TCCoA Top Times - The All Time Best List - Page 2 - TCCoA Forums
 1Likes
post #31 of 94 (permalink) Old 12-14-2012, 11:32 AM Thread Starter
Gotcha Dave. Great runs!
post #32 of 94 (permalink) Old 12-14-2012, 11:34 AM
David Neibert's Avatar
Wow, that was quick !
Thanks, David
David Neibert is offline
post #33 of 94 (permalink) Old 12-14-2012, 11:58 AM
VA Chapter Director
Jason Miller's Avatar
Send a message via AIM to Jason Miller
If you want this list to reflect my all time best then in this thread it should be 12.440 @ 112.54 mph and that was 7/07
Member MAMN12 Drag Racing team Best ET 12.44 @109mph
Click here to check out the Mid Atlantic chapter
Jason Miller is offline
post #34 of 94 (permalink) Old 12-14-2012, 12:04 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Yeah, and if you'd get it to the track it'd be quicker than that now!!! So what are you hollerin about anyway. At least I TOOK THE TIME to get you listed on these threads. LOL
Steve
"There's a bad, built 4.6L Coming in 2016"
Current Elite member of the Halfshaft snapping, Auburn eating, Tranny crunching, Piston Melting, Tire lifting Torque Club
Previous Best 11.75 @ 113.76 1.57 60', ZEX Nitrous April 2012 (346 HP, 503 TQ)
Previous Best 12.94 @ 105.25 1.81 60', Naturally Aspirated April 2012 (254 HP, 315 TQ)
"IN MEMORY OF MY FRIEND JOEL BENDER 1979-2006"
"IN MEMORY OF JOHNNY LANGTON 1975-2011- 4.6L NPI NA RECORD HOLDER"
"IN MEMORY OF MICHAEL VIVERETTE 1953-2013 aka-CHRISTINE KENNEBELL Bird"
1MTNCAT is offline
post #35 of 94 (permalink) Old 12-14-2012, 01:02 PM Thread Starter
Got it Jason. Thanks for getting me the correct time.
This is why I'm maintaining two lists - The Current Time list and this All Time list.
In general, I'm not a fan of "My car is faster than yours look what it ran in 19xx or 200x !"
If someone hasn't run near their best in years then the time is really irrelevant other than for historical purposes.
post #36 of 94 (permalink) Old 12-14-2012, 08:17 PM
VA Chapter Director
We'll see what happens in the spring Steve. Lets see. 400psi empty bottle and 26" tall drag radials put me in the 12.50's. I'll fill the bottle and get some 27" bias ply and see what happens in a few months. Any predictions? LOL
post #37 of 94 (permalink) Old 12-14-2012, 08:43 PM
1MTNCAT's Avatar
Yeah, 12.1's at Cecil!!!!!
Steve
1MTNCAT is offline
post #38 of 94 (permalink) Old 02-06-2013, 03:23 AM Thread Starter
Originally Posted by RobertP View Post
118.42 MPH with SVO Blower
109 mph N/A
Well 12.1 compression 5.0 boss block and e85 same heads and cams as you
Robert
Bump. I was looking over this thread to check and update it and noticed this post that I missed previously. I didn't realize that he made those runs on E85 and his block is a 300 ci Boss Block vs the 281 ci of the standard 4.6L.
Anyway, I changed the 2011 date to 2010 for Chris (Blown38).
Any body else want to add their time?
post #39 of 94 (permalink) Old 02-06-2013, 05:18 AM
1MTNCAT's Avatar
Ron
You sure about that? Didn't think Hans was running a 5.0 block or E85.
Steve
1MTNCAT is offline
post #40 of 94 (permalink) Old 02-06-2013, 05:27 AM Thread Starter
Per Robert
See the quote below complete with links to hanz's times.
Edit: Duh, After looking at it again I see, you're right; he's talking about two things. 1. Hanz's times with the links and 2. Wayne's build with the Boss block and E85.
I'll make the correction.
109 mph N/A
Robert
post #41 of 94 (permalink) Old 02-06-2013, 09:02 AM
1MTNCAT's Avatar
I'm thinking Hans set up was a 12.1 aluminum teksid with renegade ported heads and aftermarket cams with the SVO blower, kooks etc when those numbers were run.
I'm thinking NA it was the same set up minus the blower when he ran the NA numbers. Guess only Rob would know for sure.
But it was a 4.6 running on gasoline.
Steve
1MTNCAT is offline
post #42 of 94 (permalink) Old 02-06-2013, 11:15 AM
Yea it was 11.1 but the setup was identical except blower
And Ron as long as its a 4.6 motor size it's good to go, only engine size difference would be like a 5.4 motor something that is physically bigger,
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 6.34@109.89
10.11 @ 139.19 best mph
RobertP is offline
post #43 of 94 (permalink) Old 02-06-2013, 12:24 PM
1MTNCAT's Avatar
Robert
No way pal. Don't even go there.
Whole nother ballgame. You take a typical 4.6 281 cubes and then a 5.0 300+ inch, however you arrive at it. If each only make 1 HP per inch its NOT the same. You're looking at least 19-20+ HP minimum and a torque difference from the get go. If thats the case then why not use a stroked 5.3/5.4 either then? Why build a 5.0 or 5.3 then? There is an advantage or it wouldn't be done. Now a clean bored .020 or.030 over non stroked 4.6 is another story and not hardly enough to mention. Bottom line its either a 4.6 or a 5.0 or a 5.3 whatever. Yeah and I know people lie too or don't tell the whole truth!! LOL
Thats like saying a stock set of PI heads are comparable to a production set of TFS heads.
Oh, and I'm Santa Claus!!
Steve
1MTNCAT is offline
post #44 of 94 (permalink) Old 02-06-2013, 12:43 PM
It's beside the point, if its a 4.6 motor that's what matters, if y'all wanna whine on it so be it, ill put fords 6.2 in mine, that's and massive upgrade, I mean u can just bolt on bigger blower if need be and do the same thing, putting a 5.4 shelby motor is completely different
So be it see if I care
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #45 of 94 (permalink) Old 02-06-2013, 01:13 PM
1MTNCAT's Avatar
Got nothing to do with whinning. If thats the case why worry about a 5.3/5.4 if you have a 5.0. Just add a bigger blower.
It really matters especially if its a NA motor. There you aren't running power adders.
So if someone takes out your current numbers with a 5.0 or 5.3 then the 4.6 on the bottom of your signature really means nothing then? To some degree you have to keep things apples to apples, and oranges to oranges. 20-30 cubic inches is not apples to apples. Blown or NA!
People look at these forums to get actual information. If they don't understand what they are looking at in comparison then they get a false sense of whats real or not.
Thats all I'm trying to get across Rob. Its certainly nothing personal. We go back a LONG....... way! I think you know where I'm coming from here.
Steve
1MTNCAT is offline
post #46 of 94 (permalink) Old 02-06-2013, 01:51 PM
Yea ill make up what ever I don't have with a ysi blower
10.75 @128.38
1/8 6.34@109.89
RobertP is offline
post #47 of 94 (permalink) Old 02-06-2013, 02:37 PM Thread Starter
... If thats the case why worry about a 5.3/5.4 if you have a 5.0. Just add a bigger blower.
4.6L to 4.6L is (roughly) apples to apples.
As I've said before, there really is no true apples to apples comparison of our cars because no two cars are exactly alike.
For the purpose of this list engine size and a brief list of mods are identified. Due to the rising number of cars now running E85 I've also added that information to each person's list profile who runs E85. I know Chris uses race gas and probably Nickleman and Siska too, along with some of the other top time runners but I don't know which kinds of gas. I highly doubt that the top times on the list are run on just 93 pump gas, especially the V6 SC's.
If someone runs a better time than someone else on the list, the list viewer can look at the engine info and see roughly why. Granted there are many other variables including the extended mods list, track conditions and weather (DA). But for the purpose of brevity those factors aren't listed here.
post #48 of 94 (permalink) Old 02-06-2013, 03:33 PM
r429460's Avatar
For those that care, back in the day 1985, my 460 Falcon was
.25 seconds faster on 112 VP racing fuel that the 100 octane LL(low lead)
avation gas.
Quickest N/A Modular MN12.
11.97@ 109.35
3880 lbs. w/driver.
Bradenton Spring Brake Shootout 03/04/2017.
r429460 is offline
post #49 of 94 (permalink) Old 02-06-2013, 04:46 PM
1MTNCAT's Avatar
Try yours on race fuel and see how it does comparitively speaking to E85. That would be a fun experiment.
I know mine does much better with just a bit of oxygen enrichment ROFL!!!!
Steve
1MTNCAT is offline
post #50 of 94 (permalink) Old 02-06-2013, 05:04 PM
NeedAbirdinVA's Avatar
Send a message via AIM to NeedAbirdinVA
I'll add my times for both cars...
16.254 @ 83.83 NeedAbirdinVA '91 T-Bird 3.8 11/20/2011
14.832 @ 93.47 NeedAbirdinVA '89 SC 5spd 6/16/2012
'89 SC 5-speed SCP down tubes,muffler delete 14.83@93mph(sold) '94 Rose Mist Lincoln Mark VIII..Custom downtubes,muffler delete,gloss black cougar rims.(Now lives in my '91) '91 Thunderbird
V6 AKA The UnderBird.... cone filter, Custom down tubes to highflow cats,magnaflow muffler to turndowns in the middle of the car(LOUD), Vogtland 1.6 springs, poly bushings, '89 SC seats, '95 bird Sun visors, '95 bird radio, Chrome '97 sport rims with 255/55/16's... 16.25@84mph(mid 14's now)(skinnys,removed pass. seat,door panels and center console and advanced timing)
NeedAbirdinVA is offline
post #51 of 94 (permalink) Old 02-06-2013, 07:11 PM
VicRattlehead's Avatar
12.410 @ 103.95. VicRattlehead 96 T-Bird 4.6L N2O 7/09
CMP Drag Racing
VicRattlehead is offline
post #52 of 94 (permalink) Old 02-06-2013, 10:27 PM
miller1995's Avatar
Was your car running in 09? Who did you get to push it down the track that fast?
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #53 of 94 (permalink) Old 02-07-2013, 09:21 AM
Send a message via AIM to Red97Tbird
I really need to find my 12.1 time slip. I have no Idea what I did with it. Fastest one I see is my times on youtube is 12.39@113.95...
4.6 explorer motor,Water meth injection, V1 Vortech, 3.48 pully,BBK 78mm, Dirty Dog 9.5 converter 3500 stall, RobertP built trans, 8.8 rear with trac lock, 3.73 gears, BrainCoating manifolds, Dual 2.5" exhaust.
Red97Tbird is offline
post #54 of 94 (permalink) Old 04-13-2013, 05:57 PM Thread Starter
Congrats to Chris Murder on his new time and breaking into the 13 second club.
13.891 @ 103.58 Chris_Murder - 97 T-Bird 4.6 4V N/A 04/2013
post #55 of 94 (permalink) Old 04-13-2013, 07:37 PM
1MTNCAT's Avatar
Awesome
I new it would do it. Probably more there too!!!!!! Congrats
Steve
1MTNCAT is offline
post #56 of 94 (permalink) Old 09-29-2013, 01:22 PM
Speaking of which lets correct it with my new best since technically speaking I should be dropped from both lists now that the 97 is crushed and the 96 is doing all the work. Slower but honest.
13.971 @ 104.08 - 09/2013 - Chris_Murder - 96 T-Bird 4.6 4V N/A
post #57 of 94 (permalink) Old 09-29-2013, 09:16 PM Thread Starter
Got it Chris. Thanks for the update.
Get yourself some DR's and get that time down where it should be with that engine set-up.
post #58 of 94 (permalink) Old 11-01-2013, 10:42 AM Thread Starter
I've penciled in neverfastenough on the list at 11.8 seconds. He couldn't remember the exact numbers but his car is certainly capable and deserves a place on the list.
Congrats on an awesome car! Looking forward to seeing some new, firm numbers next year.
Here are the details that he sent to me:
Originally Posted by neverfastenough
It's going on 3 years since I've been to the track. Its gone 11.80s with well over 2.0 60ft. I got the launch figured out and did 3 back to back 1.6 60ft but second gear blocker was dead and it just wasn't taking it. So I've never made a good pass. Trapped over 120 but I don't know the exact number off the top of my head. Its a 3.8, built short block, stock split port heads, custom intake, turbo setup. Using a precision 6766. I'm doing heads and cam over winter. Back to single port with a full custom intake. Shooting for the 750 rwhp mark.
post #59 of 94 (permalink) Old 11-01-2013, 11:03 AM
Need to update SCrazy too. 10.607 @ 128.37 - SCrazy - 1994 SC, C4 Auto, 2.6L KB This was done in september '13.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------300RWHP est.---------who knows/who cares
10.740@127------------13.842@103.08-------16.1@
BLOWN38 is offline
post #60 of 94 (permalink) Old 11-01-2013, 11:17 AM Thread Starter
Got it. Thanks for the update Chris. I see he switched from AR to KB.
