Bilstein racing shocks - Front Shock Custom Design - TCCoA Forums
post #1 of 47 (permalink) Old 06-30-2012, 07:23 PM Thread Starter
tbirdtess's Avatar
Hello
I hope to have racing shocks up front.
Bilstein
Keep in mind these shocks are oval track shocks.
Bilstein SG series. 7" 36mm (1.42")
I drilled a small hole in the bottom of my worst shocks I had.
Careful shocks are under pressure.
I then cut the shock top off. Used my cut off saw.
Cleaned it out
I then drilled A 1/2" hole 1/2" down from lower bracket top.
Drilled some weld spot out.
Slid the shock body in. I used electric tape on the end to make up the space.
So shock won't rattle around.
Bolted in place with a grade 8 bolt & poly-lock nut.
Removed the other Eye bolt end. Assembled the spring as normal.
Still looking for another upper nut. (lock nut) it's finer than 10mm 1.0
I started with this:
Then this:
Photobucket
finished with this:
Photobucket
They are in. will be racing Saturday
Paul Nm12tbirdracer@aol.com
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #2 of 47 (permalink) Old 07-01-2012, 07:56 PM
Slightly Disjointed
Do you have the dimensions of that shock? Part #? I've been very seriously thinking about doing something similar!
Great job! I definitely look forward to hearing how they perform
post #3 of 47 (permalink) Old 07-01-2012, 08:57 PM
pendejo
druggles85's Avatar
Do you have the dimensions of that shock? Part #? I've very been seriously thinking about doing something similar!
X2 we need more info
"Yesterday, upon the stair,
I met a man who wasn't there.
He wasn't there again today,
I wish, I wish he'd go away..."
druggles85 is offline
post #4 of 47 (permalink) Old 07-01-2012, 10:03 PM
djoc2000's Avatar
X3 !
You can go as fast as your money will let you
djoc2000 is offline
post #5 of 47 (permalink) Old 07-02-2012, 08:17 PM
Maic's Avatar
Nice, let us know how stiff/soft they are. Don't know if that matters on'a Oval track, but what happened to your spring insulator?
The upper shock(Strut) mount looks like its on is way out!
Maic.
Maic is offline
post #6 of 47 (permalink) Old 07-02-2012, 08:51 PM Thread Starter
tbirdtess's Avatar
spring insulator
I left it off. Can't hear sh!t @ WOT!
These aren't T-bird springs either.
The shocks are way stiffer than the Koni's I took off.
The valving is 5.5
Plus I added camber. Makes the sway bar off center.
351W 2bbl.
C-4 Auto
3.90 open rear
post #7 of 47 (permalink) Old 07-02-2012, 09:26 PM
Very nice work Paul~!
Which springs are you running?
post #8 of 47 (permalink) Old 07-02-2012, 10:55 PM
jhiland32's Avatar
Wow now thats something I never thought about pretty cool.
Jason H.
Mods:
jhiland32 is offline
post #9 of 47 (permalink) Old 07-03-2012, 03:32 PM
djoc2000's Avatar
Which bilstein are they?? Part # ??
djoc2000 is offline
post #10 of 47 (permalink) Old 07-04-2012, 08:51 AM Thread Starter
tbirdtess's Avatar
SG series
I bought them from Day Motorsports.
Bilstein S7G- 5555
They seem stiffer than the Koni's I took off.
The springs are from a 85 LTD II. They were broken So I helped my buddy change them.
I can't use lowering springs because I have to raise it to 7" ground clearance.
Racing rule.
351W 2bbl.
C-4 Auto
3.90 open rear
post #11 of 47 (permalink) Old 07-04-2012, 09:02 AM
Thread stuck for innovative design.
I hope to build a set of these for my car some day. Since the Koni's are history.
BTW Paul, what are your plans for the Koni's that you took off? Might they be for sale???
post #12 of 47 (permalink) Old 07-07-2012, 11:44 PM Thread Starter
tbirdtess's Avatar
7's are too tall.
Opened the hood today & saw the shocks were sticking about 2" or more
up above the spring.
So anyone with a lowered car maybe the 6" version.
I am going to more the shock to the lower hole.
Closer the the shock base. ( my first hole)
I lost the nut on the RF. I think it's 11mm but with a very fine thread.
finer than 11mm x 1.0
351W 2bbl.
C-4 Auto
3.90 open rear
post #13 of 47 (permalink) Old 07-08-2012, 09:37 AM
djoc2000's Avatar
I have the bilstein cobra rears. Which valving would be comparable? or should this question go to bilstein ?
djoc2000 is offline
post #14 of 47 (permalink) Old 07-08-2012, 01:42 PM Thread Starter
tbirdtess's Avatar
Bilstein
You would have to go to Bilstein.
I don't quite understand the valving numbers.
Also different series use different numbers.
351W 2bbl.
C-4 Auto
3.90 open rear
post #15 of 47 (permalink) Old 07-08-2012, 05:28 PM
Rayo's Avatar
With progress..Failure is to be expected ..
I'm sure you'll get the bugs worked out Paul..
When you do..You can post the results that work..
That way anyone interested in doing this..
Have all the details to make this Mod "work properly"..
Good Luck!
1991 Ford Thunderbird Sport
Rayo is offline
post #16 of 47 (permalink) Old 07-11-2012, 03:48 PM
djoc2000's Avatar
Exclamation
Just got off the phone with Bilstein. They were able to get valving info for me. The original T-Bird Bilstein fronts (B46-1505)were 730 compression/1090 rebound. Rears (B46-1506) 650 compression/1460 rebound. The Cobra Bilstein HD rears 800 compression/2170 rebound. He said that you can order the SG series with any valving you desire.
I might see what it would cost to have the SG series built with the original (B46-1505) 730 compression/1090 rebound valving,
Im sure if you do the math someone could figure a good match for the cobra Bilstein rears, as our frontends are heavier then the Cobra. Hence those front rates wouldnt be accurate if compared to T-Bird fronts.
Okay I did some math(thank god for google) If you are running cobra HD rears a good match would be 896 compression/1620 rebound for fronts. I figured this by comparing the ratio from the original Bilsteins for the T-Bird. My math is rusty so give a little wiggle room.
djoc2000 is offline
post #17 of 47 (permalink) Old 07-11-2012, 04:06 PM
The fronts would be closer in weight to a Cobra for a PI swapped Tbird with the AL block vs the iron block.
I have the Cobra Bilstein rears on my car and I'm very happy with them.
post #18 of 47 (permalink) Old 07-11-2012, 08:47 PM
Rayo's Avatar
Cobra Bilstein Rear Shocks
Correct me if I'm wrong but you're running:
Vogtland Lowering Springs..
Sport Front Shocks
Cobra Bilstein (Sport) Rear Shocks
What is the "feel of the ride" with your set-up on Dippy Roads?
In most cars I've driven..Once you get up to 80+ Mph..
It feels like you're floating on the road, and the suspension starts making "squishy sounds"..lol
What is the "feel of the ride" with your set-up..Once you get up to 80+ Mph on Dippy Roads?
I like the feel of a car firmly planted to the road..
Rayo is offline
post #19 of 47 (permalink) Old 07-11-2012, 09:07 PM
The one thing that I would add to the (obviously) design. Make sure you incorporate a boot or dust shield over the rod so that it doesn't come in contact with dirt or debris from the road.
post #20 of 47 (permalink) Old 07-11-2012, 09:31 PM
Sport Front Shocks
http://www.capmac.org/iphonesig/wp-c...bumpy-road.png
Yes, you have my set up correct. To clarify I have the 1.6" drop Vogtland springs with poly spring cups in the rear, the front is as you said (sport shocks with the vogtland springs). I have replacement rubber OEM top shock mounts in the front.
I also have a 1.25" ADDCO anti-swaybar in the rear with the stock anti-swaybar in front.
I certainly wouldn't be doing 80+ on the road pictured in your post.
The "feel" of my car on any road or track is very responsive. I feel all the imperfections in the road surface - not that that's a bad thing - the suspension telegraphs the contour of the road surface to the driver very clearly.
The suspension I have is very, very tight. No wallowing in the corners, no "squishy", soft or floaty feel. The car goes where I point it and, to use another cliché, "corners on rails!". I really need to get more supportive seats and they're on the long range mod list.
It's truly a canyon carving performance suspension set-up and is probably way firmer than most people would be comfortable driving. Having said that, I have taken the car on many a road trip and even to a road course. The car is drivable over long distances but you'll need to stop to stretch your legs and scratch your butt more often than if you were driving something with a softer suspension.
I don't daily drive the car and probably would be miserable doing so. But, for a weekend warriors car it's simply amazing.
If you're looking for the ultimate canyon carving suspension you could either mirror what I've done or talk to our resident T-Bird autocrosser Kelsey Smith to see what he's done with his cars suspension. I don't think it's much different than mine except he has lower 3.27 gears and matched 245/45 tires vs my staggered 245/45 front and 275/40 rears. We both have trac-locks in the rear diff.
post #21 of 47 (permalink) Old 07-11-2012, 09:40 PM
Rayo's Avatar
Thank You TM..
That's what I needed to know..
Do any of your "poly" suspension components annoyingly squeek?
Rayo is offline
post #22 of 47 (permalink) Old 07-11-2012, 09:44 PM
Ron what is your monkey doing? lol (off topic, but I gotta ask )
post #23 of 47 (permalink) Old 07-11-2012, 10:07 PM
Thank You TM..
Do any of your "poly" suspension components annoyingly squeak?
You're welcome. Glad I could help.
I did put poly bushings on the front sway-bar at one time and they were very squeaky, noisy, annoying so I switched back to rubber bushings.
I do have poly bushings on the rear anti-swaybar that are so quiet I forgot to mention that they're there; the rear poly spring cups are also very quiet.
He's stretching his legs, eating a banana, chucking the peel and scratching his monkey butt.
What did you think he was doing? (Don't answer that, it's a rhetorical question.)
post #24 of 47 (permalink) Old 07-11-2012, 10:11 PM
I did put poly bushings on the front sway-bar at one time and they were very squeaky, noisy, annoying so I switched back to rubber bushings. I do have poly bushings on the rear anti-swaybar that are so quiet I forgot to mention that they're there.
haha I thought he was stretching his legs, eating a banana, farting lightning out of his monkey butt. lol
post #25 of 47 (permalink) Old 07-12-2012, 06:52 AM
Seasoned Geek
He he thanks for the smile this AM Josh
post #26 of 47 (permalink) Old 07-12-2012, 08:09 AM
Rayo's Avatar
Aside from the squeaky poly bushings on the front sway-bar..
Did you have to "lube up" any of your other Poly suspension components to keep them from squeaking??
Rayo is offline
post #27 of 47 (permalink) Old 07-12-2012, 09:15 AM
I put some grease on the rear anti-swaybar bushings but I didn't do anything with the rear sping cups.
Are you going to build your suspension up soon? What are your plans?
post #28 of 47 (permalink) Old 07-12-2012, 01:19 PM
EvilMooseofDoom's Avatar
Subscribed.
I was thinking of doing something similar with my own heap, but not in this direction.
My only worry is that the shock shaft itself may not be strong enough to handle the spring loads, as the stocker is designed to be a coil-over setup, and I don't think this one is.
Of course, my worries may be unfounded, however, paranoid people live far longer lives.
EvilMooseofDoom is offline
post #29 of 47 (permalink) Old 07-12-2012, 03:03 PM
Slightly Disjointed
The shaft isn't under spring loads unles it's at full droop (car in the air) but that's the case with any shock. The shock body is the only part under stress driving the car but that part is reused from the stock one.
post #30 of 47 (permalink) Old 07-12-2012, 05:41 PM
Rayo's Avatar
Yes..I'm trying to get an appropriate parts lists together..For what I'm trying to accomplish with my suspension set-up..
I figured you would be good person to ask..Since you've been running your suspension set-up for a few years now..
Getting all the kinks worked out of it, and what not..
At the moment I'm running my all stock Sport Suspension..Which is actually in really good condition..Since my Sport isn't my DD..
Just to get an idea..
Here's a little run down of some of the parts on my "have or need" list:
Stock Sport Sway bars front and back..
Stock Rubber Sway Bar Bushings front and back..
"Different" Coil Springs front and back..
New Motorcraft Shock Mounts in the front..
Poly rear spring cups..
"Different" Front Shocks for Higher Spring Rate Coil Springs..
"Undecided" on Rear Shocks (Possibly Bilstein Sp)..
If I'm not satisfied with the end result..I may end up upgrading to thicker Sway Bars as well..We'll see..
My goals suspension wise are for corner carving..Nothing that knocks the fillings out of your teeth..But..Stiffer than my current set-up..
*Anyone interested in stiffening up their front suspension could benefit from Paul's "Bilstein Shock Mod"..
Rayo is offline
