High Output Alternator Upgrade for Cheap - Page 3 - TCCoA Forums
post #61 of 66 (permalink) Old 09-17-2014, 07:22 AM
Well, his new one is a higher output than his old one was ... *grins*
Fuelly
RalphP is offline
post #62 of 66 (permalink) Old 09-17-2014, 09:15 AM
Tbird Bob's Avatar
Originally Posted by guitar maestro View Post
So you got a mitsu HO alt? That's what this thread is about
I do have a high output Mitsu alt in my tractor.
Tbird Bob is offline
post #63 of 66 (permalink) Old 09-17-2014, 09:07 PM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #64 of 66 (permalink) Old 09-17-2014, 10:29 PM
Tbird Bob's Avatar
lol..
Off topic, but if anyone is ever considering the purchase of a Japanese built tractor, Mitsubishi has a reputation for quality built tractors.
post #65 of 66 (permalink) Old 07-26-2015, 01:54 PM
I bought this project, and am looking it over.
This pwm board is way too complicated for what it's doing; I'm going to look into making this also a pic programming project.
I also want a 100A PWM controller for my M8 fan, so... multipurpose use is in order.
BTW, here's a link to the OG article from P71; I hope it's with permission.
http://www.pantherbb.com/p71intercep...ade/index.html
My idea is:
The GEN-MON signal is an output of what the alt it doing; that needs to be read, compared with temperature, and then a proper output duty cycle should be output to the Alt on the GEN-COM line.
The connector for this Alt is the WPT-118, which also happens to be the same as the TPS sensor. Most of us have a spare harness laying around, so the $40 pigtail isn't required. It's low current, so don't worry about these.
Repeated output high current pulses should trigger a "hardcore" mode, where it bumps it up a bit, and monitors over a longer period before adjusting; I've had amps fool a regulator before, to the point the battery slowly discharged... Vavg is less than Vrms.
I think a battery temperature monitor input would be a cool feature.
A WFO mode might be nice for the guys who need full output; although, if your amps aren't pulling that much, your battery is going to boil and explode, lol. The temperature monitor could help that.
And you need like ~2500 rpm minimum to get full current. And a bigger radiator and fan, lol.
This now reads more like a self destruct switch for noobs, lol.
Anyone else have any ideas on a controller for a charging system?
post #66 of 66 (permalink) Old 07-26-2015, 05:30 PM
That makes sense to me, Grog.
Fuelly
RalphP is offline
