Thunderbird/Cougar Steering Shaft Mod - TCCoA Forums
post #1 of 30 (permalink) Old 06-30-2012, 08:21 AM Thread Starter
Rayo's Avatar
Have you been wanting to add a set of Headers to your Thunderbird or Cougar?
Sure..Alot of us have..
The problem we run into is the stock steering shaft won't clear a set of nice Headers..
I'm going to show you all the parts you need..
So that you can Modify your Steering Shaft assembly to clear those Aftermarket Headers you've been wanting to install..
You can see the subtle differences between the years..
If you keep the stock Steering Shaft (Lower Shaft) installed you may or may not be able to clear your Aftermarket Headers..
I've created a Diagram with Part Numbers..So you know what goes where..
I'm going to outline a Parts List..
We'll start at the Steering Column U-Joint, and end with the replacement of the stock Steering Column (Rag Joint)..
Flaming River Parts List
Steering Column U-Joint: FR1716DD
Center U-Joint: FR1716DD
3/4" Shaft Material: FR1850
Support Bearing: FR1810
Bottom U-Joint: FR1715DD
The Bottom U-Joint (FR1715DD) replaces the factory Steering Column (Rag Joint)..
All-Star Performance
Firewall Support Bearing:ALL52130
I recommend using the Red Loctite for assembling your parts!
Here are the dimensions for the following parts:
FR1716DD-3/4" ID x 3/4" ID
FR1850-18" Long x 3/4" OD
FR1810-3/4" ID
FR1715DD-3/4" ID x 36 Spline
ALL52130-3/4" ID
This should make things easier for all of us!
Here's 392Bird's page on how to do it http://members.tccoa.com/392bird/birdworka1.htm
1991 Ford Thunderbird Sport
Rayo is offline
post #2 of 30 (permalink) Old 06-30-2012, 07:28 PM
Thanks for posting. I may have to do this one day.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------300RWHP est.---------who knows/who cares
10.740@127------------13.842@103.08-------16.1@
BLOWN38 is offline
post #3 of 30 (permalink) Old 06-30-2012, 07:46 PM Thread Starter
Rayo's Avatar
Np...
I wanted to put all the information for this Mod in one place..
Rayo is offline
post #4 of 30 (permalink) Old 09-10-2012, 12:39 AM
97Tturd's Avatar
So the "aftermarket" headers.... shorty, mid length, long tubes??? And from a 99-04 2v mustang?
just curious
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #5 of 30 (permalink) Old 01-23-2013, 09:15 AM
curious as well. Just what aftermarket headers does this allow? 2v mustang (99+) headers are cheap....(AM has some pacesetters for 250$...)
son of mad dog is offline
post #6 of 30 (permalink) Old 01-23-2013, 01:21 PM Thread Starter
Rayo's Avatar
The Steering Shaft Mod has been done predominantly on 5.0L/5.8L pushrod MN12s..
I don't know of anyone that has done the Steering Shaft Mod on a 4.6L MN12??..
Maybe someone that has done the Steering Shaft Mod on a 4.6L MN12 will speak up??
One of the problems a 4.6L MN12 owner could face is the fact that the 4.6L Engine is wider than the 5.0L/5.8L..
Which might cause an issue trying to do the Steering Shaft Mod..Considering the lack of space compared to its pushrod counterpart..
You could always become a pioneer, and just try it!..You know..Buy the Steering Shaft Mod Parts & a set of cheap Longtubes..
Rayo is offline
post #7 of 30 (permalink) Old 01-23-2013, 01:48 PM
Slightly Disjointed
Mark VIII guys do it all the time. A lot of them swap in Cobra Manifolds and do the steering shaft mod to fit them.
post #8 of 30 (permalink) Old 01-23-2013, 04:33 PM
1 thing to note, the firewall support is not needed to make it work.
Its just extra support.
I tried to run one, but I could not get it to work right, so I said screw it.
If you want to run one, by all means, go ahead. I'm just stating what worked for me.
post #9 of 30 (permalink) Old 01-23-2013, 04:50 PM
Slightly Disjointed
Also, if you wanted to, you can make a steel plate to cover the hole and hold the support bearing on the firewall and omit the frame rail support bearing too.
post #10 of 30 (permalink) Old 01-23-2013, 09:41 PM Thread Starter
Rayo's Avatar
That's a slightly different Steering Mod IIRC..Basically upgrading the stock rag joint to the flaming river piece to allow header clearance..
I think you're referring to this Mark VIII Steering Mod...or this [DLF] Flaming River Rag Joint Swap
Did you take any pics of that Mark VIII you ransacked to get your Marauder Engine out of?...
I seem to remember you mentioning something about that car having some sort of steering mods..
Anyone else thats done the Steering Shaft Mod listed here on a 4.6L..Please post some pics..
Rayo is offline
post #11 of 30 (permalink) Old 01-23-2013, 10:42 PM
Slightly Disjointed
There's more than one way to skin a cat. The "standard" mod for them is extending the splined end straight out and moving the pivot towards the shock tower. Essentially the same routing as a Fox/SN95 shaft but without the necessity of a firewall support bearing. That's not the only way to do it though. The Mark VIII I got my Mach motor out of had the 392bird style steering shaft mod with the stock (but very deformed) firewall boot to keep the seal.
tbirdtess set his up by using a sheet metal plate over the firewall hole and adding a support bearing(ala SN95 Mustang). I believe he even used OEM U joints and shaft pieces. I'll probably do something similar.
post #12 of 30 (permalink) Old 01-24-2013, 08:39 AM
I now have just a small hole for the steering shaft to fit through.
Ahh, this is back when I first installed it, using foxbody mustang manifolds.
post #13 of 30 (permalink) Old 03-18-2013, 03:37 PM
Moderator & Teksid Whore
guitar maestro's Avatar
I highly doubt this mod would clear 4.6 Longtube headers in an mn12 engine bay. The spot available for the support bearing is right where the #5 and #6 primary tubes go.
This is likely more feasible for pushrod 5.0 engines. I'd love for someone to actually turn wrenches and do this with 4.6 Longtube headers. Until then, this "article" is kinda lame considering it is not specific as to which engine configuration this applies to and has not been done by the OP. Will I be able to add a set of 1-7/8 headers with this steering shaft mod?? According to this article, I should be able to.........
guitar maestro is offline
post #14 of 30 (permalink) Old 03-18-2013, 03:49 PM
Slightly Disjointed
If you lose the eyelet bearing mounted to the frame rail and make a shaft-boot delete plate with a support bearing mounted higher up(towards the booster) the shaft will come out almost exactly where the Mustang steering shaft goes in relation to everything.
post #15 of 30 (permalink) Old 03-18-2013, 04:13 PM
prove it
post #16 of 30 (permalink) Old 03-18-2013, 04:22 PM
Slightly Disjointed
Only one I can think of who did it that way is tbirdtess. His is routed the same way it is on Mustangs
And don't forget, many 4.6 Mustang Longtubes have the steering shaft run between the primaries, rather than have all the primaries bundled out of the way
post #17 of 30 (permalink) Old 03-18-2013, 05:58 PM
still waiting.......
I don't see any pictures of MN12s with 4.6 longtube mustang headers using the steering mod......
post #18 of 30 (permalink) Old 03-19-2013, 09:01 AM
yeeeeeeep.
yall pretty much said the same thing.
post #19 of 30 (permalink) Old 03-19-2013, 09:20 AM
slick59's Avatar
Do you think this will work for us SC guys and using the mustang 3.8 headers?
I can explain it to you, but I can't understand it for you
Tim
1994 Cougar 3.8L Supercharged
1990 Tbird Supercoupe
slick59 is offline
post #20 of 30 (permalink) Old 03-19-2013, 10:41 PM
yeeeeeeep.
kinda sorta. His comments are pure speculation as he doesn't have a 4.6 to look at, let alone tinker with, where as my doubt comes from actual experience fitting in 4.6 longtubes.
post #21 of 30 (permalink) Old 03-19-2013, 11:08 PM
Paulyrats's Avatar
ohh this is great, just added on to my to do list!
good post... -Paul
Paulyrats is offline
post #22 of 30 (permalink) Old 03-20-2013, 11:20 AM
^ gathering that you did not read the posts about this not helping 4.6 owners...
post #23 of 30 (permalink) Old 06-20-2013, 02:08 AM
Dreadful_Knight's Avatar
So, just out of curiosity, which model/year mustang can I pull this part from?
'91 Sport 5.0 HO - AOD - JBL Premium Sound w/ Kenwood eXcelon deck - Black Leather LX interior w/ Lux Light
- 17" Sport Edition Wheels wrapped in Michelin 225/50's - Custom Flowmaster exhaust - GT40 heads - Electric Fan - '92 Sport Bumper
Planned Mod's
-Cobra intake (upper/lower) / SC MAF/30#inj / Dual Exhaust/headers
-'99 CV/PI 4" Aluminum DS / MK8 Disc Rear/HS/LCA/11.5" Front Disc
-M5R2 5-Speed / 3.27 LS Diff / SC F/R seats
Dreadful_Knight is offline
post #24 of 30 (permalink) Old 06-20-2013, 02:57 AM
Slightly Disjointed
None. It's a flaming river part.
post #25 of 30 (permalink) Old 04-16-2016, 01:18 PM
tbirdtess's Avatar
NOT
Hello all. My mod was for a 5.8 using all Thunderbird parts!
tbirdtess
Paul Nm12tbirdracer@aol.com
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #26 of 30 (permalink) Old 04-16-2016, 09:10 PM
Slightly Disjointed
Originally Posted by tbirdtess View Post
NOT
[IMG]http://i180.photobucket.com/albums/x88/tbirdtess/HPIM0371.jpg[/IMG
tbirdtess
I knew that's what you were using, I was responding in that post that the original write up used a flaming river part, not a stock mustang one. I actually plan on copying your setup
post #27 of 30 (permalink) Old 06-09-2017, 01:58 AM
NOT
tbirdtess
Is there a writeup somewhere or more pics? I would like to do this without spending a bunch of C-notes.
post #28 of 30 (permalink) Old 06-09-2017, 11:43 AM
gordonm1's Avatar
Somebody above asked about what long tubes work for the 5.0. I'm kinda curious what long tubes will work with which heads and this mod? Wouldn't the head choice make a difference? E7 vs GT40 vs Trick Flow/aftermarket?
gordonm1 is offline
post #29 of 30 (permalink) Old 06-09-2017, 03:31 PM
S4gunn's Avatar
E7, GT40, and some aftermarket heads have the exhaust ports in the same position so the same long tubes should work between either.
GT40P and some of the higher end aftermarket heads have different exhaust port and/or spark plug port locations which would require different piping.
-g
S4gunn is offline
post #30 of 30 (permalink) Old 06-10-2017, 01:30 PM
Slightly Disjointed
I did mine the way Tbirdtess did his more or less, I've since redone it due to switching to a Cobra rack with a different input. The only parts here I spent money on was the firewall bearing, aluminum plate to bolt to the firewall and hold it, and the 36 spline U joint - which is absolutely necessary unless you want your steering wheel clocked sideways with the wheels pointed straight. Otherwise just a shaft section from a gutted junkyard steering column and an extra stock U- joint.
More details in this post XR7-4.6's disjointed Build Thread, now a 4V snob
