Fastest N/A 2v MN12??? - Page 2 - TCCoA Forums
 1Likes
post #31 of 154 (permalink) Old 11-27-2012, 11:51 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
I think JL and I are the only ones that have ran faster than a 12.50.
JL's car had Comp 270's and 4200 RPM TC. I have the exact same TC ad he did. Our cars are very similar except, cams, displacement and oil pump...
TGJ is offline
post #32 of 154 (permalink) Old 11-28-2012, 05:03 AM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Yes, I remember that yours has run very well too. Yours is NPI? Excellent numbers. I see you also run at higher DA. What is your set up?
Steve
"There's a bad, built NA 4.6L COMING FALL 2017"
Current Elite member of the Halfshaft snapping, Auburn eating, Tranny crunching, Piston Melting, Tire lifting Torque Club.
1MTNCAT is offline
post #33 of 154 (permalink) Old 11-28-2012, 08:58 AM
r429460's Avatar
The fastest is j/l.
Some are trying to get there as well.
Pump gas(e85), N/A.
Power adder = turbo, blower, nitrous only.
My crap box was with all options working.(a/c, p/s)
j/l is running a little higher rpm.
See below.
Quickest N/A Modular MN12.
11.97@ 109.35
3880 lbs. w/driver.
Bradenton Spring Brake Shootout 03/04/2017.
r429460 is offline
post #34 of 154 (permalink) Old 11-28-2012, 09:59 AM
1MTNCAT's Avatar
Originally Posted by r429460 View Post
The fastest is j/l.
Pump gas(e85), N/A.
See below.
Rick and TGJ. Are you all 4.6's????? I know you are 2V. TFS, PI or NPI?
Regardless, still great numbers.
Steve
1MTNCAT is offline
post #35 of 154 (permalink) Old 11-28-2012, 11:11 AM Thread Starter
What is the biggest difference between the npi and pi motors besides the compression.
Was JL motor a complete npi motor or pi heads on a npi bottom end.
97 LX
Motor and trans from 95
Working out the bugs right now.
R.I.P.
1995 Thunderbird LX. Black
BEST MOTOR TIMES
12.76 @ 105
BEST NITROUS
12.12 @ 109 mph
Stuckinkaos07 is offline
post #36 of 154 (permalink) Old 11-28-2012, 11:26 AM
1MTNCAT's Avatar
Justin,
JL's car had Non-PI heads (Non-Performance Improved). I don't know if anyone on here other than K. Danner who likely knows what the true bottom end of the engine was. I know once JL did tell me the NPI heads were fully ported and polished, big cams, Bullitt Intake that was ported by the same place and various other things. He also used a lot of converter and gear.
Besides that he was well into the tuning.
He also told me that he turned a lot of RPM around 68-7000 with it. It was set up very well, he knew how to get every ounce out of the car both driving and tuning, and he had a very good track to run on at HRP to run numbers in good weather. He sure made the combination work whatever the bottom end was.
Steve
1MTNCAT is offline
post #37 of 154 (permalink) Old 11-28-2012, 11:28 AM
There isn't THAT much difference in compression. The NPI engine is about 9.2:1 while the PI is 9.3-9.4:1 depending on what year PI engine.
JL had Renegade Ported NPI heads on an NPI block; I always suspected he had either flat-top or 4v pistons.
He was so fast cause he had a ported Bullitt Intake, aftermarket cams, U/D pullies, CAI, 80mm LMAF, dual exhaust, an awesome tune and to put it to the ground - Jmod, 4000 stall converter, matrix drive-shaft, trac-lok, and I don't know what gears...
Like I said, I don't know what pistons, rear gears, or exhaust headers he ran.
~Rick
TCCoA Sig
post #38 of 154 (permalink) Old 11-28-2012, 11:35 AM
1MTNCAT's Avatar
JL had Renegade NPI heads on an NPI block.
Yeah, he had an NPI block. What was in the NPI Block? What was the build? I don't know and likely neither does anyone else but Kris. You think thats what the compression was on that motor?
Whatever it was it worked!
Steve
1MTNCAT is offline
post #39 of 154 (permalink) Old 11-28-2012, 11:39 AM
Like I said, I suspect he ran either the flat-top 0cc pistons that came in 1999-2004 Navigator 5.4L DOHC or the 2.66cc 4v pistons from the 1993-98 Mark VIII. So the answer to your question about the static compression - heck no I don't think it was stock!
~Rick
TCCoA Sig
post #40 of 154 (permalink) Old 11-28-2012, 11:52 AM
1MTNCAT's Avatar
Like I said, I suspect he ran either the flat-top 0cc pistons that came in 1999-2004 Navigator 5.4L DOHC or the 2.66cc 4v pistons from the 1993-98 Mark VIII. So the answer to your question about the static compression - heck no I don't think it was stock! lol
I agree, that or more and I also suspect it was an aluminum block too! Likely around 12-13.1. Without a doubt he proved if the NPI's were worked they could flow with the PI's.
Steve
1MTNCAT is offline
post #41 of 154 (permalink) Old 11-28-2012, 12:10 PM
I know for a while he was trying to get rid of a set of 93 Mark VIII pistons and rods...
post #42 of 154 (permalink) Old 11-28-2012, 01:20 PM Thread Starter
Ok, so I got everything he had besides the intake and the compression.
Now I got an idea....
97 LX
R.I.P.
BEST MOTOR TIMES
12.76 @ 105
BEST NITROUS
12.12 @ 109 mph
post #43 of 154 (permalink) Old 11-28-2012, 01:41 PM
1MTNCAT's Avatar
You may have and idea but no, you don't!
Steve
1MTNCAT is offline
post #44 of 154 (permalink) Old 11-28-2012, 01:47 PM
ehh, why not?
so you're saying you know what hes thinking? awesome.
what number am i thinking right now?
post #45 of 154 (permalink) Old 11-28-2012, 01:59 PM
1MTNCAT's Avatar
ehh, why not?
He's thinking that is what he needs to get there on JL's numbers. He's not got all JL had by far, at least not yet. Compression, Intake are part of the equation, Cams and block are another issue, tuning ability is another, etc.
You aren't just going to throw pistons and intake on the car and go there is all I'm saying. It's not just that simple. I'm sure at some point someone will get there.
Steve
1MTNCAT is offline
post #46 of 154 (permalink) Old 11-28-2012, 02:30 PM
TGJ
TGJ's Avatar
JL posted what pistons he used, etc...
Congrats MR Langton Making MMFF Sept Issue
JL was running a plastic PI intake recently with a very similar setup to mine...
I am running a 5.0L Big-Bore and here is my build thread
Another Bad *** N/A NPI Modular
My car runs on Shell 91 Octane fuel and shifts at 6500 RPM. I run proper racing wheels and tires, bypass the power steering and remove my sub-box from the trunk as well as the spare tire, jack. I run anywhere between a 1/4 to 1/2 tank of fuel, sometimes less.
TGJ is offline
post #47 of 154 (permalink) Old 11-28-2012, 03:17 PM Thread Starter
I know steve....im just thinkin in my head.
97 LX
R.I.P.
BEST MOTOR TIMES
12.76 @ 105
BEST NITROUS
12.12 @ 109 mph
post #48 of 154 (permalink) Old 11-28-2012, 03:18 PM Thread Starter
Im not worried about your numbers since you have a 4.6 turned it a 5.0
97 LX
R.I.P.
BEST MOTOR TIMES
12.76 @ 105
BEST NITROUS
12.12 @ 109 mph
post #49 of 154 (permalink) Old 11-28-2012, 03:19 PM
1MTNCAT's Avatar
I knew he either sold the bullitt or was trying too! Also his converter I beleive. So there were other plans for sure. That bullitt set up hangs about 38# on the nose.
Again, great numbers & times!
Steve
1MTNCAT is offline
post #50 of 154 (permalink) Old 11-28-2012, 03:28 PM
Also they seemed to have had killer air there that's even hard to get here
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 6.34@109.89
10.11 @ 139.19 best mph
RobertP is offline
post #51 of 154 (permalink) Old 11-28-2012, 03:31 PM
Robert
yep
HRP where we race will have a -1500 to -2000 DA at times.....good freakin air!
will drop your times a couple tenths usually.
post #52 of 154 (permalink) Old 11-28-2012, 06:16 PM
...My car runs on Shell 91 Octane fuel and shifts at 6500 RPM. I run proper racing wheels and tires, bypass the power steering and remove my sub-box from the trunk as well as the spare tire, jack. I run anywhere between a 1/4 to 1/2 tank of fuel, sometimes less.
Ok, so from your post there by JL, that answers the pistons - "Ross flat-top pistons-stock bore" and the headers - "Kooks headers". We still don't know what gears, but I'm thinking 3.73 or 4.10s.
~Rick
TCCoA Sig
post #53 of 154 (permalink) Old 11-28-2012, 06:17 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Yeah, I have always wanted to run at hrp just so I can feel better about my times lol
-Rob
RIP '94 Amber Fire Pearl Metallic Thunderbird on Bullitts 14.56@90.54MPH
96 Sport '02 Explorer PI with ported heads, 90MM LMAF, DirtyDog Marauder TC, Inject tech chip, Jmod, Magnaflow mid-mount with Tru-X core, no cats. Urethane drivers motor mount. HIDs!
Rob is offline
post #54 of 154 (permalink) Old 11-28-2012, 06:28 PM
4.30s, IIRC, and 4200 stall (which locked immediately after the 1-2).
post #55 of 154 (permalink) Old 11-28-2012, 07:08 PM
1MTNCAT's Avatar
I know he had at least 4:30's at one point cause he and I were probably the first to use those. He may have had more gear in it later, I don't know.
Steve
1MTNCAT is offline
post #56 of 154 (permalink) Old 11-28-2012, 11:37 PM
TGJ
TGJ's Avatar
JL had 4.30's...
TGJ is offline
post #57 of 154 (permalink) Old 11-30-2012, 09:37 AM
1MTNCAT's Avatar
The good part is
Look at the various Naturally aspirated combinations now runnings in the 12's with 2V heads compared to several years ago.
Bored & stroked motors
Stock motors
with PI's unported, NPI's & PI's ported and new TFS style heads.
Pump gas, Race gas and E85
We've come a long way from 1995 with these little motors/big cars!!!!!
Steve
1MTNCAT is offline
post #58 of 154 (permalink) Old 11-30-2012, 01:04 PM
r429460's Avatar
Still tiny engines, look at the times when the humidity is 33%, then goes up
two hours later to 92%. 4 10ths. drop off in the ET.
Thw dew on my roof was running down the back window like it was raining and I was on I95.
Thats what sux about bracket racing, time runs day time, eliminations at night.
11.97@ 109.35
3880 lbs. w/driver.
r429460 is offline
post #59 of 154 (permalink) Old 11-30-2012, 02:00 PM
Tbird1997's Avatar
Yep little motors and very big cars. Of course with all these new mustangs and most other cars our boats are a about average now.
I thought it was very impressive that Luke just barely got in the 12s with a stock 2v PI motor and only 3.73 gears!
-Patrick
9.63@77mph on used street tires
Pics here.. http://forums.tccoa.com/30-videos-images/129479-tbird1997-pictues.html
Tbird1997 is offline
post #60 of 154 (permalink) Old 12-01-2012, 10:31 AM Thread Starter
So, fastest N/A 4.6 on 93/104/116 gas goes something like this?
JL with his low 12
Paintme102 with his 12.60(so he says)
me with my 12.76.
Is there a thread somewhere at has all this info in? Maybe we can make a list of all the MN12s times and mods? Just an idea...
97 LX
R.I.P.
BEST MOTOR TIMES
12.76 @ 105
BEST NITROUS
12.12 @ 109 mph
