything else.
Old School is still best sometimes.
I have a signal generator that uses a lamp in the feedback loop; it's stable as hell.
post #22 of 27 (permalink) Old 04-05-2017, 07:00 PM Thread Starter
Well, I ordered some 500 ohm resistors. I don't have any bulbs like that just lying around.
Edited to say that I slept on the issue and it turns out that, in my later evening grogginess apparently, I confused GY/R with LG/R thinking they were both gray instead of one being gray and one being light green. I have corrected the wiring and all is well. I still need to install the resistor but this part is all set now.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #23 of 27 (permalink) Old 04-05-2017, 09:30 PM
Top notch job. Can't think of any reason 4.6k ohm resistor wouldn't be fine. Still learning these cars however.
Creighton
post #24 of 27 (permalink) Old 04-07-2017, 08:32 PM Thread Starter
OK, it's all set. The charge light is properly wired including the 500ohm resistor. The proper sending units for oil pressure and coolant temp are in place and all of the gauges that are supposed to work do work. I haven't calibrated the speedometer yet but I hope to do that tomorrow.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #25 of 27 (permalink) Old 04-09-2017, 08:41 PM
CDsDontBurn's Avatar
Try SuperBright LEDs
CDsDontBurn is offline
post #26 of 27 (permalink) Old 04-10-2017, 03:26 PM
Really nice-looking installation. Congrats!
MikeB
1997 Thunderbird Sport
5.0L-2V NPI S/C
375 RWHP / 416 RWTQ
11.959 @ 117.17 MPH
MikeB is offline
post #27 of 27 (permalink) Old 04-12-2017, 07:09 AM
Rayo's Avatar
Good Job!
That compliments your Interior nicely..
1991 Ford Thunderbird Sport
Rayo is offline
