Coyote 5.0 Engine Swap - Page 7 - TCCoA Forums
 117Likes
post #181 of 237 (permalink) Old 08-02-2016, 11:11 PM
Slightly Disjointed
Oh I see, the geometry of those must be a little different stock vs. AJE
post #182 of 237 (permalink) Old 08-09-2016, 12:24 PM
BIG PETE's Avatar
This build is awesome. Oxman, any issues with the AJE installation? I think a lot of the early problems have since been resolved, but I was wondering if you had any thoughts on this piece since many have never run this setup. Would you have any issues with using this setup on a street car that is mostly driven around town while cruising on the weekends and does the occasional track day?
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #183 of 237 (permalink) Old 08-10-2016, 06:43 AM
Darrin's Avatar
If you are interested in going with auto shift and staying with that transmission, I have helped a lot of guys get it done using the newest Baumann controller. That thing rocks. Baumann used to be a bad word around me, but he has REALLY stepped up his game with his latest box.
D
Darrin is offline
post #184 of 237 (permalink) Old 08-13-2016, 09:56 AM
MaleWhore
smokymance's Avatar
Great build and write up!!!! Loved reading all of it so far!!! Love the brakes...what rotors are you using up front, the stock cobra 13''?
1997 MN12 Sport 4.6L Supercharged 5 Speed
2000 Jeep XJ 4.0L Lifted
smokymance is offline
post #185 of 237 (permalink) Old 08-21-2016, 01:24 PM
BIG PETE's Avatar
Josh,
Still looking for any inputs on the AJE k-member. I am looking to get one for my car since I will be pulling the engine very soon and I am considering doing this modification for more access. I think most of the negative feedback on these units was from the early days, but I wanted to get your impressions on the install, driving qualities, and if you think it would be safe for use on a street car that is mostly a weekend cruising machine that goes to the track a few times a year.
Please let me know.
-Pete
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #186 of 237 (permalink) Old 08-22-2016, 12:47 PM
coggonobrien's Avatar
looks good
coggonobrien is offline
post #187 of 237 (permalink) Old 08-25-2016, 05:40 PM Thread Starter
Pete
Josh,
Please let me know.
-Pete
Thanks!
For the installation, it was just dropping the stock k member and bolting the AJE in it's place. I used a transmission jack. The AJE only uses 4 bolts to mount to the frame. I would have liked them to build one that uses all 8 stock frame bolt holes, but it works for now. Along with using the stock lower arms and strut bar. My imputs? Don't be a dumb-dumb like me, make sure you install the strut arms on the correct way the first time. Mine were backwards. Along with the strut arms, if you are running a 17-18-19-20" wheel by 9" you'll need at least a 1 inch spacer to turn your wheels lock to lock without rubbing. I have only 120 miles on the car since the swap. It has all been street and highway driving. The lower arms are good, no bending. I bought them mostly for the space to work on headers, power steering rack and changing the oil. Second, the weight savings off the front end. I was able to replace a steering rack super fast and install headers with ease. And changing out a oil filter would be a easy with a stock 4.6. Any other questions let me know!
D
I had the US Shift Quick 4 Transmission Control System by BEC, sold it to EEC DOC. Opted for more of a fun way to shift with a MVB and hurst shifter. So far so good.
Thanks! Yes those are 13" cobra rotors
Originally Posted by coggonobrien View Post
looks good
Thank you!
post #188 of 237 (permalink) Old 08-27-2016, 09:58 AM
BIG PETE's Avatar
Josh,
Thanks for the info, I went ahead and ordered a mild steel one from Anthony over at AJE. We'll see how it goes, but the thought of installing the headers from the bottom with the engine and K-member already in the car sounds easier than stabbing it from the top with the Kooks already installed or trying to lift it all from the bottom in one movement. Having done it, do you think that's the easiest way to get the headers in with this k-member? Also, how's the handling? Any noticeable improvements in chassis rigidity and handling?
As for the wheel spacers, thanks for the heads up on that. I'll make sure to check with the car still in the air and post back up the results for anybody else who researches this thread. The rims that I am running are a 18 x 9 with +36 mm of offset with the stock 5 x 4.25 bolt pattern, so we'll see what happens with those since they are different than the rims that you are running... which I think are a 19 x 9" with + 42 mm of offset.
Pete
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #189 of 237 (permalink) Old 08-27-2016, 04:26 PM Thread Starter
It would not clear the sides with the headers on the engine from up top. I'm sure a 2V compared to a coyote will be different. The header install was easy with the k-member. I do notice a more stiffer ride, but I went from bouncy KYB struts and stocks to Tokico Blues and Bilstein along with the k member.
CDsDontBurn likes this.
post #190 of 237 (permalink) Old 08-27-2016, 09:00 PM
BIG PETE's Avatar
Yeah, I remember JL saying that to get the SOHC in with the headers already on the engine required a load leveler getting to about 45 degrees and clearing the brake booster and frame by about 1/4" on each side. Not for the faint of heart, so I look forward to just stabbing the headers from the bottom, working through the k-member with the engine and trans already mated.
I also plan on upgrading my front to some Koni's that have been sitting in the closet for a couple of years now, so I think this will be something to look forward to as long as I don't have any rubbing issues.
Pete
OxmanWI likes this.
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #191 of 237 (permalink) Old 09-20-2016, 08:11 PM
JoeyICU's Avatar
I think I asked this once before, but to seem like a real notable idiot, doing the AJE K, requires there lower control arms, and other stuff? I thought I saw this k for sale on jegs, but it had arms for sale separate. What is the price on these?
1995 Ford Thunderbird 4.6 LX
2011 BMX X5 Xdrive50i
1998 Jeep Grand Cherokee 5.2L AWD - Cooling work, a big sound system, an exhaust, 3.5" IRO lift on 31s
1984 Ford F250 6.9 IDIT
JoeyICU is offline
post #192 of 237 (permalink) Old 09-20-2016, 08:39 PM
MaddMartigan's Avatar
It looks like you need these: Adjustable Rodend A-Arms 1988-97 Thunderbird I don't trust this is the correct part either because it doesn't look like the LCAs in the pictures in this thread.
And this: K-Member 1989-97 Ford Thunderbird
Interestingly enough, while looking I ran across this: Pinto Steering Rack Kit 1988-97 Thunderbird which is pricey and not correct most likely....
and this: Coil-Over Strut Conversion w/Drop Spindle 1988-97 Thunderbird which is also pricey and not correct most likely.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #193 of 237 (permalink) Old 09-21-2016, 07:47 PM
JoeyICU's Avatar
Ya those where the things I saw. I didn't know if they had a complete kit somewhere else. I may buy that stuff and slowly piece it all together.
JoeyICU is offline
post #194 of 237 (permalink) Old 11-15-2016, 04:00 PM Thread Starter
Don't tell my wife I have car parts on the carpet. Winter project coming soon!
free photo hosting
photo sharing websites
BIG PETE, Woodman and CDsDontBurn like this.
post #195 of 237 (permalink) Old 11-15-2016, 04:41 PM
OMG.
I just out-drooled my cat.
That's Ponderous, totally ponderous!
OxmanWI likes this.
post #196 of 237 (permalink) Old 11-15-2016, 07:58 PM
Nice. Congrats. I knew you'd slap one of those on there as soon as you could afford it. What size is that? Details please.
You need to get it down here for a proper tune.
OxmanWI likes this.
post #197 of 237 (permalink) Old 11-16-2016, 11:28 AM
I have a 91 T-Bird. Looking to put a 5.0 in it. I'm buying all the parts and having someone do the work. I need to know what all do I need to do and buy besides the engine?
Birdlover1 is offline
post #198 of 237 (permalink) Old 11-16-2016, 12:04 PM
Go to the 5.0/5.8L forum, plenty of info there. This thread is covering the 5.0 Coyote swap. Whole different animal.
Welcome!
OxmanWI likes this.
post #199 of 237 (permalink) Old 11-16-2016, 12:40 PM
will the blower fit under your hood?
OxmanWI likes this.
post #200 of 237 (permalink) Old 11-16-2016, 04:01 PM
I'd add a "Wart" for THAT blower, lol.
OxmanWI likes this.
post #201 of 237 (permalink) Old 11-17-2016, 11:13 PM
BIG PETE's Avatar
Thanks!
Josh,
Getting ready to do my AJE K-member swap, so I don't have a certain answer yet, but here's what I came up with when trying to order the spacers for the 18x9 rim that a lot of guys run here, myself included, from The Custom Wheel Shop. I figured that I would post these pictures to hopefully shed some light on the issues for anybody else contemplating this K-member / Coyote swap.
The first attachment compares the Custom Wheel Shop 18x9 to the Track Pack Mustang rims, and it looks like the Track Packs are nearly 11 mm closer to the suspension components than the 18x9 style rim. The next compares a stock 16" MN12 rim to the Track Pack. The difference looks substantial at about 18 mm closer to the suspension for the Track Pack, and the last chart compares stock to CWS 18x9... only about 7 mm closer to the suspension for the CWS.
I will update this post with results on how everything works with my Custom Wheel Shop 18x9's and the AJE K-member.
Pete
OxmanWI likes this.
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #202 of 237 (permalink) Old 11-17-2016, 11:28 PM
Slightly Disjointed
That's it, I quit
post #203 of 237 (permalink) Old 11-18-2016, 07:11 AM Thread Starter
Thanks Ron! It's a Eaton M122 from a 07-12 GT500. It's a 2.0L I believe. Stage 7 port and fresh rebuild from Stiegemeier. The manifold is from Department of Boost. It's the cheapest way to supercharge a coyote. Kinda like the Tork Tech with the 4.6 2V from Bill. I bought the M122 and manifold from a ARMY guy in Germany with a 2014 Mustang GT. Decided to sell the kit and go with a turbo. I got a nice package deal with free shipping. Not sure where I'll get a tuned.
It should, I hope. I have a 3" VFN cowl hood
Josh,
Pete
Looks like you're crunching the numbers, but yea a 1" spacer for 9" wide rims for sure. I plan on having my front wheels narrowed 1" and put a 235/35/19 on the front so I don't have to use spacers. If you look at the car from an angle you can tell the wheels stick out, it bugs me and I don't like the stance.
That's it, I quit
Nooo don't quit! haha. Dude your 4V swap is awesome Matt.
post #204 of 237 (permalink) Old 12-05-2016, 07:33 AM
so............blower on yet?
OxmanWI likes this.
post #205 of 237 (permalink) Old 12-07-2016, 06:33 AM Thread Starter
Not for a while, I'm currently finishing up a remodeling project in my basement, adding a 4th bedroom. My wife and I are also expecting our second this weekend so once I start FMLA and my basement is done ill have some garage time.
post #206 of 237 (permalink) Old 12-07-2016, 07:21 AM
Rayo's Avatar
Congrats Josh!
OxmanWI likes this.
1991 Ford Thunderbird Sport
Rayo is offline
post #207 of 237 (permalink) Old 12-07-2016, 07:29 AM
congrats on the baby, you know unlike cars you can just stack children as you have more...........
OxmanWI and CDsDontBurn like this.
post #208 of 237 (permalink) Old 01-10-2017, 10:21 AM
Congrats!
Better to get this project done now. You'll find that as the kids grow they become more expensive and will eat (literally) into your hobby funds.
Boy or Girl?
post #209 of 237 (permalink) Old 01-11-2017, 06:06 AM
twin turbo 281's Avatar
Sweet build. BTW the M122 is a 2.1L blower. I had one on a custom setup and then upgraded to a 2.3L TVS charger and will be moving up to a 2.6L TVS when they are released.
Does that Stiegemeier stage 7 have the snake bite overdrive gears in it?
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #210 of 237 (permalink) Old 01-19-2017, 03:43 PM Thread Starter
Thanks guys, proud Papa! We had a boy named Austin. Yea a new baby and a toddler is no joke. I just finally finished my basement remodel, ill be in the garage soon.
No snake bite, just stage 7 and rebuild.
I'm replacing the 4R75W with a 6R80-Circle D triple disk, upgrading the the PCM to a auto-installing a PBH control kit to work, narrowing the front wheels and of course the department of boost supercharger kit.
There is a guy who lives a few miles south of me, he has a fox Mustang with a GT500 swap and 6R80. I've been getting advice and tips from him. Hoping to make this a high 10 second car before 2018. I've decided to get the car tuned with Lund Racing. A mass majority of fox coyote swap owners are recommending him.
