Common MN12 Problems (A buyers Guide) - Page 2 - TCCoA Forums
 2Likes
post #31 of 44 (permalink) Old 08-27-2015, 01:08 AM
ptschett's Avatar
My '96 4.6L had the coolant crossover failure about 14 years and 140,000 miles ago. The manifold I have now, replaced under the recall/extended warranty at zero cost to me, must have been an early one since it's all black plastic externally. [knocks on various wood and faux-wood objects till knuckles are raw]
I started noticing the rocker rot last year... sad, but inevitable, on a car that was a daily driver including winters first in SD and later ND, with excursions into MN and other neighboring states, for the timeframe of 1998 through 2010.
196k+ miles and I've never touched the fuel pump. I want to get the car past 200k... after that, I'm not sure what I'm doing with it.
1996 Ford Thunderbird 4.6L/auto, 195k miles, semi-retired
2005 Dodge Dakota Club Cab 4x4 4.7L/auto
2015 Dodge Challenger R/T 5.7 Hemi/auto
Gone but not forgotten: 1973 Mercury Cougar XR-7 351C-2V/FMX - 2010 Dodge Challenger R/T 5.7L/manual
ptschett is offline
post #32 of 44 (permalink) Old 09-22-2015, 09:15 AM Thread Starter
General Thing for new owners
Stock up on random parts, what is easily found today may not be when you need it.
steveg1988 is offline
post #33 of 44 (permalink) Old 11-22-2015, 09:34 AM
03HarleyF150's Avatar
Angry
I do think that totally crappy gas may shorten the life. As will letting the car sit. A buddy did his wife's Mustang GTat 3500 miles. But the car is just not driven all that much. Maybe a tank a year.
If there's some consensus on a average it would be good to know.[/QUOTE]
I have a 40th Anniversary Packaged '04 GT Mustang Convertible that I had to replace the fuel pump this past spring with only 23K miles. Car is sometimes driven less than 250 miles during warm weather months for car shows. A co-worker had to change his '04 Mach 1 fuel pump out at 9300 miles. Seems the factory ford fuel pumps don't do well in the tank of rarely driven 'Stangs.
I hope I don't have this issue with the Cougar I just purchased. It has 41k miles and was last registered in '08. Sat in the lady's basement due to health reasons. Still working out some of the lack of usage bugs with one being inoperative wipers, washers pump and door/key chimes. Fixed all the other electrical issues encountered so far but that one. Have checked the combination switch, the relay module, and fuses. Anyone have any input on the ground wire(s) location for this circuit?
Would like to suggest this be considered an issue on low usage cars if not listed already further on in the thread. I've run across several searches listing this issue for T-Birds and Cougars.
03HarleyF150 is offline
post #34 of 44 (permalink) Old 11-23-2015, 08:58 AM
T6Rocket's Avatar
Dump a can of Sea Foam in a full tank of gas, to dissolve varnish from all of the fuel system components.
Al
97 T-Bird LX 4.6 - 68k miles
Previous cars:
T6Rocket is offline
post #35 of 44 (permalink) Old 11-26-2015, 04:00 AM Thread Starter
According to the guy i got my leather interior off of, the t-bird power seat motors are a flawed design from the start. He worked at Holman Ford until 2001 as a service/parts guy. And he was able to swap my interior for me in about 45 minutes, so i can trust that he would be right about that!
post #36 of 44 (permalink) Old 11-27-2015, 07:26 PM Thread Starter
This is not a common problem, or a problem at all. This is more like a "good design" feature.
the MN12 does not use struts up front, they do sell quick struts (i have a set) but they are really coilovers. Meaning that you don't have to do much to get them in or out. Break the ball joint loose to get more room to swing the bottom arm out, unbolt the top bolts, unbolt the bottom bolt, it is as easy as doing a regular shock absorber.
Common Issue: New shocks will rarely have the right mounts for the rear, just go with whatever they have for the top mount and follow the directions, it is differnet but....it works 100%.
Don't try and get the sport suspension....nobody really makes it anymore.
post #37 of 44 (permalink) Old 06-14-2017, 08:40 PM
1991 5.0's Avatar
About the smartest thing I've heard so far !!
1991 5.0 is offline
post #38 of 44 (permalink) Old 06-15-2017, 07:57 AM
Natesriv's Avatar
Originally Posted by ogbird95 View Post
You can fix B pillar fade with some matte black plasti dip. Did it to mine and looks great.
Black Bumper paint works too
Natesriv is offline
post #39 of 44 (permalink) Old 06-15-2017, 08:46 AM
Natesriv's Avatar
The motors are fine I believe... taken them apart more than once... very simple...rotor, stator..the magnets are actually in the metal tubes that hold the parts... Pretty simple.
The BAD part of the design is the power seat switches. There's a lot of copper parts which I think just wear at the contacts over the years...
I've a post on the seats here somewhere..
Pefect? No but pretty simple to fix
Natesriv is offline
post #40 of 44 (permalink) Old 06-15-2017, 11:27 AM
Slightly Disjointed
The gearboxes are flawed, steel worm gears in a plastic case makes for a bad time. The switches I've never ever heard of issues with.
post #41 of 44 (permalink) Old 06-15-2017, 12:17 PM
T6Rocket's Avatar
Krylon flat black looks quite nice too. It's not as flat as it sounds, more like a matte finish. No orange peel at all, very smooth.
Looking inside the door, I was surprised to see how much gloss the original color had. I still like flat - it doesn't jump out at you like a gloss would against slightly faded rubber trim.
Al
Natesriv likes this.
Previous cars:
T6Rocket is offline
post #42 of 44 (permalink) Old 06-15-2017, 02:01 PM
ODO gears :/
Lots of links on here as to where to find them and how to repair it. Mine went last week at 98K.
96 Thunderbird LX 3.8L
Fishing when I'm not driving
Advice welcomed
jt96NY is offline
post #43 of 44 (permalink) Old 06-15-2017, 04:00 PM
Natesriv's Avatar
Al
Agreed, a nice semi matte finish sets it off just fine
Natesriv is offline
post #44 of 44 (permalink) Old 06-15-2017, 05:49 PM
Originally Posted by jt96NY View Post
ODO gears :/
Dude, that's not a MN12 thing ... those are Chrysler/Ford gears we buy; and there's a REASON why Chrysler is listed first in a lot of the listings!
Fuelly
RalphP is offline
