Front Bushing Picture Thread with part numbers - Page 4 - TCCoA Forums
 2Likes
post #91 of 104 (permalink) Old 09-09-2015, 10:58 AM
Torinocator's Avatar
I know from my old Navy days that hydraulic lines may resonate when a ship's rudder is moved, at least on some of the older ships.
Steam lines can do the same thing. Maybe the TP bushings are just more sensitive to hydraulic line resonance than the OEM ones.
I discovered the brake fluid solution by accident BTW.
The TP design is completely different from the OEM one and Moog should have at least included a tech drawing with the bushing kit.
My perception is that someone could easily wind up chasing their tail from a troubleshooting standpoint if the brakes are also worn on their car when they install the TP replacement bushing kit.
All I know is at a minimum you WILL get steering wheel feedback if the front and rear strut-to-frame TP bushings are incorrectly reversed when they are put on. That's pretty easy to do without instructions because the conical OEM bushing is installed in front of the sub-frame.
Without instructions or a tech drawing, most people probably mimic the OEM setup and install the conical TP bushing on the wrong side of the sub-frame.
Use a tool, don't be one...
-Mark
1997 Thunderbird LX 4.6L
1970 Torino GT 351C 4V
...................................GT
Torinocator is offline
post #92 of 104 (permalink) Old 10-01-2015, 08:09 PM
After trying my luck on Ebay I managed to collect almost all the bits I need to rebuild my front end. The OEM Ford bushings cost a pretty penny and involved pulling the buy trigger on a zero feedback seller but it's all here now.
Now the real problem is figuring out what to do about the sleeves for the strut rod to frame bushings. Even though my Cougar is a garage kept Arizona car with 76,000 original miles with consistent bad luck it seems unlikely the old ones will be usable. If I'm wrong please please tell me. Sorta don't want to tear it apart till I get everything to together.
Anyone have the all of the dimensions of them? The oem stuff looks totally different from the after market junk. The pic on the first page is helpful but with a bit more info I may be able to get something made.
Freddy Cougar is offline
post #93 of 104 (permalink) Old 10-02-2015, 12:40 AM
Or, you know, you could contact Jay Richmond ( 98Mark8LSC here) and buy his units.
Fuelly
RalphP is online now
post #94 of 104 (permalink) Old 10-02-2015, 12:52 AM
The $170 ones? No thanks.
post #95 of 104 (permalink) Old 10-10-2015, 03:10 AM
I make stuff
Nope, the $135 ones.
They're 304 stainless steel and 360-degree TIG welded. They'll oulast everything else on the car....
As stated above, they're $135 shipped for the sleeves, but I also sell the Motorcraft OEM frame-side bushings for an additional $45 for the set.
CDsDontBurn likes this.
98mark8lsc is offline
post #96 of 104 (permalink) Old 10-10-2015, 05:19 AM
Good deal Jay!
I'm not sure if this was already mentioned in the thread, the washers need to be opened up for these? Is this something you can do?
post #97 of 104 (permalink) Old 10-13-2015, 02:27 PM
Sorry, beautiful work but that isn't going to happen. Pulled it apart and it was actually was in nice shape. The bushings even look pretty close to new. I love Grandpa owned, garage kept , Arizona cars cars. My collection of OEM bushings will wait for another time.
post #98 of 104 (permalink) Old 10-14-2015, 02:45 AM
I make stuff
Originally Posted by Rodeo Joe View Post
Good deal Jay!
Yes sir. The holes in the forward washers need to be enlarged to 1" I.D. I can do that, if necessary, but I need the washers sent to me beforehand. I try to keep some in stock, to send out, but unfortunately, a lot people have forgotten to send me their originals as a core. Out of 10 sets of them, I think I only have 1 set left.
post #99 of 104 (permalink) Old 11-02-2016, 12:58 PM
CDsDontBurn's Avatar
@98mark8lsc , do these sell like hot cakes, or do you make these still? I *may* need a set when I get to this part of my suspension rebuild.
Also, is the $170 price for left and right, or just is per side?
CDsDontBurn is offline
post #100 of 104 (permalink) Old 11-02-2016, 01:20 PM
Looks like they're (sleeves) $135 and I do believe it's (2) for both sides.
post #101 of 104 (permalink) Old 11-02-2016, 01:36 PM
Yes, I was saying $170 because I will want to get bushings as well. I'm thinking it's $170 for both sides, but I'd like to be 100% sure so I know how much needs to be spent.
post #102 of 104 (permalink) Old 11-02-2016, 01:48 PM
Actually I think it's $180! $135 for the sleeves and then another $45 for the bushings.
post #103 of 104 (permalink) Old 03-08-2017, 08:18 PM
Thundermonkey9's Avatar
Hey ya'll. I need some help. My brothers are busy and my husband is not a car dude. I know more than he does. Anyway I need to buy the front lower control arms for both sides as well as the bushing for the control arm to strut. The ball joint on the passenger side looks blown out and the bushing from the strut arm is blown out too. It makes a noise like when someone is jumping on a bed or doing something else...... anyway it's quite embarrassing driving around town. Sometimes it does it and sometimes it doesn't. Sometimes it feels like I'm driving on ice and sometimes it acts just fine. I cannot do high speeds anymore cause it pulls the right something awful, especially when the brakes are applied. I almost was flung into a semi then the middle divider on the freeway. Thank God I am quick with the steering. Anywho sorry for the story but advice would help. Thank you.
Thundermonkey9 is offline
post #104 of 104 (permalink) Old 03-09-2017, 08:18 PM
What exactly is the question?
rodsv6cougar@cs.com
