The computer thread! What's your build look like? - Page 5 - TCCoA Forums
 2Likes
post #121 of 202 (permalink) Old 08-20-2014, 06:44 PM Thread Starter
SuperThunderbirdLX's Avatar
Man, I feel bad.
No one even mentioned the 1203.16 MHz (12 * 100.26 MHz) speed reported on that link, lol.
It slows down if it isn't doing much; like browsing.
http://valid.x86.fr/t66dap
This is the OC.
Only 4.1GHz?
WEAK
I have my 3570k clocked at 4.5GHz but only due to temperatures while, once I get The Kraken x60 big boy cooler I'll probably do 4.7/4.8.
Too bad games don't really have support for anything over 4 cores. That's the only think stopping me from a 6 core processor.
-Daniel
http://forums.tccoa.com/30-videos-images/134659-pacific-green-bird-4.html
SuperThunderbirdLX is offline
post #122 of 202 (permalink) Old 08-20-2014, 07:24 PM
Try running this:
http://www.caselab.okstate.edu/resea...benchmark.html
This is what I use for heavy loading.
What's the Frequency, Kenneth? (7.905 is mine, at this oc...)
Grog6 is online now
post #123 of 202 (permalink) Old 02-15-2015, 09:29 PM
Black_Cat's Avatar
Finally 90% Complete and Functional - Black Cat's PC
Well I finally got it 90% completed. Phase 1 is complete, and Phase 2 preparations are underway pending tax return.
System Final Specs:
-16Gb Gskill DDR4 3000 SDRAM (More ram than you can shake a single RAM stick at )
- EVGA X99 Quad-SLi Motherboard LGA 2011v3 Socket
- Intel 5930k Core i7 6 Core 3.5GHz processor
- EVGA 1200 Platinum PSU (93% efficiency)
- Samsung 850 Pro 256Gb SSD (Lightning fast)
- Windows 10 Technical Preview OS
- EVGA Superclocked GTX 980 4Gb Graphics Card
It currently has all of the above minus the graphics card, I am borrowing an ATI POS from a friend, and it's throwing out a ton of heat and doesn't do my system justice lol. But for now it's a means to an end till Phase 2 completes.
Phase 2:
- Liquid Cooling for CPU
- Possible upgrade to an 8 Core Intel 5960X CPU @ 3.0GHz
- Double RAM up to 32Gb (Same stuff I have)
- Swap out the graphics card for the GTX980
I drive an endangered species...they are being crushed at an alarming rate. Please do your part to preserve the Cougar species, and ensure they live on into the future.
1995 Mercury Cougar XR-7 4.6L 2V 5 Speed
1998 Lincoln Mark VIII LSC Collector's Edition Car#94
Black_Cat is offline
post #124 of 202 (permalink) Old 02-16-2015, 12:30 AM
CDsDontBurn's Avatar
Nice Rig! What video card do you have in there now? R9-280, or R9-290?
CDsDontBurn is offline
post #125 of 202 (permalink) Old 02-16-2015, 01:45 AM
Black_Cat's Avatar
Borrowing an XFX ATI radeon hd 4890 1gb, it works, but my pc wants more, and its heat soaking everything around it lol.
post #126 of 202 (permalink) Old 02-16-2015, 11:01 AM
I can't believe you put that together without liquid cooling (yet).
Congrats. You're the first on here (that I know of) to make the transition to DDR4. Although it's got some benefits, from what I've read for the average user there's nothing to be gained. Right now the noticeable benefits of DDR4 over DDR3 are net 0, except that you're forced to use it with the newer CPUs.
DDR4 actually has higher latency rates (are slower) than the best DDR3 chips. Latencies are some where in the neighborhood of 15 to 16 for DDR4 vs 8 to 9 for a good DDR3 chip. It looks like the Gskill DDR4 that you have is at a latency of 15 with numbers of: 15-15-15-35.
I recently did a bit of research into this before upgrading my office laptop from 4GB @ 1600 MHz (11-11-11-28) to 8GB @ 1600 MHz (9-9-9-24)
The Frequency (Bandwidth) to Latency (Speed) relationship is inversely proportional. You sacrifice one for the other. I'd rather have faster RAM with a lower CAS latency than a higher frequency.
To make an apples to apples comparison and measure the true latency you have to convert to nanoseconds, just like the quarter mile time in my sig.
Here's the formula:
(CAS / Frequency (MHz)) × 1000 = X ns
The real Frequency rate is half the listed rate where, for example, 1600 Mhz is really 800 Mhz (1600 is the double in DDR).
For example, I'll compare my 16 GB DDR3 to your 16 GB DDR4.
DDR3 @ 2133 Mhz:
(10 / 1066 ) x 1000 = 9.38 ns
DDR4 @ 2400 Mhz:
(15 / 1200) x 1000 = 12.5 ns
My DDR3 RAM is 3.12 ns faster than your DDR4 ... As I said, net difference is so insignificant as to be near zero.
Here's the bigger difference:
16GB G.Skill DDR4 at 15-15-15-35 sells for $290
16GB Mushkin DDR3 at 10-12-12-28 sells for $77
If you're interested there's some interesting reading here: http://www.tomshardware.com/forum/28...ency-frequency
I'm curious what your previous system specks were? What are you upgrading from?
I'm also curious what you plan to do with all that computing power? Is it a gaming rig? If so what do you play?
I doubt that for other than bragging rights you're going to need more than the 16GB you have now or a CPU with more cores. IMHO you'd be wasting your money to buy more RAM.
Originally Posted by jitpublisher @ Tomsshareware
In the end, you won't won't be able to tell 1 iota of difference in memory speeds. You can see a difference in benchmarks, but not in actual use. DDR memory running at 1333mhz is effectively fast enough than for all but the most severely demanding users. It will never, ever be a bottleneck, at any latencies. When talking about making your PC perform, as far as the RAM goes, just buy decent name brand memory, and enough of it to do what you need to do.
BTW, Nice monitor / small TV. What are your thoughts on Windows 10? I see that Microsoft will offer it for free for a year.
I'm looking to upgrade mine or add a second monitor some time this year. I'm also looking at the same GPU that you mentioned.
Congrats on your new system Ian. Now get some proper cooling on it!
Thanks to Edrick @ http://forums.anandtech.com/showthre...2323770&page=2 for schooling me on RAM.
post #127 of 202 (permalink) Old 02-16-2015, 11:35 AM
CometGSR's Avatar
My rig...
I have a bit of a classic. I have computers that are newer in my house but they really don't hold a candle to my HP Workstation XW9400
It is a dual (x2) AMD Opteron 2220SE Dual Core (so I have quad cores between two CPUs)
16GB of RAM (8GB allocated per processor)
250GB 10K SATA Hard Drive
Nvidia Quadro FX5800
FACTORY liquid cooling
Assembled in 2009
I wouldn't mind changing out the Nvidia with something else but I play Battlefield 2, which is an older game and want to make sure it continues to work.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #128 of 202 (permalink) Old 02-16-2015, 06:17 PM
Black_Cat's Avatar
Here's the formula:
DDR3 @ 2133 Mhz:
DDR4 @ 2400 Mhz:
Thanks Ron, yeah it's a beast alright.
DDR4 is great because it's low voltage, and although the latency is higher on the timings, it's honestly not something you're going to really notice, and with 16Gb it's like being stabbed with a cotton swab, no big deal lol.
Meh no real need for liquid cooling on it as it sits, all the components I have in there right now are top of the line in both performance and efficiency, considering that my RAM is running at 1.25 volts, I could OC it and drop the timings, but it's fast enough for me as is. I really reap the rewards from the processor though, mmm LGA 2011v3 is good stuff. I'll upgrade to liquid cooling if I decide to overclock it, but right now the max I've seen the CPU hit while playing Battlefield 4 and World of Tanks on max was 42C, which is well below my comfort level of 65C, which is inherently below Intel's comfort level of 100C, so for $28 bucks that fan/heatsink combo is paying for itself already, and it's very lightweight, not to mention this case can breathe very well and I have the cables routed for optimum air flow.
It's basically gaming rig right now, but I might try to run some type of server off it in the future like a voice server or something.
Games I play currently:
- Battlefield 4
- Counter Strike Global Offensive
- World of Tanks
- Starcraft II
I'm really excited for the integration that's about to go down on Windows 10 so I can play PC games with XBOX users and vis versa, this is going to revolutionize and revitalize PC gaming again. I can't wait for GTA V to come out on PC in 4K resolution so I can get a 4k TV and burn my eyes from playing it too much lol.
I upgraded from my old gaming rig, I loved that thing but it sold to a good home and I still do regular check-ups and tech support for it The guy is a good friend of mine and owns a 97 sport with 25k miles on it. Anywho here were the specs:
- 8Gb of OCz Reaper RAM 5-5-5-15 (fast enough for ya? ) Had this machine since 2007 till last year.
- EVGA 780i Triple SLi motherboard
- EVGA GTX560 graphics card
- 680W Apevia Iceburg PSU
- Western Digital Velociraptor 10k RPM drive
- Windows 7
- Intel Core2Quad Q6600 Quad-Core processor
PM me if you play any of those and want to frag together.
post #129 of 202 (permalink) Old 02-17-2015, 06:31 PM
You guys make me wish I had the time to game.
TM, you got it spot on with the RAM timing thing. The only time I'd take slower RAM over faster RAM is when I'm getting more RAM and reaping the benefits of having more RAM .
post #130 of 202 (permalink) Old 02-17-2015, 07:52 PM
Post up some benchmarks!!
I personally like Euler3d, but there's a bunch out there.
Grog6 is online now
post #131 of 202 (permalink) Old 02-17-2015, 09:00 PM
CometGSR's Avatar
From what I can tell, this isn't too bad for how old it is.. I am sure people have better systems.
-=James
CometGSR is offline
post #132 of 202 (permalink) Old 02-17-2015, 10:34 PM Thread Starter
Figured I'd run mine. It says 3415mhz but it is at 4.4Ghz
I have a whole battlestation that I need to take a picture of for you guys. I just bought a new case and it's really nice!
-Daniel
post #133 of 202 (permalink) Old 02-18-2015, 12:13 AM
Been using this same build for years now, had to change hard drives, ram, and video card once already though.
Verified NovaBench Score: 1338
Test run on February 18, 2015 at 01:08
Microsoft Windows 7 Home Premium
Intel Intel Core i7 860 2.80GHz running at 2793 MHz
NVIDIA NVIDIA GeForce GTX 650 Ti GPU
8184 MB System RAM (Score: 171)
- RAM Speed: 6992 MB/s
CPU Tests (Score: 607)
- Floating Point Operations/Second: 205384064
- Integer Operations/Second: 633818128
- MD5 Hashes Generated/Second: 827115
Graphics Tests (Score: 501)
- 3D Frames Per Second: 1375
Hardware Tests (Score: 59)
- Primary Partition Capacity: 931 GB
- Drive Write Speed: 126 MB/s
post #134 of 202 (permalink) Old 02-18-2015, 05:14 PM
Novabench looks interesting:
NovaBench Score: 2190
2/18/2015 6:06:01 PM
Microsoft Windows 7 Professional
Intel Core i73930K 3.20GHz @ 4039 MHz
Graphics Card: AMD Radeon HD 7900 Series I have Two of these installed
32708 MB System RAM (Score: 297)
- RAM Speed: 15598 MB/s There are four memory busses running at this speed.
CPU Tests (Score: 1104)
- Floating Point Operations/Second: 310334004
- Integer Operations/Second: 1495766436
- MD5 Hashes Generated/Second: 1398842
Graphics Tests (Score: 738)
- 3D Frames Per Second: 1964
Hardware Tests (Score: 51)
- Primary Partition Capacity: 442 GB
- Drive Write Speed: 198 MB/s
I'll post up a screenshot later.
The processor never went above 55°C...
Grog6 is online now
post #135 of 202 (permalink) Old 02-18-2015, 06:00 PM
Do these count?
Nevermind the hulks not in the photo that I'm currently assembling. P-133 MMX, P-III 750, all for old games...
Can't forget this one!
97 Laser Red Thunderbird LX 155k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
96 Ivory Mark VIII 233k, stock 4.6 32v on coils; New engine at 185k
post #136 of 202 (permalink) Old 02-18-2015, 08:19 PM
Back in Black
ShadowDragon's Avatar
2013 Fusion Hybrid
*SCRAPPED* 1994 LX 4.6 NA 13.6@100mph 236.07RWHP/286.26RWTQ
ShadowDragon is offline
post #137 of 202 (permalink) Old 02-18-2015, 09:34 PM
Nice. SD. I wouldn't expect less from you.
post #138 of 202 (permalink) Old 02-19-2015, 05:29 AM
The i7 47xx chips are just a bit faster, clock for clock.
I just realized I'm only running at 4.1GHz; something changed, lol.
I've got one piece of software that won't run at 4.6GHz; it's a dvd ripper, lol.
Every time I run it it ends up crashing "Due to Overclocking!!"
The bios then cranks it back a notch, and reboots; nicer than the old days.
Grog6 is online now
post #139 of 202 (permalink) Old 02-19-2015, 06:35 AM
Back in Black
I don't think that benchmark can read turbo speed, I got mine to 4.8 with no problems but put it back to 4.6 for constant use because... well.. 4.6.
2013 Fusion Hybrid
post #140 of 202 (permalink) Old 02-19-2015, 11:15 AM
CometGSR's Avatar
Wow... You guys have some fast machines.
-=James
CometGSR is offline
post #141 of 202 (permalink) Old 02-19-2015, 06:44 PM
Nice, lol.
This processor won't clock that high stably; or I haven't found the combo yet.
Did you see this?
Geek Porn...
I may get to build a newer one this year, if there's money for software. Computer is extremely cheap compared to the Software...
Grog6 is online now
post #142 of 202 (permalink) Old 02-20-2015, 07:45 AM
My graphics card is holding my score back ...
post #143 of 202 (permalink) Old 02-20-2015, 10:48 AM Thread Starter
Flawed benchmark.
I just realize I get docked a ton of points because it doesn't factor SLI/Crossfire and I lose a ton of points because my main "harddrive" is only 119gb. When my main storage is 4TB 7200RPM.
Chris's hard drive score spanks all of ours cause he's on a 1TB mechanical hard drive.
My computer works good enough for me. I game on 6.2 Megapixels
-Daniel
post #144 of 202 (permalink) Old 02-20-2015, 10:27 PM
Originally Posted by SuperThunderbirdLX View Post
Flawed benchmark.
It's also a very fast writing 1TB hard drive, this computer is too old for my wife and my own personal needs and hobbies, this computer is getting seriously updated in a few months.
I've outgrown my processor, board and graphics card.
So I'll be replacing the board , i7 5960x 8 core 3.0ghz, 64GB ram, ax1500i power supply, Nvidia quadro k6000 12GB, 2 samsung 1TB SSDs one for each operating platform, 2 wd black 4TB storage drives one for each platform, etc... I feel extremely lazy for not updating a few areas sooner.
post #145 of 202 (permalink) Old 02-21-2015, 08:40 PM
Mgino96tbird46's Avatar
Seagate 600 Series ST240HM000 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD) (For the OS and other computer utilities)
Western Digital 250 GB 7200 RPM HDD for games and other stuff
ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Intel Core i5-3570 Ivy Bridge Quad-Core 3.4GHz (3.8GHz Turbo Boost) LGA 1155 77W Desktop Processor Intel HD Graphics ...
EVGA GeForce 9800GTX+ 512 MB
520W Corsair modular power supply
HEC Blitz Black Steel Edition ATX Mid Tower Computer Chassis Gaming Case w/ Front Blue LED 120mm Fan & Top 120mm ...
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL11D-8GBXL
Microsoft Windows 7 Professional SP1 64-bit - OEM
It's a decent home built system. It runs just about anything I ask it to.
1996 Thunderbird LX. Gone, but not forgotten Oct 1995-March 24 2016
1998 Mustang GT premium. Auto, stock, and slow. Daily beater.
Mgino96tbird46 is offline
post #146 of 202 (permalink) Old 02-21-2015, 08:58 PM Thread Starter
May I ask what you need all that for?
You just listed like a 7000 dollar PC..
-Daniel
post #147 of 202 (permalink) Old 02-21-2015, 09:44 PM
I was thinking the same thing. That's truly a money's no object build...
The quadro k6000 12GB alone is a $4,000 GPU card.
What do you plan to do with it? Run three 55" 4K monitors @ 4K simultaneously? 3D Modeling? Professional animations? CAD work?
Have you considered the TITAN-Z for a mere $3K vs $4K for the Quadro?
post #148 of 202 (permalink) Old 02-21-2015, 11:53 PM
Yes, we know. Her job has been affording for us a lot of opportunities to grow, mentally by going back to school and learning new skills, physically with our house, vehicles, and gun hobbies, health with new benefits we previously could not afford, and peace of mind having real savings, being debt free, and being able to pursue our hiking, camping, fishing, and expedition trail riding hobbies.
We are finally in a decent place in our lives, we are even considering trying to have children in the next year. All of our vehicles need our time to get them where we want them to be, but with my broken wrist I have to wait until after I heal to physically perform the tasks, and after the wedding to get around to them.
We are getting married officially in March on our 8 year anniversary together, some state have considered us common law married by definition already (except the taxes). We are going on vacation up in the mountains for a week to get away from it all.
We run two 65" Mitsubishi DLP TV's, we do some 3D modeling, I do some Cad work, rendering, I also am tinkering with tuning and mapping lately, she does a lot of programming, editing, marketing, and photoshop. And it must do those processes while streaming media as we "watch" tv/news, stream constant audio, etc...
Yes we've been doing a lot lately. Our current machine is being pushed, and hiccups more and more as we grow. We are considering the Titan-Z as well due entirely because of the $1k difference in price.
Well that's the long and short of it, now I'll go back to work.
post #149 of 202 (permalink) Old 02-22-2015, 08:00 AM
That's cool Chris, it sounds like things are really going well for you and your family. Congrats on your upcoming wedding.
That must be amazing computing with two 65" TVs for monitors. That's some serious workspace!
It sounds like you could write a good portion of that build off as a business expense or an un-reimbursed work expense.
post #150 of 202 (permalink) Old 02-22-2015, 09:43 AM
Large monitors are great, until you have to turn your head to focus on every window; it gets worse from there.
I find three or four 24" monitors are better than two large ones; you separate the windows by tasks, and it gets easier.
Playing games on a 65" 3dtv in 3d mode is incredible; but will make most people barf, lol. (alll my friends, anyway. )
Grog6 is online now
