"Slow" outside air temperature sensor? - TCCoA Forums
 12Likes
  • 2 Post By RalphP
  • 2 Post By XR7-4.6
  • 1 Post By theterminator93
  • 1 Post By rushtonracing
  • 1 Post By Grog6
  • 1 Post By CDsDontBurn
  • 1 Post By Woodman
post #1 of 22 (permalink) Old 02-20-2016, 05:19 PM Thread Starter
Woodman's Avatar
I have the SATC in my 1997 Thunderbird, and last weekend it was -12 here in MN. Today, it's 38 degrees outside. I pushed the Outside Temp button on the SATC and what did it say? -6! As I drove around on a few errands, it finally made it's way up to 6 above, and seemed to be very slowly climbing up to actual temp, but my question is this...
Is the sensor going bad? How big a deal is it to replace? Does the sensor affect engine function at all?
Woodman is offline
post #2 of 22 (permalink) Old 02-20-2016, 06:22 PM
In sequence -
1) Probably, unless the air in front of the condensor / radiator is actually that cold.
2) I haven't replaced one, but it's on the bottom rail in front of the condensor on the passenger side. If you can get your hand up / down there, should be easy. MIGHT need to pull the bumper cover to get to it, though.
3) Nope, not anywhere near connected.
Woodman and CDsDontBurn like this.
Fuelly
RalphP is offline
post #3 of 22 (permalink) Old 02-20-2016, 06:36 PM
Slightly Disjointed
Actually it's dead center right below the hood latch bracket, the bracket bolt is accessible from the top and the sensor/bracket can come out underneath.
post #4 of 22 (permalink) Old 02-20-2016, 07:27 PM Thread Starter
Woodman's Avatar
Thanks guys.
I can attest, it has been in the high 30's, low 40's the last couple of days. Supposed to be warm tomorrow and all through the week.
I haven't driven into any snowbanks, can't think of any reason the ambient outside air would be -6 just around my car when everywhere else it's warmer.
Woodman is offline
post #5 of 22 (permalink) Old 02-20-2016, 08:55 PM
Mine does similar nonsense. It's like it "remembers" the last temperature it was sensing then slowly changes to get down (or up) to the current temperature.
Woodman likes this.
97 Laser Red Thunderbird LX 155k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
96 Ivory Mark VIII 230k, stock 4.6 32v on coils; New engine at 185k
post #6 of 22 (permalink) Old 02-20-2016, 09:01 PM Thread Starter
Woodman's Avatar
Mine has done that since I got the car. It "remembers" the temp inside my garage usually for the first few miles, but I've never had it remain 30 degrees off of actual like that.
I'll look into a replacement.
Woodman is offline
post #7 of 22 (permalink) Old 02-20-2016, 09:06 PM Thread Starter
Woodman's Avatar
Speaking of which, what actual part is it?
I highly doubt it's the outside air temperature/charge sensor as that's in the intake.
Is it the ambient air temperature sensor?
http://www.rockauto.com/en/moreinfo....sn=581&jsn=581
Woodman is offline
post #8 of 22 (permalink) Old 02-20-2016, 09:11 PM
I tried finding it a few years ago. Not available new anymore IIRC. Different part than the IAT sensor.
I ended up getting a used one off here to install... but lost it before I did.
Woodman likes this.
post #9 of 22 (permalink) Old 02-20-2016, 09:14 PM Thread Starter
Woodman's Avatar
I know that the IAT goes in the intake. The one I found on rock auto is an ambient air temp sensor, sounds like it would be the one. I'm tempted to go out to the garage to look.
Woodman is offline
post #10 of 22 (permalink) Old 02-20-2016, 09:25 PM
TX12? Yup, that's the one. Darn, I need to get one now.
Woodman likes this.
post #11 of 22 (permalink) Old 02-21-2016, 09:36 AM
rushtonracing's Avatar
Woodman likes this.
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #12 of 22 (permalink) Old 02-21-2016, 10:07 AM Thread Starter
Woodman's Avatar
Originally Posted by rushtonracing View Post
Excellent, thank you!
Woodman is offline
post #13 of 22 (permalink) Old 02-21-2016, 06:13 PM
You're welcome. I took that photo quite some time ago when I had the front bumper cover removed.
2004 Tahoe 5.3 4x4
post #14 of 22 (permalink) Old 02-21-2016, 06:17 PM Thread Starter
Woodman's Avatar
Thankfully I am dexterous enough to unbolt it, fish it out, unplug it, re-plug it, and fish it back in and re-bolt it up. Not too hard to get to from the top of the car.
Anyhow, even though it's 28 out, it still thinks it's 9 out after leaving it unplugged long enough to discharge. So, a new one is on it's way.
Thanks again for the detailed view. the description from earlier also was very helpful.
Woodman is offline
post #15 of 22 (permalink) Old 02-21-2016, 08:29 PM
BTW, All temperature sensors depend on the EEC being at "normal" temperature. (EEC or other brain box)
They use the EEC local temperature as the "cold reference junction", which is a diode these days.
If the eec is really hot of cold, you get strange readings until everything stabilizes.
Woodman likes this.
post #16 of 22 (permalink) Old 02-28-2016, 03:06 PM Thread Starter
Woodman's Avatar
Well I replaced the IATC this afternoon, seems to be working just fine now. Next up is the auto-down mod on the windows, along with replacing the pucks in the regulator.
Woodman is offline
post #17 of 22 (permalink) Old 03-22-2016, 09:20 AM
CDsDontBurn's Avatar
I was looking at this over the weekend, but I couldn't figure out where it's located. I know it's behind the bumper cover, but short of removing it, how do I even get to it? @Woodman , you got to it from the top side, and fished it through, but I looked through the top side between the bumper and was unable to even identify it's exact location.
Woodman likes this.
CDsDontBurn is offline
post #18 of 22 (permalink) Old 03-22-2016, 11:15 AM Thread Starter
Woodman's Avatar
I'll take some pictures from the front of the car. It's mounted to the front of the radiator support, directly underneath the hood retention latch (not the release, the hook that holds the hood down) just slightly left of center on the front of the radiator support.
CDsDontBurn likes this.
Woodman is offline
post #19 of 22 (permalink) Old 03-22-2016, 05:41 PM Thread Starter
Woodman's Avatar
Here it is, just on the left, on the little bracket with just one bolt.
Woodman is offline
post #20 of 22 (permalink) Old 03-22-2016, 06:12 PM
Oh. That seems somewhat easy to get to then. I'll take a look at this again.....probably tomorrow. I'm driving the wife's Taurus today .
Woodman likes this.
post #21 of 22 (permalink) Old 03-22-2016, 06:38 PM Thread Starter
Woodman's Avatar
I didn't have trouble. Unbolt it, fish it out by it's cable, replace it, then fish it back in.
Woodman is offline
post #22 of 22 (permalink) Old 03-22-2016, 06:40 PM
Dude; wash all that salt off!!!
