My Bird with the Nitrous - Page 3 - TCCoA Forums
post #61 of 78 (permalink) Old 12-10-2007, 07:25 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Originally Posted by Mark M. TCCoA VP View Post
I like mine wet
What the hell do you know anyway Steve? LOL
Nothing! That's why I'm on here making sure he gets hold of the experts!
Besides Mark, You know I don't know my Arse from a hole-in-the-ground!!!!!!
LOL!!!
Steve
"There's a bad, built 4.6L Coming in 2016"
Current Elite member of the Halfshaft snapping, Auburn eating, Tranny crunching, Piston Melting, Tire lifting Torque Club
Previous Best 11.75 @ 113.76 1.57 60', ZEX Nitrous April 2012 (346 HP, 503 TQ)
Previous Best 12.94 @ 105.25 1.81 60', Naturally Aspirated April 2012 (254 HP, 315 TQ)
"IN MEMORY OF MY FRIEND JOEL BENDER 1979-2006"
"IN MEMORY OF JOHNNY LANGTON 1975-2011- 4.6L NPI NA RECORD HOLDER"
"IN MEMORY OF MICHAEL VIVERETTE 1953-2013 aka-CHRISTINE KENNEBELL Bird"
1MTNCAT is offline
post #62 of 78 (permalink) Old 12-18-2007, 02:17 PM
fordmuscle's Avatar
I dont need to get ahold of anyone, I already know what SHM has to say. I was just looking to see if someone here has run any ghetto nitrous rigs. ( No Instruction sheets included- BIg Guy.)
'77 F-350 460ci- Daily Driver
''94 T-Bird LX 4.6L SOHC
Mostly stock w/ 189,000 mi., but not for long. Soon to be a nitrous breathing 4000 lb. IRS terror.
fordmuscle is offline
post #63 of 78 (permalink) Old 12-18-2007, 05:19 PM
Whining Intakes Rock
Al_Florida's Avatar
Originally Posted by 1MTNCAT View Post
...You know I don't know my Arse from a hole-in-the-ground!
Well.. both are dark and brown.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #64 of 78 (permalink) Old 12-19-2007, 06:12 PM
1MTNCAT's Avatar
Tis True,
However, I can't answer the question cause I don't run a ghetto system.
Steve
1MTNCAT is offline
post #65 of 78 (permalink) Old 12-20-2007, 08:28 AM
VA Chapter Director
Jason Miller's Avatar
Send a message via AIM to Jason Miller
Tis True,
Steve runs nothing ghetto.
It's redneck engering at it's finest!
Member MAMN12 Drag Racing team Best ET 12.44 @109mph
Click here to check out the Mid Atlantic chapter
Jason Miller is offline
post #66 of 78 (permalink) Old 05-09-2008, 02:17 PM
LW-FX-'s Avatar
hey quick ? for u guys, loking at my sig below i should have no prob running a 75 dry shot in my car right? dun wanna go with wet, jus like the idea of not changing out a bunch of stuff, jus get welded into my cold air .should i run a switch or rpm read be better?
1995 COUGAR XR-7, March underdrive pullies, FRPP 9mm plug wires, '02 Mustang GT MAF sensor and housing, custom 2.5" H-pipe true dual exhaust w\flowmaster 40's, Mountain racing Perfomance Custom Shorty Headers, 180thermostat,Front mount tran cooler, MSD 40,000 volt DIS 4 coil packs, NGK V power modified electrode plugs, K&N cone filter,Modified '95 Honda Civic intake tube, FRPP 19# hr injectors, BBK 255ph fuel pump, BBK adjustable fuel pressure regulator 34\46psi(idle\WOT), Ramsey's performance Dyno tuned computer w\221 rwhp 247 rwtq on 93 octane and 3.08 gears, no speed limiter, 6400 rpm rev limiter, LUK clutch packs and Redliine bands and bearings in rebuilt tran w\ race shift kit, hughes 2000 stall
LW-FX- is offline
post #67 of 78 (permalink) Old 05-09-2008, 04:53 PM
IF you are running a zex kit then you dont need anything else,if you have some off the wall setup that is pieced together then you will need a wide open throttle switch
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/298tq--12.13@110.05mph
1989 mustang gt 10.68@126.97
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #68 of 78 (permalink) Old 05-09-2008, 06:21 PM
LW-FX-'s Avatar
links? i was looking at summit racing site at there kits, will they do ok?
LW-FX- is offline
post #69 of 78 (permalink) Old 05-09-2008, 06:48 PM
go for a zex dry kit,it has the wide open throttle switch built in so there is no accidental spray at less than full throttle
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #70 of 78 (permalink) Old 06-18-2008, 02:38 AM
lots of peoplel ike the zex kit. but with it come some false securities. then again i was paid at the shop to be extremely careful as to how we set up our clients cars. the zex kit is good because it comes with the safety net box to prevent alot of the bad things you hear about with nitrous. but most of the time bad things involving nitrous are because people who haven't researched it toss iton for the quick power boost and something goes boom.
any kit id suggest a window switch and a step colder plug and dont go nuts with the timing. the kits suggest every 50 shot to retard timing by 2 degrees but thats not really necessary. as long as you dont bump up stock timing, use a step colder plug, and use high octane fuel you shouldn't have any issues.
make sure your car is in good running order, no oil leaks, no burning oil etc etc.
get it, have fun. you'll never regret having n2o. once you get it, one time try running with race gas too. though its up to around 8 bucks a gallon its real fun, nice power boost off the giggle gas, and nitrous eats that stuff up too.
best of luck and have fun. be safe.
Travis
blue95lx is offline
post #71 of 78 (permalink) Old 12-09-2008, 05:54 PM
my tb truck's Avatar
One of our racing buddies is still tuning the T-bird but I think it is ready for the track. It was fast before but he upped the nitrous and I will let all know after he gets it to the track.
my tb truck is offline
post #72 of 78 (permalink) Old 12-09-2008, 05:57 PM
I am not smart enought to post more than one picture at a time so I saved this shot. .
post #73 of 78 (permalink) Old 12-09-2008, 11:02 PM
Send a message via AIM to tstats
very clean what were its old times?
97 Cougar
98 Mustang
tstats is offline
post #74 of 78 (permalink) Old 12-11-2008, 07:24 PM
I can't remember the times but will try to find out Saturday. We are going to the dragstrip but this car won't run because he is not taking it. He decided to go fishing. He may change his mind since we had a lot of rain. As soon as I find out I will keep you posted.
post #75 of 78 (permalink) Old 12-12-2008, 07:41 AM
looks good.
post #76 of 78 (permalink) Old 12-13-2008, 01:56 PM
seawalkersee's Avatar
What are some of the specs on that?
SWS
seawalkersee is offline
post #77 of 78 (permalink) Old 12-16-2008, 06:33 PM
The best time before in the eight was 6.9/60ft was 1.54. He is trying to beat my son's Nova with a procharger on it. They all work on each others cars to compete with each other. All in fun. We took the Nova to Darlington Saturday and did pretty good. He has too much power for the tires and will have to go wider to get it to hook. This was the best time with the Nova just easing into it off the lights. He tried the trans brake and all four tires cleared the ground. Looked weird to see a launch with the whole car off the ground.
post #78 of 78 (permalink) Old 11-03-2013, 10:18 AM
I got a question.
How does the auto trans hold up to the extra power from the nitrous? Before I got my T bird, I was running Mustangs with a 5 speed trans and the stock trans sux. You can trash one with a stock engine much less using a power adder.
Since the price of a Ford Racing T5 costs $1300 with shipping to Hawaii, I decided I can get a used car and not have to work on it. I found my T bird and love it a lot better then driving my old Fox body car ( I did put a 75 shot of nos in my Mustang before I blew my first transmission). That's why I am asking.
1986 Mustang GT 5.0 RIP
1988 F-150 4x4 5.0
1997 Thunderbird LX
outboardtech is offline
