Ambient Air Temp Sensor - TCCoA Forums
post #1 of 3 (permalink) Old 05-08-2017, 02:39 PM Thread Starter
My outside air temperature reading is very slow to update. If I park it in a hot parking lot, it will take 20 or 30 minutes to update to the proper temperature. Yesterday, I parked it when the outside temperature was in the 50s. When I got back in to the car the temp was in the mid 80s. I drove nearly 50 miles before it had updated to the proper temperature. I this just the nature of the system, or is something going south, and needs to be replaced?
ThunderbirdLX is offline
post #2 of 3 (permalink) Old 05-08-2017, 03:30 PM
The 2nd temperature sensor is in the cabin, and is a reference to the one out front, behind the grill.
When the inside temp is hot, or cold, it will read funny until the cabin goes to ~40-80 degrees, then will work normally.
It's inside the satc unit, so it's more insulated than the cabin, so it takes a bit.
The sun beaming on the dash makes it worse.
post #3 of 3 (permalink) Old 05-09-2017, 03:27 PM Thread Starter
OK That makes sense. It's a black car that lives in Texas. The interior does get hot.
Thanks for your expertise!
