Mark 8 15/16" oil pick up tube - TCCoA Forums
 1Likes
  • 1 Post By racecougar
post #1 of 14 (permalink) Old 02-24-2017, 08:51 AM Thread Starter
Looking for a late model Mark 8 15/16" (big one) oil pick up tube.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------300RWHP est.---------who knows/who cares
10.740@127------------13.842@103.08-------16.1@
BLOWN38 is offline
post #2 of 14 (permalink) Old 02-24-2017, 12:50 PM
jco1385's Avatar
What year model would this be on? Last time out to the yard, someone had pulled the k-member out of a 97/98 Mark so it wouldn't be much to grab the pan and tube if it's what you need. I don't know much of anything about the Lincoln drivetrain.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #3 of 14 (permalink) Old 02-24-2017, 10:26 PM
The larger tube actually didn't appear until the '96 MY.
rodsv6cougar@cs.com
post #4 of 14 (permalink) Old 02-25-2017, 08:02 AM
We're talking about two different tubes here. The larger Mark VIII tube for the "HO" pump is p/n F6LE-6622-AA. Again, it first appeared in '96 MY Mark VIII's.
rodsv6cougar@cs.com
post #5 of 14 (permalink) Old 02-25-2017, 01:10 PM
Rayo's Avatar
Yeah, you're probably right..You're not the first person who I've heard say that either..
The strange thing is, F6LE-6622-AA is an engineering number..Not a Ford Part Number..
Still, the F6 suggests Ford started using that oil pick up tube in 96..
1991 Ford Thunderbird Sport
Rayo is offline
post #6 of 14 (permalink) Old 02-25-2017, 02:02 PM
Slightly Disjointed
Looks like every part number I'm familiar with
F=199x
6=xxx6
L=Lincoln Mark
E=Engine
6622=Pickup tube
AA=Revisions
post #7 of 14 (permalink) Old 02-25-2017, 03:10 PM
Rayo's Avatar
The number you see cast into or stamped on a part is not a Ford part number. Strange, huh?
This is known as a casting number or engineering number, not a Ford part number.
It may be close to the actual part number but is never the same as a Ford part number.
These numbers were used in the manufacturing of the part, and that is a completely different story,
although the engineering numbers follow the same type of numbering system and format.
Codes, basic part numbers, and suffix are different for casting numbers.
Rayo is offline
post #8 of 14 (permalink) Old 02-27-2017, 09:00 AM Thread Starter
Thanks for the clarification, guys. I wasn't exactly sure what year they started with the big one. Are the pans the same for the bigger tube?
Jco, sounds like that should be the correct pickup. I only need the pick up as long as the pans are the same.
BLOWN38 is offline
post #9 of 14 (permalink) Old 02-27-2017, 06:16 PM
The pan was revised with a better rail in the Gen II's, but either will work with either tube. To be clear, any of the 4.6L MN12 or FN10 pans will work.
CDsDontBurn likes this.
rodsv6cougar@cs.com
post #10 of 14 (permalink) Old 03-03-2017, 09:49 AM Thread Starter
Bump if someone is going to the yards this weekend.
BLOWN38 is offline
post #11 of 14 (permalink) Old 03-03-2017, 11:49 AM
jco1385's Avatar
I haven't been out there again since I posted here. I'm going right by there in the morning so I will stop and see if I can get this for you. You only want the tube, correct?
jco1385 is offline
post #12 of 14 (permalink) Old 03-06-2017, 07:37 AM
jco1385's Avatar
No luck. Someone pulled the engine before I got back to it.
jco1385 is offline
post #13 of 14 (permalink) Old 03-06-2017, 09:21 AM Thread Starter
Thanks for looking.
BLOWN38 is offline
post #14 of 14 (permalink) Old 03-08-2017, 08:21 AM Thread Starter
I think I found one. Hopefully when it shows up it is correct.
BLOWN38 is offline
