0 - 60 and 1/4 mile times: EVERYONE READ - TCCoA Forums
post #1 of 2 (permalink) Old 11-21-2002, 03:09 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
Exclamation 0 - 60 and 1/4 mile times: EVERYONE READ
Here are a few links that I have found for getting info on 0-60 and 1/4 mile times:
Car-Stats.com
Automotive Performance Central
If you know of any others, just PM them to me and I will add them in!
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #2 of 2 (permalink) Old 01-11-2007, 09:00 PM
MaddMartigan's Avatar
You can also check here:
http://www.albeedigital.com/supercou...0-60times.html
You can see whether or not your 3.8 1994 Thunderbird can beat a 2006 Honda Civic (it can't btw).
Please don't clog up this forum with questions about whether your car will beat some other car. Take it to the track and find out.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
