"BAD" radio code - TCCoA Forums
post #1 of 12 (permalink) Old 02-09-2017, 01:56 PM Thread Starter
30thAnniversaryCat's Avatar
"BAD" radio code
Has anyone seen this code? I turned on my radio today (original Factory Premium Sound system), and that code showed up in the window where the station number usually is. The power antenna goes up and down just fine, but there is no sound. There has been no prior trouble with the radio. Is there a reset sequence?
Any help appreciated.
30thAnniversaryCat is offline
post #2 of 12 (permalink) Old 02-09-2017, 03:54 PM
Slightly Disjointed
I didn't even know these radios threw trouble codes. Cassette or CD?
post #3 of 12 (permalink) Old 02-09-2017, 05:21 PM Thread Starter
Me, neither. Cassette
post #4 of 12 (permalink) Old 02-09-2017, 05:52 PM
Post a pic; I may have one.
Is that the one with the amp?
Edit; reading some posts, you should disconnect the battery for a while, and see if it resets.
It apparently overheated.
post #5 of 12 (permalink) Old 02-09-2017, 05:55 PM
Natesriv's Avatar
too bad you're so far away, you can just have mine, pristine....
Natesriv is online now
post #6 of 12 (permalink) Old 02-09-2017, 07:54 PM
Tbird Bob's Avatar
My premium sound CD player took a dump. It decided to eject a non existent disc, even when power to the head unit was off. I'd be driving along with the radio off, and all of a sudden it started: clacka ta clacka ta clacka ta; and the only way to stop it was to disconnect it. But, sometimes it would stop on its own, and continue working normally for a while.
Tbird Bob is offline
post #7 of 12 (permalink) Old 02-09-2017, 08:12 PM
Thunderstruck95's Avatar
I know that the factory radios can be rebuilt. The CD player in my car was serviced before I got it, and this may be another source for rebuilding-
JBL RADIO/CD PLAYER RESTORATION
1995 T-Bird. PI 4.6. Bullitt intake. Big MHS cams. 4,200 Dirty Dogg converter. Kooks headers. Full exhaust. 4" Drive Shaft. 4:10s.
Waiting on a tune.
1997 Lincoln Mark VIII FX2 Sand Dune Machine.
Thunderstruck95 is offline
post #8 of 12 (permalink) Old 02-10-2017, 12:15 PM
baylensman's Avatar
Send a message via AIM to baylensman
HOPE THIS HELPS FOUND IT ON AND EXPLORER FORUM
The Ford DIN CD Radio uses the error message "BAD" in the display for a couple different conditions. One is for a "bad CD" which could be scratched or so dirty that the laser cannot read it. For this, trying a different disc should tell you if that was it. The other condition is if the radio has been operated at high volume and high temperature. The CD mechanism has internal protection schemes to shut itself down if too high an internal temperature has been reached. If it does not work after a reasonable "cool-down" period, try disconnecting the vehicle battery cables, and then re-connecting. If that does not reset it, it will have to be removed for repair.
i'd rather go slow than not go at all
1996 MKVIII air ride delete
2007 Royal star venture (loaded)
2007 Ford free style 3.0 v-6
baylensman is offline
post #9 of 12 (permalink) Old 02-10-2017, 02:52 PM Thread Starter
OK, here's an update:
Tried inserting a cassette (no good reason) to see what would happen. It got stuck in the cassette bay and wouldn't eject. I finally got it freed and ejected, and the radio then started working fine again and still is. There was no way it overheated. Beats the heck outa me!!
Thanks to baylensman for that info, and Natesriv for the offer (if it goes out again, I will take you up on the offer )
post #10 of 12 (permalink) Old 02-10-2017, 07:35 PM
94badbird's Avatar
Where did you find a tape.?😛
I WANT TO TRADE a 75mm throttlebody and exremly ported vic plenum and a set of 24lb injectors FOR a pi intake and alternator bracket and hopefully valleytube and nipple, pm me!!!
94badbird is offline
post #11 of 12 (permalink) Old 02-13-2017, 04:17 PM Thread Starter
was in the pocket of my leisure suit!!
post #12 of 12 (permalink) Old 02-16-2017, 08:25 AM
baylensman's Avatar
