Floor mat templates - TCCoA Forums
 1Likes
  • 1 Post By Creighton
post #1 of 19 (permalink) Old 04-18-2017, 07:13 AM Thread Starter
Andy625UK's Avatar
Floor mat templates
Finally managed to try out my mat templates. I found a website a while back that had an outline drawing of fitted mats. So I drew round the outline on the CAD at work, and printed them out full size.
Passenger side looks good, but the drivers side has a weird cut out on the top right corner beneath the gas pedal. Not sure if this is quite right - what do you guys think?
"...put me on a highway, show me a sign, and take it to the limit one more time"
The Eagles
1975
http://www.cardomain.com/ride/2149821
RIP Dutch T-Bird (Robert Hendriks) 1970-2012 No doubt looking down on us from his low-riding T-Bird in the sky.
Andy625UK is offline
post #2 of 19 (permalink) Old 04-18-2017, 07:20 AM
Natesriv's Avatar
paper is a bad material for floor mats!
Ha!!!
I'd extend the driver's upper right. That's a complex curve so you may have to put in a notch there. If you plan to sew around the perimeter, then that notch can be all sewed perimeter...
Natesriv is offline
post #3 of 19 (permalink) Old 04-18-2017, 07:39 AM Thread Starter
Andy625UK's Avatar
I agree that the drivers side needs to be longer. I think the notch top right is to go behind the gas pedal, but it seems too low down at the moment.
This is the picture I drew round. Unfortunately I can't remember which website I found it on now, but they were definitely tailored mats for our cars.
The Eagles
1975
post #4 of 19 (permalink) Old 04-18-2017, 08:28 AM
Natesriv's Avatar
Natesriv is offline
post #5 of 19 (permalink) Old 04-18-2017, 08:40 AM Thread Starter
Andy625UK's Avatar
Aha, that looks like the website I copied the picture from. Yours should be exactly the same shape then, in theory.
Has your drivers side mat got the same notch in the top right underneath the gas pedal??
The Eagles
1975
post #6 of 19 (permalink) Old 04-18-2017, 10:24 AM
Natesriv's Avatar
I'll have to check when I leave work.
here's the link to my build page
My Bird - Stage 1
pics in there of the mats.
Natesriv is offline
post #7 of 19 (permalink) Old 04-18-2017, 10:55 AM
Seasoned Geek
Andy I remember sending you pics of floor maps from my bird .
post #8 of 19 (permalink) Old 04-18-2017, 11:04 AM Thread Starter
Andy625UK's Avatar
Yes, thanks very much for that. They were very helpful when it came to working out the scale for my drawing. I also noticed that the pictures of the original type mats you had, seemed to show a notch on the drivers side, but your new mats don't have it. Does it seem to make any difference in the fit?
I guess it makes sense to trim the mat back around the pivot point of the gas pedal, but on my template it seems to be miles away from the pedal(or the template is too short).
The Eagles
1975
post #9 of 19 (permalink) Old 04-18-2017, 05:42 PM
Here is an original 95 driver side mat. Need dimensions or a template mailed let me know. Hope your project goes well.
Creighton
CDsDontBurn likes this.
Just keeping the history on the road.
Creighton is offline
post #10 of 19 (permalink) Old 04-18-2017, 11:55 PM Thread Starter
Andy625UK's Avatar
Thanks Creighton, that's very interesting, yours has the notch too.
Could you possibly give me an overall length from top to bottom (pedal end to seat end), so I can check the scale?
The Eagles
1975
post #11 of 19 (permalink) Old 04-19-2017, 07:55 AM
Natesriv's Avatar
Darn, mine doesn't have that hole to hold it in place.
Natesriv is offline
post #12 of 19 (permalink) Old 04-19-2017, 11:36 AM
Sure. 28"
Creighton
post #13 of 19 (permalink) Old 04-19-2017, 04:32 PM Thread Starter
Andy625UK's Avatar
Thanks. My template measures about right, so I can't be far out. I'll check the drawing again tomorrow when I get to work.
The Eagles
1975
post #14 of 19 (permalink) Old 04-19-2017, 06:36 PM
Here are more dimensions:
15" across at widest point. Notch starts 6 1/4" from top.
Mounting hole center 2 1/4" from side 2" from bottom.
Sorry the Metric tape is hiding:-)
Need anything else just let me know.
Creighton
post #15 of 19 (permalink) Old 04-20-2017, 04:36 AM Thread Starter
Andy625UK's Avatar
Creighton
Thanks, that's very helpful. (I didn't even know you had metric tapes over there!) I'll update my sketch, print out another "mat" full size and see how it looks. It's interesting the subtle differences between the factory ones and the custom ones Boston-Bull sent me pictures of.
The Eagles
1975
post #16 of 19 (permalink) Old 04-26-2017, 09:55 AM
It seems rare to find the retaining clip hole in aftermarkets, even customs.
I ordered a brand new pair of 96-97 mats on eBay, double-checking with assurance from the seller that they were the saddle colored ones. The seller even put a label on the top with the correct Ford part number after checking them. Nope! Seller must be color blind, because I opened the box to find gray ones instead. After numerous attempts to find OEM saddle ones, I've given up.
Most custom aftermarkets are pricey. Some have fine serging surround and the manu will even embroider your choice of logo. Then there are the various piles, materials, etc.
Are you attempting to achieve the same results as custom aftermarkets but on a budget? I have the '96 OEM's if they differ from the '95's and you want measurements.
At this point, with mechanical probs needing taken care of on my Bird, I'm reluctant to dump a lot of cash into custom mats. Too bad nobody sells just the driver's side, because my passenger side looks almost new -- the driver's side is worn down to the rubber where my accelerator heel rests/pivots, and is long overdue to be replaced.
I've been considering just using clear vinyl aftermarkets, perhaps oversized & cut to fit.
What do y'all think about the clearies? They're cheap and easily cleaned. If they get stained or damaged, they're inexpensive enough to discard and replace w/o much heartache.
How about cutting to fit an alternative, say an office chair carpet protector? They have spikes to keep them in place. These are available in non-rigid material as well, so perhaps they could conform, this stuff is even available by the yard off a roll.
Torque is offline
post #17 of 19 (permalink) Old 04-27-2017, 04:47 AM Thread Starter
Andy625UK's Avatar
Yes, that is what I was trying to do, mainly because of the cost of getting new ones shipped over here to the UK. Thanks for the offer of measurements, however I think I have all the measurements I need.
I updated my pattern with the dimensions including the exact position of the hold-down hole. When I drew round the photo on the cad, the scale of my original was pretty close. However when I put the template in the footwell on the hold-down hole, it pushed the mat into what seemed like completely the wrong position.
I put the mat into what seems like the position in should be in, and re-marked the hold down hole. I've also decided to dispense with the notch under the gas pedal, as it doesn't seem to do anything apart from expose a chunk of carpet that could get dirty. I don't understand why they put it there as the floor doesn't have a pronounced bulge in it there or anything that would make a squared off mat not sit right.
Maybe either Ford aren't very good at designing mats, or they did them on a Friday afternoon.
I'll post pictures of my templates when I've finished tweaking them.
The Eagles
1975
post #18 of 19 (permalink) Old 04-27-2017, 08:25 AM
Must be a liability issue. They must have discovered in R&D or real world feedback (from other models, perhaps?) that there could be eventual problems with curling or lifting, leading to interference with (or worse, binding of) the pedal, which would be an unsafe situation. At best, it would be highly distracting to the driver, who may take their eyes off the road while attempting to remedy it.
Torque is offline
post #19 of 19 (permalink) Old 04-27-2017, 05:15 PM
1995 cougar xr7's Avatar
Every pair of floor mats I have bought for these cars. The only issues I have are the rear mats. Only the factory ones are cut out correctly the aftermarket ones never cut the 2 notches out
1995 cougar xr7 is offline
