HELP!!! Anyone know where I can find - TCCoA Forums
 1Likes
  • 1 Post By MadMikeyL
post #1 of 3 (permalink) Old 06-18-2017, 06:47 AM Thread Starter
Mr.Thunderbird's Avatar
Anyone know where I can find a passengers side window regulator (NEW). 1995 ford thunderbird.
Had the glass guys here from Novus to replace the motor. On initial inspection he found the motor working and says I need a new regulator. So far none of my online searches have brought me anything but the gears required. Anybody know a source? Thanks
Mr.Thunderbird
Mr.Thunderbird is offline
post #2 of 3 (permalink) Old 06-18-2017, 07:09 AM
I highly doubt you need a new regulator. Most likely the plastic pegs inside the motor are broken. See if you can move the glass manually. If you can, then that is your problem.
T6Rocket likes this.
post #3 of 3 (permalink) Old 06-18-2017, 10:16 AM
Rayo's Avatar
The Ford Part Number is: (F4SZ-6323208-A) or (F4SZ6323208A)
Unfortunately it has been discontinued, but you might be able to find a NOS one online..
It looks like the aftermarket never made these for the MN12 either..
If it really is damaged, you're only choice is finding a good used one..
1994-1995 MN12 Window Regulators are the same..I can't confirm if any other year of Window Regulator will work..
1991 Ford Thunderbird Sport
Rayo is offline
