Cobra Bilstein Rear Shock Info - TCCoA Forums
post #1 of 133 (permalink) Old 09-23-2007, 04:20 PM Thread Starter
The Bilsteins that work on MN12's are:
99-04 Cobra with independent Rear Suspension
---> Only the rear shocks are compatible with our cars. <----
Bilstein Part numbers are:
HD Front: F4-V36-4138-H3
HD Rear: F4-BE5-2959-HO
SP Front: F4-VE3-4593-WO
SP Rear: F4-BE5-C265-HO
HD are the Heavy Duty's
and
SP are the Sports
The sports are the firmer of the two choices used on the Cobra Convertibles.
The difference, as described by Bilstein, is quoted below.
SPORT (S)
For the performance-minded driver, Bilstein “Sport” shocks deliver absolute mastery of the road surface.
Designed to push a car’s suspension to its performance peak, these shocks are well suited for use with special springs, anti-sway bars or other suspension upgrades.
HEAVY DUTY (HD)
For most vehicles including full-size sedans, SUVs and trucks. These shocks provide improved handling and stability without sacrificing ride comfort. They offer super damping ability that makes them ideal for heavy hauling for occasional off-road use, while maintaining and exceptional “street” ride.
The one's on my car are the Sports (Convertible): BE5-C265-HO Bilstein Sport Ford Mustang Cobra which I ordered from shockwarehouse.com in November of 2006.
post #2 of 133 (permalink) Old 09-28-2007, 10:05 AM
PCD
Confirmed V6 Nut
Are the bolts the same? I looked at the fitment for other Bilsteins and saw that the Mustang shocks used a bolt that required us to take the bushing out of the shock for the setup to work as the Mustang's bolts are thicker than Tbird bolts for the bottom of the shock.
PCD is offline
post #3 of 133 (permalink) Old 09-28-2007, 03:29 PM Thread Starter
They're Identical. I took the old shocks off and bolted the Bilsteins in. - Direct Fit.
post #4 of 133 (permalink) Old 01-11-2008, 12:27 PM
LOLA's Avatar
I thought I had read here in the past here that the Bilstein fronts had problems with breaking on the botom mount where it's welded to the shock tube.
LOLA is offline
post #5 of 133 (permalink) Old 01-11-2008, 03:17 PM Thread Starter
When Bilstein made shocks for the front of MN12's I believe that was a problem. However, Bilstein no longer makes front shocks for the MN12's. Problem solved. LOL.
post #6 of 133 (permalink) Old 01-11-2008, 03:28 PM
LOLA's Avatar
So are the front shocks OEM FORD Sport shocks and the rears Bilsteins? I assumed since it said Bilstein it was refering to both front & rear.
LOLA is offline
post #7 of 133 (permalink) Old 01-11-2008, 04:28 PM Thread Starter
Yes, my front shocks are OEM FORD Sport shocks and the rears Bilsteins. This is an acceptable set up and the FORD Sports aren't that expensive either.
post #8 of 133 (permalink) Old 01-11-2008, 05:08 PM
Resident Line Creator
th3subtl3on3's Avatar
This is true, but I wish the fronts were a little stiffer to match the rears. When I first did the swap, I learned to take speed bumps slow in the front. I had slammed down on a few.
-Brian
th3subtl3on3 is offline
post #9 of 133 (permalink) Old 01-11-2008, 05:19 PM
ROLLINTHUNDER's Avatar
So the stock replacement rear shocks on a 99-04 mustang which are stiffer than the rear stock replacement shocks on our birds a direct bolt-on?
ROLLINTHUNDER is offline
post #10 of 133 (permalink) Old 01-11-2008, 06:28 PM
Chapter Director Coordinator
jamesD's Avatar
no...
99-04 COBRA with INDEPENDENT REAR SUSPENSION will bolt on.
99-04 MUSTANGS are solid axle and use a different setup
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #11 of 133 (permalink) Old 01-11-2008, 07:49 PM
Last I checked, they were discontinued.
Grog6 is online now
post #12 of 133 (permalink) Old 01-11-2008, 08:20 PM Thread Starter
I bought a set of front OEM Sport shocks off of Jason in December 2006. They probably are discontinued by now but there may be a few sets still available. Anyone interested in these should get them now before they're all gone.
Otherwise it's Koni or Tokico. Any other recommendations?
Last edited by Trunk Monkey; 01-11-2008 at 08:59 PM. Reason: Front/Rear clarification
post #13 of 133 (permalink) Old 01-11-2008, 08:56 PM
I checked in mid-late 2007 and the rear sport shocks are discontinued but the fronts were still available.
post #14 of 133 (permalink) Old 03-01-2008, 08:23 PM
Tx_Cat's Avatar
Can't find the rears.... Probably discontinued...
Tx_Cat is offline
post #15 of 133 (permalink) Old 03-01-2008, 09:01 PM Thread Starter
Which Rears? The sports may not be available anymore. The Bilsteins should be.
post #16 of 133 (permalink) Old 03-01-2008, 10:00 PM
Tx_Cat's Avatar
Can't find the Bilsteins... No ebay, no jegs, no summitt..
Tx_Cat is offline
post #17 of 133 (permalink) Old 03-01-2008, 11:36 PM
Burbank 95sc's Avatar
http://www.steeda.com/products/bilstein_strut.php
http://dagostinoracing.com/index.php...oducts_id=9451
96 GT - 4V,T-56,2.2 - video
01 F-150 - work beater
95 SC - 4.6 DOHC,4R70W -sold
94 LX - 4.6 SOHC - scraped
Burbank 95sc is offline
post #18 of 133 (permalink) Old 03-02-2008, 08:47 AM Thread Starter
http://www.shockwarehouse.com/site/p...-Mustang-Cobra
post #19 of 133 (permalink) Old 03-02-2008, 03:26 PM
Tx_Cat's Avatar
Awesome.. Apparently my searching capabilities sucks major... =0) I like the third link.. Thank T.M.
Israel
Tx_Cat is offline
post #20 of 133 (permalink) Old 03-02-2008, 07:43 PM
Tx_Cat's Avatar
Well, I scored back shocks for 50 shipped . Used of course, but shocks have 15k or so.. So I am happy, can't complain too much.
Trunk Monkey, for the fronts SP shocks, were does offered on the cobra's too?!
Tx_Cat is offline
post #21 of 133 (permalink) Old 03-02-2008, 09:11 PM
LOLA's Avatar
Cobra/Mustang use McPherson struts on the front. They will not fit MN12 cars.
LOLA is offline
post #22 of 133 (permalink) Old 03-20-2008, 02:05 PM
Tx_Cat's Avatar
So for the fronts, what ya'll recommend?! kyb gr2?
Tx_Cat is offline
post #23 of 133 (permalink) Old 03-20-2008, 03:05 PM
Thread Killer
midwestbird's Avatar
Thats what I used and they are no where near as stiff as the rears. Im looking for something else.
As of 10-20-06 DOHC POWERED
Painted Vista blue as of 08
242hp/251tq
14.39@96.01mph 5-17-08@ Byron Il
RobertP plate modded: 5-23-08
midwestbird is offline
post #24 of 133 (permalink) Old 09-27-2008, 10:34 AM
Has anyone tried the bilsteins and tokico HP's on their car? Are the bilsteins better or about the same?
96AlpineBird is offline
post #25 of 133 (permalink) Old 11-09-2008, 11:12 AM
crash00527's Avatar
Send a message via AIM to crash00527
what are the top 3 best brand shocks struts SC's
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #26 of 133 (permalink) Old 11-11-2008, 05:18 PM
crash00527's Avatar
that really sucks that bilstein fronts dont work on our cars.
anyone know what are good shocks/struts for 95 SC. i have konis on my camaro but dont wanna spend that much. i just want better than oem.
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #27 of 133 (permalink) Old 11-12-2008, 07:10 AM
PCD
Confirmed V6 Nut
Maybe put an ad in the wanted parts section of the market place looking for used front Bilsteins.
PCD is offline
post #28 of 133 (permalink) Old 11-12-2008, 03:41 PM
crash00527's Avatar
who would want used suspension? not I
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #29 of 133 (permalink) Old 11-12-2008, 05:10 PM
Illinois Chapter Director
TydlwavS's Avatar
Send a message via AIM to TydlwavS
crash, I sent you a pm.
"That is the worst looking car in the whole world. I'd rather look at one of your dingle berries"
Check out what we've been up to....
http://forums.tccoa.com/54-illinois-chapter/
TydlwavS is offline
post #30 of 133 (permalink) Old 11-12-2008, 05:12 PM
crash00527's Avatar
got it man. i replied
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
