XR7-4.6's disjointed Build Thread, now a 4V snob - Page 8 - TCCoA Forums
 30Likes
post #211 of 659 (permalink) Old 04-29-2013, 01:14 PM Thread Starter
Slightly Disjointed
Nah, I have enough other uses for snap ring pliers that I'll just buy a new pair. I've been abusing the current ones since 2008 so they had a good run
I may just take you up on the torx bolts though. I may have been able to disassemble the whole trans with them in place, but it happened so fast I can't remember exactly how to do whatever it is I did in reverse
post #212 of 659 (permalink) Old 05-02-2013, 11:39 PM Thread Starter
Slightly Disjointed
Got second and it's hub out finally.
Fixed my pliers and got the snap ring off but the hub still needed coaxing and the 3 jaw puller, even with my custom extensions, was way too short to reach. I had to improvise
step 1
step 2
step 3
post #213 of 659 (permalink) Old 05-03-2013, 12:43 AM
*images elided*
Tell me that's not blood, that red smear under the hammer ...
RalphP is offline
post #214 of 659 (permalink) Old 05-03-2013, 01:21 AM
jhiland32's Avatar
Ha! I was wondering the same thing!
Jason H.
Mods:
jhiland32 is offline
post #215 of 659 (permalink) Old 05-03-2013, 02:21 AM Thread Starter
Slightly Disjointed
Heh, it's just paint but I guess I subconsciously placed it there
post #216 of 659 (permalink) Old 05-03-2013, 02:42 AM
THats a great LP start to finish, a fun listen. DOHC with 5 speed in an mn12 sounds badass.
post #217 of 659 (permalink) Old 05-03-2013, 02:03 PM
Roadrunnner's Avatar
That's an awfully big hammer for trans work. Cant wait to see the finished product good luck with your build.
Will
Roadrunnner is offline
post #218 of 659 (permalink) Old 05-03-2013, 04:28 PM
jhiland32's Avatar
Jason H.
Mods:
post #219 of 659 (permalink) Old 05-11-2013, 05:57 PM
jhiland32's Avatar
How's the 5 speed coming along? Haven't heard much lately.
Jason H.
Mods:
post #220 of 659 (permalink) Old 05-11-2013, 07:49 PM Thread Starter
Slightly Disjointed
Waiting on/looking out for parts. Only thing I've done to it recently was start building it's wiring harness. Mostly though I got back to working on and finishing the 4V's engine harness(es) after FINALLY sourcing some ridiculously hard to find connectors and clips. I'll be posting pics when they're complete (I'd post them now but since I've been leisurely putting all this wiring together over the past 4 months I need to organise the pics I've taken, which I think will be easier all at once).
Overall It's all coming together at snails pace. Juggling the DOHC, the T-45, the exhaust, engine management (yes I'm swapping PCMs too) and every other little doodad I throw in the mix is taking patience and $$$. Everything I need I hold out for deals/discounts for, so parts aquisition(and thus progress) is pretty random.
post #221 of 659 (permalink) Old 05-11-2013, 08:12 PM
jhiland32's Avatar
Well snails eventually get where they're going ! Can't wait for pictures though. Can't wait to put a manual in mine even if its just a NA 3.8 but it will still be fun, even more with a 4.2 when the time comes.
Jason H.
Mods:
post #222 of 659 (permalink) Old 05-31-2013, 10:49 PM Thread Starter
Slightly Disjointed
I've thought about pressing a steel sleeve over the cracked boss, drilling/tapping the hole deeper and using a ball pivot with a longer stud(if I can find one).
I would tig weld the broken pivot boss smooth it, sleeve it around it, weld the sleeve to the boss, fill it with weld, redrill a slightly smaller hole, tap it with the correct threads, lock it in place with JB Weld just to go over the top, and if all goes well you'll have a stronger than stock repair.
Or, or, I can do this instead
old/new
Got a good deal it from a guy on CMC so this will make things a bit less complicated. In the midst of all the other crap I'm in the middle of doing for this project, I really didn't need to engineer a fix for an old broken part.
I'm phoning in this update. There's not a whole lot of other progress on the other various tasks in this build I'm ready to share yet... so here's a several more pics of boring old bellhousings
Borg-Warner
Old one was a Borg-Warner, 96-98 according to my research.
Here's it's "issue"
Borg-Warner bellhousing inside
BW cracked/stripped pivot boss
The new one's a tremec, so from 99-mid 01 apparently.
Tremec
Tremec bellhousing inside
This one's got a better condition throwout bearing retainer as well.
post #223 of 659 (permalink) Old 06-01-2013, 04:22 AM
I bet you're done before GM fires his engine up...
post #224 of 659 (permalink) Old 06-01-2013, 06:14 PM Thread Starter
Slightly Disjointed
We'll see. He keeps putting ideas into my head, thus sabotaging progress
post #225 of 659 (permalink) Old 06-01-2013, 06:21 PM
rmfk13's Avatar
Glad to see you found a bellhousing! Hopefully this one doesn't snap off like the other one did :p
Rob
rmfk13 is offline
post #226 of 659 (permalink) Old 06-01-2013, 06:36 PM Thread Starter
Slightly Disjointed
No kidding The guy I got it from was initially selling another bellhousing but it turned out that it not only had a broken boss, the boss was apparently completely gone!
This one's got a good pivot stud so I'm not touching it lol
post #227 of 659 (permalink) Old 09-30-2013, 02:51 PM Thread Starter
Slightly Disjointed
Well the time has come for the update you've all been waiting for....
I finally found a pair horizontal ALPS lock switches!
ALPS switches
ALPS switches
post #228 of 659 (permalink) Old 09-30-2013, 03:03 PM
Thanks for that Matt, now I can die happy.
post #229 of 659 (permalink) Old 09-30-2013, 07:33 PM
Rayo's Avatar
I couldn't help but notice that you have a Grey Interior Door Handle Trim on one side, and a Black Interior Door Handle Trim on the other side..
Are you looking for a matching Grey Interior Door Handle Trim for the Driver Side as well?
I've been waiting for this update for awhile..
1991 Ford Thunderbird Sport
Rayo is offline
post #230 of 659 (permalink) Old 09-30-2013, 07:37 PM Thread Starter
Slightly Disjointed
Have you never seen a 94-97 Thunderbird interior? Excluding saddle, they're all like that
And no. I swapped in the black Tbird bezels on purpose. The stock ALL grey bezels Cougars come with(which includes the dash/radio surrounds and console tops) was just too bland.
post #231 of 659 (permalink) Old 09-30-2013, 07:59 PM
Rayo's Avatar
I figured if I brought that up you would school me on MN12 interiors..
That's why you're the Moderator of the Interior section of TCCoA..Who knows more about MN12 interiors?..waits
Don't be too surprised if someone copies your idea..That is..If you share what car the switches came from..
Rayo is offline
post #232 of 659 (permalink) Old 09-30-2013, 08:26 PM
Earl's Avatar
Any idea what the original application was for those switches?
Earl is offline
post #233 of 659 (permalink) Old 09-30-2013, 10:07 PM Thread Starter
Slightly Disjointed
Hey no secrets here(though I'll never tell how to make outside temp display automatically! lol). The window switches are passenger and rear door switches from a gen IV Taurus(the drivers door switches are a 1 piece cluster on them so those won't work) and the lock switches in horizontal form can be found on 02+ Explorers and Expeditions.
Wiring them was the hard part since the connectors aren't even close. The illumination circuit in the window switches had me racking my brain as I recall as well, as they internally share the ign circuit with the window motor, rather than having their own ignition feed. Took lots of dissection to figure those out(the diagrams were useless for the new switches)
post #234 of 659 (permalink) Old 09-30-2013, 11:16 PM
Mgino96tbird46's Avatar
Too lazy to read into it again, why did you change the switches, again?
1996 Thunderbird LX. Gone, but not forgotten Oct 1995-March 24 2016
1998 Mustang GT premium. Auto, stock, and slow. Daily beater.
Mgino96tbird46 is offline
post #235 of 659 (permalink) Old 09-30-2013, 11:48 PM Thread Starter
Slightly Disjointed
I like the look
post #236 of 659 (permalink) Old 10-01-2013, 12:04 AM
Custom User Title
Ehhh .. I dont think its fair to say one is more knowledgeable than another, perhaps in different aspects of the interior. Matt may be more keen on color trims and options ( not that I couldnt get the information ), but I definately have more "experience".
dDUBb is offline
post #237 of 659 (permalink) Old 10-01-2013, 06:00 AM
Send me a compatible SATC head from the secret model year and I'll figure it out for myself!
post #238 of 659 (permalink) Old 10-01-2013, 06:41 AM
Rayo's Avatar
True..I could have worded that differently, but yeah his knowledge of color trims also options is pretty extensive..
I have no doubt that your "experience" with interior swaps, and rewiring of MN12/FN10 far exceeds many here..
As a whole there are a quite a few knowledgeable members here that know their way around an MN12 interior..
"Active Members" ..Now that's a different story..
Rayo is offline
post #239 of 659 (permalink) Old 10-01-2013, 10:55 AM
cobra R Thunderbird's Avatar
I like those switches Matt. Cool mod!
2001 GT BULLITT #00762 stock
post #240 of 659 (permalink) Old 10-01-2013, 03:51 PM Thread Starter
Slightly Disjointed
Knowledge of color trims and options is the extent of my "experience"?
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
MaddMartigan
