Cougar Ghost Lights - TCCoA Forums
 1Likes
  • 1 Post By RalphP
post #1 of 6 (permalink) Old 04-01-2017, 09:01 PM Thread Starter
Cougar Ghost Lights
I put a set into Sweetie's 1991 Cougar XR7 today (while replacing the door panel, replacing the head unit, and replacing the console cover - 'twas a busy day for me today.)
Here's what it looks like at dusk.
Natesriv likes this.
Fuelly
RalphP is offline
post #2 of 6 (permalink) Old 04-12-2017, 04:26 AM
Rayo's Avatar
Good stuff Ralph..
What all is involved in doing that?
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 6 (permalink) Old 04-12-2017, 07:34 AM Thread Starter
Originally Posted by Rayo View Post
Good stuff Ralph..
One hole, drilled with the included hole saw, in the bottom of the door.
Since I had the courtesy lights, I could expose some wire going to said courtesy light, solder the wire from the ghost light to the courtesy light wiring, and used Scotch brand electrical tape to reseal. (Better would have been to use heat shrink, but I was lazy.)
I carefully ran the wiring, and adjusted for location, before I drilled the hole. Even so, the window barely touches the barrel inside the door; not enough to cause problems, but if I had moved 1/16" closer to the inside, the NUT would not have fit, so it's just about perfect in/out.
I lined it up with the hole that the wiring went through the inner door for a location; that fit and worked for me.
I've not found any internal mount ones for a T-Bird yet; but the Cougar ones seem to work great.
One side note: As I open the door, I still reach down "to grab that piece of paper that blew out on me" *grins*
Fuelly
RalphP is offline
post #4 of 6 (permalink) Old 04-12-2017, 10:04 AM
Rayo's Avatar
Thanks Ralph!
Just to clarify..Do you mean the door panel, door mirror, or the actual metal part of the door?
Rayo is offline
post #5 of 6 (permalink) Old 04-12-2017, 10:09 PM Thread Starter
Umm ... Rayo? The "bottom of the door" isn't where the mirror is on MY car. Also, "bottom of the door" <> "door panel".
So, yes, like I said, the actual metal part of the door; hence "the bottom of the door".
*is confuzzled at how 'the bottom of the door' could ever come out as anything else ...*
Fuelly
RalphP is offline
post #6 of 6 (permalink) Old 04-13-2017, 02:13 AM
Rayo's Avatar
LOL
I was hoping you had a typo, as I'm not comfortable drilling holes into the bottom of my doors..Just to install some extra lights..
Thanks for elaborating anyways..
Rayo is offline
