MN12 Nitrous car registry!!! - Page 2 - TCCoA Forums
post #31 of 83 (permalink) Old 02-04-2005, 05:42 PM
I got a 93 TBird w/ stock 118,000 mile engine, 75mm bullet mass air meter, single 3 inch into dual 2&1/4 exhaust, B&M shift kit, 255lph fuel pump, and a Compucar 150 shot. 3.73's soon to come. No times yet, Bristol doesn't open until March or April I think. But it should go low 13's.
Scott
P.S. Damn am I the only 5.0 here?
scottrob is offline
post #32 of 83 (permalink) Old 02-04-2005, 06:10 PM
Mark M. TCCoA VP's Avatar
And what am I, chopped liver?
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #33 of 83 (permalink) Old 02-05-2005, 12:12 AM
AHHH! Good I didn't want to be the only pushrod guy.
scottrob is offline
post #34 of 83 (permalink) Old 02-07-2005, 10:10 PM
Birdman232's Avatar
I plan on pulling my NX kit off my honda and trying it on my 3.8, then again 108K and I think my Hg's area about toasted....Meh, why not go out with a bang and the Floor pan dropping while street racing(Fast and the furious )
Birdman232 is offline
post #35 of 83 (permalink) Old 02-15-2005, 02:34 PM
I will be getting another kit soon.
Geuss I'm the only one going to run a fogger setup
post #36 of 83 (permalink) Old 03-25-2005, 04:21 PM
Lazania's Avatar
In the process of instalation. 125 ZEX Kit
2011 Mustang GT Premium 6spd
Current Modifications:
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #37 of 83 (permalink) Old 04-15-2005, 11:10 PM
Send a message via AIM to stiffler197
95 bird
zex dry kit
no other mods yet and not track tested
stiffler197 is offline
post #38 of 83 (permalink) Old 04-20-2005, 05:02 PM
MadeInDade's Avatar
Send a message via AIM to MadeInDade
1996 Thunderbird
4.6L V-8
Zex Dry Nitrous Kit 75 shot, for now.
K&N FIPK
180 Degree Thermostat
Motorcraft 22C Colder Spark Plugs
Ford Racing 9mm Spark Plug Wires
SCT Eliminator Switch Chip
MadeInDade is offline
post #39 of 83 (permalink) Old 07-31-2005, 04:28 PM
ResqBird's Avatar
Thanks to NUHBOY4.6, I now have a 96 LX with a ZEX 75 shot.
ResqBird is offline
post #40 of 83 (permalink) Old 11-11-2005, 06:30 PM
SnoPro881's Avatar
Zex Kit with 75 shot
BBK 70 mm Throttle Body
Trick Flow Upper Intake
BBK Adjustable Fuel Pressure Regulator
K&N FIPK
Underdrive Pulleys
3:73 Trak-Loc
MSD Coils
Much More To Come!!!!!!!!!!
SnoPro881 is offline
post #41 of 83 (permalink) Old 12-07-2005, 05:32 PM
TurboCoupe50's Avatar
1988 Turbo Coupe 5.0 conversion
OOPS sorry not a MN12....
Trick Flow heads and Stage 1 cam
1.6 roller rockers....Cobra intake
65mm T-Body....24 lb injectors
75mm Pro-m MAF....1 5/8 shorty headers
Full 2 1/2" exaust system with 3 chamber Flow Masters
Lockup AOD with 2600 Stallion converter....3.73 gears
225/60/16 Nitto Drag Radials
5115 NOS dry system jetted for approx 85-90hp
Best 12.23@112.19... 1.72 60 ft...
Tried a full 150 shot, but the tires couldn't hold it till well into 2nd gear...
Holding off till 2nd gear 12.50@114.89
1988 Turbo Coupe... 5.0 conversion... AOD... 3.73s
NA..13.11@105.32... W/90hp shot.. 12.23@112.19
1988 Turbo Coupe... White, 5.0 with Trick Flow heads
1988 Turbo Coupe... Bright Red
1993 F150 Lightning... Black.. #249 of 5276
TurboCoupe50 is offline
post #42 of 83 (permalink) Old 12-08-2005, 11:27 AM Thread Starter
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Don't really matter! Its still one of our own LOL!!! Nice numbers and a really good list of mods. I bet that car really runs well. Sounds to me like its time for some larger drag rubber.
Good luck in your modding.
Steve
"There's a bad, built 4.6L Coming in 2016"
Current Elite member of the Halfshaft snapping, Auburn eating, Tranny crunching, Piston Melting, Tire lifting Torque Club
Previous Best 11.75 @ 113.76 1.57 60', ZEX Nitrous April 2012 (346 HP, 503 TQ)
Previous Best 12.94 @ 105.25 1.81 60', Naturally Aspirated April 2012 (254 HP, 315 TQ)
"IN MEMORY OF MY FRIEND JOEL BENDER 1979-2006"
"IN MEMORY OF JOHNNY LANGTON 1975-2011- 4.6L NPI NA RECORD HOLDER"
"IN MEMORY OF MICHAEL VIVERETTE 1953-2013 aka-CHRISTINE KENNEBELL Bird"
1MTNCAT is offline
post #43 of 83 (permalink) Old 12-08-2005, 04:15 PM
Whining Intakes Rock
Al_Florida's Avatar
It's almost finished so I guess I'll put mine in here now.
1994 Tbird LX 4.6
Shortblock and heads are stock for now. They'll go soon
SVO supercharger
Zex dry. I'm going to rejet for 50 shot.
90mm LMAF, 99 ziptube, 75mm BBK throttlebody
30# injectors, custom wired engine harness
3200 stall Dirtyd0g converter
99 GT 4r70w jmod, hp epc, tailshaft lube mod, speedcal
Dynotech MMC driveshaft
250lph fuel pump
4.10 gears and trac-lok in a Mark VIII pumpkin
Eibach lowering springs, new front suspension, new shocks and end link bushings in rear. Rear shock tower brace.
Custom program by Mr. X in Texas.
Have not been on the track yet. Will update my sig when I do. Which, barring any problems, will be on or before Dec 16th.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #44 of 83 (permalink) Old 12-08-2005, 04:41 PM
ThunderChicken1's Avatar
Send a message via AIM to ThunderChicken1
ok, lets see if i can remember everything...
02 explorer long block
forged rods and pistons (10.5:1 compression)
SCT tune
kooks headers to true dual exhaust
mach 1 torque converter
Jmod
3.55 gears w/ trac-lok
NX wet kit 75 shot window switch + TPS switch
awaiting install over the winter:
walbro 255 fuel pump
02 GT MAF
re-tune
150-175 shot o the good stuff
Matt
RIP Thunderchicken...
moved on to a lighter chassis with a 5 speed and cheaper parts. i know, i sold out.
ThunderChicken1 is offline
post #45 of 83 (permalink) Old 12-09-2005, 12:25 AM
Midnight's Avatar
Send a message via AIM to Midnight
Sounds like after the install of the pump you have plenty of room for more spray!
Sprtnlax14: i was was up at 4:30 to hunt
LtlLinds424: you did NOT just say hunt
Sprtnlax14: whatever, the day you become a vegan we'll talk
LtlLinds424: the day that you stop only spitting game and not producing girls in your bed... we'll talk
My Dragons
Midnight is offline
post #46 of 83 (permalink) Old 12-10-2005, 10:43 AM
Matt
post #47 of 83 (permalink) Old 12-21-2005, 07:05 PM
indiana's Avatar
95' Bird
Zex wet kit 75hp shot
Never used yet. Maybe next summer?
95' T-Bird w/ Allen 9psi S/C,JBA headers,30# injectors, 80MM Lightning MAF, 180 Thermostat,190 LPH pump,K&N filter,3.73 gears, Auburn Differential 28 spline for 8.8, SVT 17x7 Cast Alum. Rims w/Michelin Pilot Sport A/S p235/50ZR17, Art True Dual S/S w/High Flow Cats 2.5' Exhaust w/Superturbos, MMC Driveshaft, Cobra Brake upgrade 13"KVR Cross Drilled w/ 2 Piston PBR Calipers, Rear disc convertion w/ 12" KVR Cross Drilled Rotors, Zex Wet Nitrous Kit w/ Polished Bottle, Optima Battery In Trunk, Vortech Intercooler Tank, Tranny Cooler
http://www.supermotors.net/users/Indiana
06' SRT8 Dodge Charger w/Techco Supercharger 5.5psi, Custom Dual Exhaust Dump's, Auto Meter Boost & Fuel Gauges, cross drilled & slotted rotors, Oil cooler
indiana is offline
post #48 of 83 (permalink) Old 12-21-2005, 08:30 PM
marlow74's Avatar
89 sc 5spd
'66 289 k-code
wont be installed tillend of jan beg. feb. changing intake carb putting dual exhaust and changing ignition set up. then paint job and then she should be ready for spring.
marlow74 is offline
post #49 of 83 (permalink) Old 09-14-2006, 12:39 PM
Gator1980's Avatar
Send a message via Yahoo to Gator1980
heres what i have!! 1995 Thunderbird. all mods are in my signature
Owning a 9 second ricer is like coming out of the closet. At 1st everybody is suprised, but in the end you're still gay.
Gator1980 is offline
post #50 of 83 (permalink) Old 10-28-2006, 06:27 PM
1991 S.C. zex 100hp shot
superchargeaj is offline
post #51 of 83 (permalink) Old 11-02-2006, 03:20 AM
yyc_tbird_sc's Avatar
Send a message via MSN to yyc_tbird_sc
'89 SC
-Ford Reman Engine
-75mm TB & MAFS
-Custom porting on intake manifold, sc, and return manifold
-stock sc top and i/c
-home ported heads
-Comp Cams 273HR112 cam
-ported exhaust manifolds w/ basically no exhaust
-35HP NOS N20 dry shot
-some other supporting mods too....
13.588 @ 99.76MPH w/ density alt @ 3100'
Scott Semeniuk
1989 TBird SC
Mods are alot more fun to flaunt on the street than on a message board...
yyc_tbird_sc is offline
post #52 of 83 (permalink) Old 11-09-2006, 07:18 PM
midnight toker
dameon's Avatar
Send a message via AIM to dameon Send a message via MSN to dameon Send a message via Yahoo to dameon
well I'm waiting for my NOS system to get here. Just wondering if it counts It's not going on my enigine I'm putting it on the intercooler on my SC. Will i be the only one here with that type set up?
In Memory of Jose Calvetti
12-27-1974 - 7-23-2005
There is no replacement for displacement. Only ways to make the small dog act like the big dog
Originally Posted by Tx_Cat
... i do not have the tools nor the knowledge.
dameon is offline
post #53 of 83 (permalink) Old 11-09-2006, 07:41 PM
If anyone is interested, I have a NOS part#5115 for sale, with a purge.
PM me if you need a good kit.
post #54 of 83 (permalink) Old 11-13-2006, 12:15 AM
Resident Gun Guru
SHADOW's Avatar
WoW, some of you spent a lot of money to not go very fast
13.66 @ 100.4 mph
1.94 60' time
"If you stick with the basics, you never have to go back to them"
SHADOW is offline
post #55 of 83 (permalink) Old 11-13-2006, 08:59 PM
VicRattlehead's Avatar
to bad youve spent more and still dont go as fas as us.
CMP Drag Racing
VicRattlehead is offline
post #56 of 83 (permalink) Old 11-13-2006, 09:23 PM Thread Starter
1MTNCAT's Avatar
Well you fit right in then!!!!!! But then some of us haven't!!!!!!
Steve
1MTNCAT is offline
post #57 of 83 (permalink) Old 11-19-2006, 09:14 PM
I Break Stuff
94V8Thunderbird's Avatar
Send a message via AIM to 94V8Thunderbird Send a message via Yahoo to 94V8Thunderbird
nitrous is in the plans...but as of now no juice.
1988 Mustang GT 306, 4 bbl holley, edlebrock intake, nitrous cam, 4 inch cowl hood.
94 LX PI swapped Bird (sold) missing that car so bad
TCCoABAMF
94V8Thunderbird is offline
post #58 of 83 (permalink) Old 01-15-2007, 01:27 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
1993 Thunderbird 3.8L:
Eaton M112 from Lightning (in progress)
Zex Dry 50hp shot (for cooling purposes)
CO2/air intercooler
ported big valve heads
215/220 cam, .600" lift
1.8 roller rockers
custom modified intake manifold (from an S/C)
8omm LMAF
36# injectors
Kirban Adj FPR
Walbro 255lph HP pump
shorty headers
9.5" converter, 3200 stall, non locking
AODW with Lentech manual VB
aluminum driveshaft
trac-loc 3.73 aluminum case 8.8
mark viii aluminum lwoer control arms
MN12Perf wheel hop eliminator kit
So far, no dyno's. Not even finished putting the supercharger on, but hopefully will be by spring. Hoping for 350-390rwhp depending on 9-11psi.
Thomas is offline
post #59 of 83 (permalink) Old 01-23-2007, 01:17 PM
Motor-15.9@88
Spary-13.5@103
Mods on sig
1993 lincoln mark viii (AKA COBRA EATER!!!)
Mod's-Custom transmission, custom air intake, muffler delete, 255 fuel pump, bbk fuel pressure regulator, NX nitrous kit 175hp jets, custom tune from SCT, et street radials out back
Best times
Motor-13.89@100.6
N20-??? (but I can Beat srt10 vipers on spray buy 5-7 cars!!!)
R.I.P --- 1994 4.6 lx thunderbird (AKA Thundrstruck):Mod's-true duels no mufflers, custom upper intake, Cold air intake, 4.10 gears, custom engine limiter superchips tune not tuned for N20, NX 100 Shoot.Best times:MOTOR-15.9@88:n20-13.570@103.45
94SCTBIRD is offline
post #60 of 83 (permalink) Old 01-23-2007, 06:24 PM
Uber Luber
Thomas's Avatar
Originally Posted by 94SCTBIRD
Motor-15.9@88
Spary-13.5@103
Mods on sig
whats your custom upper intake?
Thomas is offline
