Bilstein racing shocks - Front Shock Custom Design - Page 2 - TCCoA Forums
post #31 of 47 (permalink) Old 07-13-2012, 04:05 PM Thread Starter
tbirdtess's Avatar
Originally Posted by EvilMooseofDoom View Post
Subscribed.
My only worry is that the shock shaft itself may not be strong enough to handle the spring loads, as the stocker is designed to be a coil-over setup, and I don't think this one is.
Of course, my worries may be unfounded, however, paranoid people live far longer lives.
The shock I chose is a Coilover Shock.
Test 2 tomorrow
Paul Nm12tbirdracer@aol.com
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #32 of 47 (permalink) Old 07-14-2012, 11:57 PM
EvilMooseofDoom's Avatar
Test 2 tomorrow
Excellent. As usual, keep us posted, since most of us are too cheap to try this ourselves.
EvilMooseofDoom is offline
post #33 of 47 (permalink) Old 07-15-2012, 12:32 PM Thread Starter
tbirdtess's Avatar
More issues
I had to put in a heavier LF spring at the track. Wheel was bouncing!
So I only had the RF in. But I think I need to tie the upper shock shaft to the upper mount. I don't think the shock is compressing right.
I have an Idea.
Let me work on it.
351W 2bbl.
C-4 Auto
3.90 open rear
post #34 of 47 (permalink) Old 07-15-2012, 06:41 PM
...yeah. I was worried about that. I'm thinking there are some side-loading issues.
post #35 of 47 (permalink) Old 07-15-2012, 08:09 PM Thread Starter
tbirdtess's Avatar
shoulder
I don't think it's side load.
our shocks have a shoulder that the top mount sits on.
This shock doesn't.
Might have to put the top eyelet back on
351W 2bbl.
C-4 Auto
3.90 open rear
post #36 of 47 (permalink) Old 07-18-2012, 03:59 PM
dode's Avatar
This is the first I have seen this thread. I messed around with this a little once. My idea was to remove he eyelet on the bottom and bolt it through the bottom and not through the side like you did. It should gain a couple of inches. The only thing I don't know is if there would be enough control arm clearance. I never got it completed though. I do have one of those Bilstein's though that I could play with....I think it is a 3535.
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #37 of 47 (permalink) Old 07-25-2012, 09:18 PM Thread Starter
tbirdtess's Avatar
update:
I just tried an AFco small body shock(1.64 Dia.) in the stock housing.
It fit!
Going to use as LF shock. Different valving. $80.00 each
The upper mount looks like it will work.
I race Saturday If I get time to get it in we will see.
still working on the racing nose. ($100)
Bilstein shock mod
Still testing
351W 2bbl.
C-4 Auto
3.90 open rear
post #38 of 47 (permalink) Old 08-27-2012, 11:15 PM
Slightly Disjointed
How's this setup holding up Paul? I didn't notice the pics until now
post #39 of 47 (permalink) Old 09-07-2012, 07:03 PM Thread Starter
tbirdtess's Avatar
Shocks
Well they work good when I bolted to the top.
Don't look great, & you wound have to cut up your tops & the top of the tower.
One might make an upper mount & weld on threaded nuts.
Then you would not have to cut the tower.
You would need a proper spring/shock compressor.
Next is the rear shocks. Need to fix a push out of the corner.
send me a PM, will point out the parts I used.
351W 2bbl.
C-4 Auto
3.90 open rear
post #40 of 47 (permalink) Old 09-08-2012, 11:50 PM
Slightly Disjointed
Well it may not look pretty but the SC ARC covers will certainly do wonders in covering it up
post #41 of 47 (permalink) Old 04-02-2013, 10:11 PM
It fit!
Bilstein shock mod
Still testing
Are these shocks something I might be able to get from Speedway?
So yeah, I bought two Lincolns in a week.
My LarryLand Automotive Facebook Page:
https://www.facebook.com/pages/Larry...61642343862942
My Scribd.com garbage: http://www.scribd.com/larry_vanzandt
post #42 of 47 (permalink) Old 04-20-2014, 10:19 PM Thread Starter
tbirdtess's Avatar
Afco
I got my Afco's from our local race shop. Mine was Bicknell.
I'm sure you have one near you.
My Bilstein's came from DAY Motor Sports. They are in Texas.
They have AFCO's as well.
351W 2bbl.
C-4 Auto
3.90 open rear
post #43 of 47 (permalink) Old 04-21-2014, 11:00 AM
Yes, good question.
post #44 of 47 (permalink) Old 09-18-2014, 10:29 AM
Yes, good question.
im also curious how this setup made out. the selections for our cars are nil.
MangBangers is offline
post #45 of 47 (permalink) Old 09-18-2014, 03:36 PM Thread Starter
tbirdtess's Avatar
Stinking rules
Between lack of time & rule changes i have been out.
I need a better top mount. someone here was making one i liked.
I can't use an eye bolt upper mount.
I also have to change the gas pedal, solid linkage style.
Engine still apart. but going with long duration cam. about 300* duration.
Got parts for pumpkin that broke when an axle gave up.
Currently my track is in limbo.!
past promoter said no more oval racing.
owner said there will be.
351W 2bbl.
C-4 Auto
3.90 open rear
post #46 of 47 (permalink) Old 09-18-2014, 05:03 PM
That makes absolutely no sense! I could almost understand if they said you have to change to a cable if they were worried about a rod going into the car and hurting a driver, but why force everyone to adapt an outdated design?
post #47 of 47 (permalink) Old 01-02-2015, 01:02 PM
Sorry to hear about the Track being out; Developers are taking over...
We lost the "Atomic Speedway" here a few years back; it's a truck maintenance facility now.
Do you remember who was making the upper mounts you mentioned?
I couldn't find anything...
I'd like to get one with the center metal bushing in a size that will clear the racing Koni shocks; they're 14mm instead of 12mm diameter shafts.
And they're a little harder to mount; (and expensive, and...) but I'd buy a set if I could find all the parts to mount them.
Grog6 is online now
