Traction-Lok Needed - TCCoA Forums
 1Likes
  • 1 Post By T6Rocket
post #1 of 8 (permalink) Old 04-30-2017, 03:36 PM Thread Starter
97Tbird4.6's Avatar
Traction-Lok Needed
My current differential makes noise. I have an open 8.8" differential with factory 3.27 gears out of a 1996 V8 Thunderbird. Looking to get this rebuilt and change to 3.73 gears. I need a traction-lok unit to complete this project.
87 octane tune by Randy Fastmann Racing, 2002 Mustang GT 80mm MAF, air tube and PI intake manifold, 70mm FRPP throttle body, Trick Flow plenum and under drive pulleys, Comp Cams, mandrel bent 2.5" exhaust w/cats into a Dynomax catback w/turbo mufflers, Jmod w/15k cooler, 3000 stall 10" converter, Dynotech 3.5" aluminum driveshaft, FRPP 3.73 trac lock, 235/55ZR17 Falken Ziex ZE950 on Sport Edition F7 rims, Tokico blues, Vogtland 1.6" drop.
I turn my own wrenches.
97Tbird4.6 is offline
post #2 of 8 (permalink) Old 04-30-2017, 09:15 PM
Woodman's Avatar
Supercoupeperformance.com has them still available for our differentials.
A non IRS TL unit can be adapted to fit if you machine the ends of it.
Woodman is offline
post #3 of 8 (permalink) Old 05-01-2017, 09:21 AM
T6Rocket's Avatar
I still got this one for sale:
28 Spline Used Trak-Lok
Al
Woodman likes this.
97 T-Bird LX 4.6 - 68k miles
Previous cars:
T6Rocket is offline
post #4 of 8 (permalink) Old 05-01-2017, 03:41 PM
Try this!
post #5 of 8 (permalink) Old 05-01-2017, 05:55 PM Thread Starter
97Tbird4.6's Avatar
Thanks for the help guys. I just got a call from my rebuild guy, he found a traction-lok for me already. No more searching for parts for me.
post #6 of 8 (permalink) Old 05-02-2017, 07:42 AM
T6Rocket's Avatar
Make sure it's for an IRS rear, or the axles won't snap fully in place. Since there were far more Mustangs with Trak-lok than T-Birds, it's a high probability it's for a solid axle.
The differences are outlined in my link above. You can have that groove and taper machined into the Mustang Trak-lok to make it work in the IRS rear.
Al
Previous cars:
T6Rocket is offline
post #7 of 8 (permalink) Old 05-02-2017, 11:57 AM
Actually, I thought they would snap in place......it would just be a bitch to get them back out.
post #8 of 8 (permalink) Old 05-02-2017, 01:29 PM
T6Rocket's Avatar
Rob claims they won't, and he has done them for people before. They didn't care, at the time at least!
But I guess if you try hard enough, anything is possible! If that snap ring gets past that sharp edge, that could be really ugly getting it back out. Especially once the snap ring gets a little bent up.
Al
Previous cars:
T6Rocket is offline
