Coyote 5.0 Engine Swap - Page 5 - TCCoA Forums
 117Likes
post #121 of 237 (permalink) Old 05-28-2016, 09:51 PM
Looking good. I can't wait to hear the start up.
Looking through your pictures I'm curious why you didn't clean this rust up while you had access to these locations?
Also, I'd replace the brake lines in the last photo if I were you. Now's the time to do it while you've got everything apart.
Just some suggestions. I'm not trying to nit-pick your build, I only wish that I could do the kind of work you're doing on my own car. Best wishes!
post #122 of 237 (permalink) Old 05-29-2016, 07:30 AM Thread Starter
I'm not worried by the surface rust on the underbody, there is very little to worry about it. When I get a car lift next winter I'll lift the body off the k-member and rear subframe and take care of the areas that need it. The body is very clean, I think the picture is exaggerating the rust, I added a little contrast to the picture.
As far as the brake lines I'll be replacing them before the car hits the road. Already bought the replacement lines.
It's ok nit-pick away. Anyone who has questions please ask me, I'm not going to hide this build or keep it secret. Hope to see more Coyote MN12-FN10's builds in the future.
Woodman and CDsDontBurn like this.
post #123 of 237 (permalink) Old 05-30-2016, 07:48 AM
Rayo's Avatar
Cool build!
I probably missed it, but I'm sure your reasoning for using the tubular k-member was sound..
Basically, what I'm asking is..Without the use of the tubular k-member, would the Coyote swap be possible?
Looking at these pics:
Things look incredibly tight in there..
It looks like the back of the oil pan sits pretty low..Will the car be sitting at stock height?
1991 Ford Thunderbird Sport
Rayo is offline
post #124 of 237 (permalink) Old 06-02-2016, 06:12 PM Thread Starter
You can cut into the stock k member and make it work. My main reason for the k member is to gain access to the headers, power steering rack, oil filter, starter, etc. Second, the weight savings.
There is 1/2 inch clearance between the oil pan and the k member. I have eibach springs.
post #125 of 237 (permalink) Old 06-02-2016, 07:16 PM
Rayo's Avatar
Thanks, and Good Luck!
Rayo is offline
post #126 of 237 (permalink) Old 06-02-2016, 08:39 PM
What is the weight savings between the two K members?
Edit: N/M I found it ....
Originally Posted by OxmanWI View Post
I was able to drop the stock K member today and do a test fit and she fits. There have been a few guys wondering about fitment issues. There was none. The only thing that will not fit is the stock oil pan. I will need to buy a Canton low profile that is used in the Factory Five Cobras. If my measurements are correct it will fit perfectly. I was also able to weigh both K members and get a difference between the them, the mounts, arms and bolts. The difference is almost 30 pounds.
post #127 of 237 (permalink) Old 06-02-2016, 10:22 PM Thread Starter
Update:
Made some progress on the gauge bezel. The radiator is in along with the alternator. I replaced my KYB stuff with tokico's in the front and cobra bilstein's in the rear. The front suspension is torqued to spec. Just need to do the rear. I'll do a DIY alignment before I take it to Firestone. Painting the brake calipers, brake lines and starting on the wiring. Someone requested a picture up top. The clearance is very tight on both sides of the towers. Slowly but surely, military training and overtime at work is keeping me from finishing this thing anytime soon.
Room between the engine and radiator.
CDsDontBurn likes this.
post #128 of 237 (permalink) Old 06-03-2016, 05:07 AM
MaddMartigan's Avatar
Update:
I'm very interested in this part. How did you go about making the bezel?
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #129 of 237 (permalink) Old 06-03-2016, 12:40 PM Thread Starter
I bought a piece of aluminum 1/4" plate from a welding shop near me. bought a metal cutting 2-1/16" hole saw and 3". Measured 20 times for the spacing and fitting the bezel over the stock gauges.
post #130 of 237 (permalink) Old 06-03-2016, 01:48 PM
How did you manage to get the overall shape of the plate to be correct and what did you use to cut it?
FRPP 42# injectors
3.73 gears
OMGHI2U
post #131 of 237 (permalink) Old 06-03-2016, 05:10 PM Thread Starter
Sharpie marker, hand held cutting wheel, grinder, files, and eye-ballin it.
Woodman likes this.
post #132 of 237 (permalink) Old 06-03-2016, 06:06 PM
bowez's Avatar
Some of the best tools in any machine shop
OxmanWI likes this.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #133 of 237 (permalink) Old 06-04-2016, 05:04 AM
Cobra_Bird's Avatar
Awesome! On behalf of well, everyone...thanx for this great write up, step by step details with pics & sharing of the minut details. Share the knowledge, knowledge is POWER.
To make the ic panel/bezel, could you have just used the stock one & outlined it on the aluminum plate to get the shape?
OxmanWI likes this.
Mark
Semper Fi til I die.
Cobra_Bird is offline
post #134 of 237 (permalink) Old 06-04-2016, 10:27 PM Thread Starter
Something like that, the stock bezel cover is (I think...) 4 inches by 8 inches on the bottom? I bought a aluminum 1/4 thick plate from a welding shop near me and eye-balled it on the sides and bottom to match the stock bezel face. I wont use the clear window, just bolt the aluminum bezel on top and run long bolts though the back to sandwich the whole thing together so I can have a stock look with the cluster dash.
post #135 of 237 (permalink) Old 06-15-2016, 08:45 PM Thread Starter
Here is a picture of the cold air intake system. The housing is from a 2012 GT500, I replaced the paper filter with a K&N. Getting the bottom coolant hoses put in. Should be hitting it hard this weekend! More updates to follow!
post #136 of 237 (permalink) Old 06-15-2016, 09:16 PM
Here is a picture of the cold air intake system. The housing is from a 2012 GT500, I replaced the paper filter with a K&N. Getting the bottom coolant hoses put in. Should be hitting is hard this weekend! More updates to follow!
Video or it didn't happen ....
Congrats Josh! I bet you can't stand the anticipation.
Be careful with it !!!!!
post #137 of 237 (permalink) Old 06-15-2016, 09:22 PM
Slightly Disjointed
Looking forward to seeing that air box install, those look sweet.
post #138 of 237 (permalink) Old 06-23-2016, 01:55 PM
rbrown's Avatar
Oh so close.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #139 of 237 (permalink) Old 06-23-2016, 03:20 PM Thread Starter
So close, but working overtime at work. Just want to finish.
And the air box fits like shit, had to cut it up
Finished the pedal mounting plate, air tube and filter are in, coolant top and bottom hose are in, heater hose connected and working on the battery box in the trunk. I made a list of things that need to get done and that's not even cutting into it.
After work and dinner tonight I'm going to drink beer and stay up until 2 AM just to knock some of the wiring and little tedious crap on my list.
post #140 of 237 (permalink) Old 06-23-2016, 03:38 PM
Slightly Disjointed
I was going to ask, where were you going to mount the airbox? Driver side like the factory Shelbys?
post #141 of 237 (permalink) Old 06-23-2016, 04:28 PM Thread Starter
I thought the Shelby had the air box on the driver side? The GT500 anyways. The air box will go on the driver side and the PCM and PDB on the passenger side where the stock air box once was.
post #142 of 237 (permalink) Old 06-23-2016, 04:36 PM
Slightly Disjointed
Sorry, I meant driver side . I was speculating that part of the poor fitment may have been coming from trying to mount it in the factory (MN12) location. I see now it's probably that the intake comes to it at an angle rather than to the side as Coyotes require
There reason you chose to mount the PCM there? I'm used to our olde tyme 104 pin connector setups which are definitely not weatherproof
post #143 of 237 (permalink) Old 06-23-2016, 10:20 PM Thread Starter
It's all good!
In the FRPP instructions it wants you to either put it in the passenger side fender or in the glove box. There is no way I'd be able to make the glove box work. In the 11-14 Mustangs they are all in the engine bay exposed to the elements. I'll make some sort of sheet metal enclosure like Rod (Racecouger) did for his 32V swap. And the wheel well cover and lower bumper should be good for the bottom part. Just keep heat away from it, is the important part from what I gather. The PCM looks weather tight anyways.
post #144 of 237 (permalink) Old 07-10-2016, 01:01 PM Thread Starter
post #145 of 237 (permalink) Old 07-10-2016, 01:32 PM
It is alive! Nice nice!
OxmanWI likes this.
post #146 of 237 (permalink) Old 07-10-2016, 05:10 PM
Runs pretty smooth. Now to dial it it. Sounds great too!
Oh so close to finishing!
Congrats again. I so wish I had the space, the time and the skills to do my own work.
Nice video & great audio. Did you shoot it with your 70D? Which picture style?
post #147 of 237 (permalink) Old 07-10-2016, 05:51 PM
Custom User Title
That is amazing. So good to see a project in progress and finally the video with the engine running.
- Dan
OxmanWI likes this.
dDUBb is offline
post #148 of 237 (permalink) Old 07-10-2016, 06:45 PM Thread Starter
Thanks Ron! I did use the 70D, H.264, 1080, 30 fps. I should have used my Rode Mic to capture better sound, but is was just a quick video.
post #149 of 237 (permalink) Old 07-10-2016, 11:24 PM
VicRattlehead's Avatar
Nice
OxmanWI likes this.
CMP Drag Racing
VicRattlehead is offline
post #150 of 237 (permalink) Old 07-10-2016, 11:55 PM
Draetech09's Avatar
Great job Ox! Awesome to see this project come out successful. Way to stay dedicated!
OxmanWI likes this.
If you Fail to plan, then you plan to Fail!
I'll forever bleed Ford Blue
Drae
Draetech09 is offline
