Coyote 5.0 Engine Swap - Page 4 - TCCoA Forums
 117Likes
post #91 of 237 (permalink) Old 03-07-2016, 04:51 PM
Originally Posted by OxmanWI View Post
Yea I could use a chrome moly gauge bezel.
Send me a scan of the design you end up with, and I'll see if I can make one from carbon fiber.
Flat is pretty easy...
post #92 of 237 (permalink) Old 03-07-2016, 06:24 PM
MaddMartigan's Avatar
Heck, even I would be interested in something like that. It doesn't even have to be carbon fiber. It just can't be 1 million dollars (or $200) like the ones I've seen.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #93 of 237 (permalink) Old 03-07-2016, 08:17 PM
I don't want to jack an awesome thread;
But I bought cheap discount carbon fiber cloth, found the best, clearest, most sun-resistant epoxy I could find, some cheap nomex honeycomb, vacuum bagging films, and have been experimenting since.
I've got less than $200 in the whole mess; and it's fairly easy to do.
I wouldn't want to make anything structural, but I'm going to do decorative stuff.
This is some of the cloth:
http://forums.tccoa.com/vbpgimage.ph...7&d=1457403401
post #94 of 237 (permalink) Old 03-07-2016, 08:44 PM Thread Starter
That looks really cool, but I think I'll pass on the carbon fiber cloth. I'll just end up painting the bezel black and be done with it. I keep finding myself buying stuff that I really don't need. For example these valve cover plates. I really don't need them but I couldn't pass up a custom CNC design. I'm having them powder coat to look like the ones on the bottom.
post #95 of 237 (permalink) Old 03-14-2016, 07:41 PM Thread Starter
Another update
The oil pan fits. The pick up is spot on. With the headers, oil pan the starter fits with no clearance issues.
Used some silly puddy to see what the clearence from the bottom of the sump.
If you get a 2011+ Mustang 5.0 the oil adapter will hit the sway bar. You can replace it with one from a 2011+ F150 5.0, get a oil cooler / remote oil filter kit. I found a F150 adapter cheap on eBay for $20.
Headers and oil pan, coming together!
BigZ and KEVIN8989 like this.
post #96 of 237 (permalink) Old 03-14-2016, 08:03 PM
sik97bird's Avatar
So jealous. Looking good man
sik97bird is offline
post #97 of 237 (permalink) Old 03-14-2016, 10:57 PM
Slightly Disjointed
That's an Addco sway bar correct? Those use the 3.8/5.0 design which splays out quite a bit wider than the 4.6 bar, which hugs the pan shape and K member pretty tightly, so sourcing a different oil filter adapter may not be necessary with one of those.
post #98 of 237 (permalink) Old 03-15-2016, 07:56 PM Thread Starter
Yes addco. Interesting I didn't know that.
post #99 of 237 (permalink) Old 03-17-2016, 08:34 AM
coggonobrien's Avatar
Just curious, what factory electronics will be retained? still going to use the original hvac? Will air bags still be functional?
coggonobrien is offline
post #100 of 237 (permalink) Old 03-17-2016, 07:35 PM
Me too, Ox!
Those Thunderbird valvecovers are reminiscent of the ones on my '63, but they were stamped.
The build looks awesome!!
post #101 of 237 (permalink) Old 03-17-2016, 08:24 PM Thread Starter
Everything but the computer (EEC) for the stock engine and transmission.
Me too, Ox!
Thanks man, I'm excited. Can't wait to drive this summer
post #102 of 237 (permalink) Old 03-21-2016, 05:59 AM
Overkill Fetish Freak
Great build Josh, keep the info flowing.
-Scott
OxmanWI likes this.
Dr. FrankenCougie is offline
post #103 of 237 (permalink) Old 03-21-2016, 10:35 AM
S4gunn's Avatar
Q: With the F150 filter relocation adapter, what is the clearance between the top of front sway bar and the bottom of the oil filter.
If they are practically touching, does the front swaybar move slightly under compression? It's hard to tell top-down from the picture if this is something to be concerned about.
-g
S4gunn is offline
post #104 of 237 (permalink) Old 03-21-2016, 01:01 PM Thread Starter
With the car in the air the sway bar is about 2 inches away. Once I drop the car and the weight is on the suspension the sway bar will move down towards the ground giving more clearence from the sway bar and oil filter. Unless I hit a jump and go airborne maybe the sway will hit the bottom? Hoping to keep the front wheels on the ground, no wheelies for me.
post #105 of 237 (permalink) Old 03-21-2016, 06:49 PM
gordonm1's Avatar
Nice build. You're gonna have a doughnut maker. My car is more of a doughnut "go getter".
OxmanWI and CDsDontBurn like this.
gordonm1 is offline
post #106 of 237 (permalink) Old 03-22-2016, 09:27 AM
cruising
The build is looking great Josh. The motor fits nicely in there. Do you have abs on the car? I'm curious what side you're going to put the air filter .
Zack
1994 SC - jack stand queen
BigZ is offline
post #107 of 237 (permalink) Old 03-22-2016, 04:40 PM
V8ThunderCat's Avatar
This is just plain awesome sauce right here! I happened to google K-member and the tubular MN-12 K-member happened to be on the first page. I saw that and thought it couldn't be that hard to install a coyote engine. Then the next day I stumble upon this topic. Great job!
OxmanWI likes this.
-Randy-
V8ThunderCat is offline
post #108 of 237 (permalink) Old 03-29-2016, 09:57 PM Thread Starter
Another update. I'm going with a manual valve body from Lentech and a Hurst pistol grip quarter shift. The 4R75W is getting a forged forward clutch drum and the valve body installed, a dyno with the TC at my local transmission shop that I trust with no bull shit.
Since this is a full manual I have to wire buttons for the TC lock up and overdrive. I'll probably wire the red button on the hurst as the overdrive and put a button on the center console dash for the lock up.
I bought this 1/4 steel plate 12x4" to mount the hurst shifter. Drilled the holes and mounted nice a strong.
I had to cut a little tab out in the front, not bad.
V8ThunderCat likes this.
post #109 of 237 (permalink) Old 03-29-2016, 10:24 PM
Slightly Disjointed
I came this close l..l to using that shift knob with my 5 speed swap!
OxmanWI likes this.
post #110 of 237 (permalink) Old 03-30-2016, 07:24 PM
If it's a drag car, you'll want the lockup on the shifter; who needs OD?
Shift, lock, unlock, shift, lock...It'll go by that quick, lol.
post #111 of 237 (permalink) Old 04-16-2016, 09:43 PM Thread Starter
I don't know if it will go like that, but something of that sort.
I got the headers back from ceramic coating. The valve covers back from powder coating. I'm hoping mid May or June 1st for a start up.
Woodman and Patty McNuggets like this.
post #112 of 237 (permalink) Old 04-16-2016, 09:52 PM
Really looking awesome there Josh... been enjoying watching all your updates and progress.
OxmanWI likes this.
post #113 of 237 (permalink) Old 04-16-2016, 10:14 PM Thread Starter
Thanks Brandon, yea this project has been alot of fun. Can't wait to drive this thing.
post #114 of 237 (permalink) Old 04-16-2016, 11:08 PM
Beautiful. I love the Tbird valve cover caps.
OxmanWI likes this.
post #115 of 237 (permalink) Old 04-17-2016, 04:45 AM
X2! Looking good there Josh!
OxmanWI likes this.
post #116 of 237 (permalink) Old 04-17-2016, 01:06 PM
Send a message via AIM to Red97Tbird
Looking good.. man that's a pretty motor..
OxmanWI likes this.
Red97Tbird is offline
post #117 of 237 (permalink) Old 04-17-2016, 05:41 PM
Black_Cat's Avatar
Sick nasty...
OxmanWI likes this.
I drive an endangered species...they are being crushed at an alarming rate. Please do your part to preserve the Cougar species, and ensure they live on into the future.
1995 Mercury Cougar XR-7 4.6L 2V 5 Speed
1998 Lincoln Mark VIII LSC Collector's Edition Car#94
2009 BMW 535i M Sport Package
Black_Cat is offline
post #118 of 237 (permalink) Old 05-10-2016, 09:33 PM
BIG PETE's Avatar
Dude, this is going to be awesome! How did I miss this thread???
-Pete
OxmanWI likes this.
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #119 of 237 (permalink) Old 05-28-2016, 08:49 PM Thread Starter
Little update:
A few weeks ago I got the transmission back.
The engine and transmission are in the car for good, I did that a week ago or so.
Today I was able to put in the headers and starter. Tomorrow I'm hoping to start more on the wiring and install the radiator and fan. More to come!
theterminator93 likes this.
post #120 of 237 (permalink) Old 05-28-2016, 09:31 PM
Looking fantastic! Can't wait to hear it...
