Public Service Announcement: Rear Upper Control Arm to Subframe Bushings - Page 2 - TCCoA Forums
 3Likes
post #31 of 70 (permalink) Old 02-10-2014, 08:15 PM
I make stuff
I don't want to break any forum post count rules, but feel free to contact me via PM with any questions.
I'm also available through the Lincoln forums where I'm a very-well established member.
98mark8lsc is offline
post #32 of 70 (permalink) Old 02-14-2014, 01:02 AM
KEVIN8989's Avatar
I think I got the bad ones too. Moog part # k8562 http://s129.photobucket.com/user/Kev...44ccf.jpg.html
KEVIN8989 is online now
post #33 of 70 (permalink) Old 02-14-2014, 05:51 AM Thread Starter
Yep. Don't bother installing those.
rodsv6cougar@cs.com
post #34 of 70 (permalink) Old 02-17-2014, 04:33 PM
I changed mine a couple of years ago and yes, I used the white ones.
Why in the world would Moog make one that does not adjust? That makes absolutely no sense.
Like making a solid shock absorber.....
~Rick
TCCoA Sig
post #35 of 70 (permalink) Old 02-17-2014, 06:34 PM
nall_one's Avatar
yeah, isnt it great... i thought their was something fishy when i looked over my new ones before install. wish my OE's hadn't been supper loose and clunky or i would have just left em.
95 Deep Jewel Green 40th Anniversary Bird / Stock SOHC 170k FRPP PI intake swap, filter relocated! 97 Mk8 4R70W, Jmod, 3L27 / energy susp rear spindle, and cobra arm bushings, Tru-Cool Max/radiator cooler bypassed, 93 Mk8 shaft, and LCAs, 225/60r16 Michelin Defenders on Windstar twin 5spokes, Vogtland 1.6drop springs, Tokico Blues, PBR, and rear-disk swap, 89 SC swaybars
nall_one is offline
post #36 of 70 (permalink) Old 02-18-2014, 05:23 PM
Overkill Fetish Freak
Somofabeeotch...
I just pulled the lowers off for the toe comps and bushings and of course it turns out I had the weak skool uppers pressed in about a year ago. I wonder if RA would honor a return since I'm sure they are aware of the issue and they can check my account? I do order from them a bunch so I guess it's worth a try. You got to love the 40mm wrench hookup for the inner rear nuts from hell!
-Scott
Dr. FrankenCougie is offline
post #37 of 70 (permalink) Old 02-18-2014, 06:22 PM
-Scott
Dear Summit racing...
I'm ordering one of these; I always end up using a large crescent wrench, lol.
post #38 of 70 (permalink) Old 02-19-2014, 10:16 AM
This just in...
Hello Scott,
We have called Moog on this issue previously and they have verified that the "bad" design is their intended design specification. We contacted them about this exact issue and they have stated that the parts that were received fit their design specifications for those parts.
If you do order those parts you will receive the same parts that the others have received and rejected.
Thank you,
Casey
RockAuto Customer Service
Ok, so I guess things will get interesting if/when Bill runs out of the correct bushings.
-Scott
post #39 of 70 (permalink) Old 02-19-2014, 10:35 AM
Sounds to me like we need to speak to someone at Moog directly. Presumably a reputable company like Moog would want to know if their design is flawed.
post #40 of 70 (permalink) Old 02-19-2014, 11:35 AM
I make stuff
Sadly, it seems like Moog is slowly and ever-more-increasingly becoming less and less of a "reputable company". As much as I hate to say it.
I think if RockAuto did indeed call/talk to them about it, and THEY didn't get anywhere with them, they must not care that much. I'm sure RockAuto has to be one of their largest carriers of parts (On the internet, at least. Maybe not compared to physical stores like Advance Auto), and for them to basically be "blown off" like that, is pretty astounding to me.
post #41 of 70 (permalink) Old 02-19-2014, 06:50 PM Thread Starter
-Scott
Did RA end up sending you a refund?
rodsv6cougar@cs.com
post #42 of 70 (permalink) Old 02-19-2014, 07:34 PM
I'd have to agree with that. Over the last few years we've seen identical packaging/labeling contain different [styles of] parts, and said parts have been failing at "cheap eBay parts" intervals. I myself had Moog front sway bar endlinks go bad in under a year...
I wonder if the ACDelco branded bushings have any chance at being correct...
97 Laser Red Thunderbird LX 155k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
96 Ivory Mark VIII 230k, stock 4.6 32v on coils; New engine at 185k
post #43 of 70 (permalink) Old 02-19-2014, 08:05 PM
I make stuff
I had a set recently that was the correct style. I want to say it was the ACDelco's, but can't remember 100%. I'm about 98% sure that's what they were. Lol.
post #44 of 70 (permalink) Old 02-19-2014, 08:11 PM
Moderator & Teksid Whore
guitar maestro's Avatar
-Scott
you should ask them how it is possible that it IS the intended design, when "Christy" had already told me she called Moog and they verified that it was a bad batch.
guitar maestro is offline
post #45 of 70 (permalink) Old 02-19-2014, 08:33 PM
I don't have time for more of their nonsense so I just ordered what I needed from SCP and called it a day.
I am very disappointed with both RA as well as Moog for total suck.
-Scott
post #46 of 70 (permalink) Old 02-24-2014, 10:50 PM
nall_one's Avatar
ordered another set of these from my oreilly store, both the same junk >.>
guess ill order another two and see what they look like... if i keep sending them back warranty maybe someone will notice... i even wrote out why there crap on the warranty tags
i also sent an email to fed mogul. doubt ill get anything helpful from them, but we'll see, and ill post the response here.
definitely want these things off my car though, their hard as rocks and i have little to no suspension travel from them. i mean even with the tokicos and vogtlands i should have something. speed-bumps 1" high feel like boulders...
and im pretty sure its them making this weird creaking noise... ive got tons of grease in my polys. those energy suspensions came with like 15 little packets of the stuff and i used all of it
nall_one is offline
post #47 of 70 (permalink) Old 02-27-2014, 11:26 AM
I got the Raybestos ones from Rock Auto a couple months ago and they are the good ones. I have yet to install them though.
1995 Thunderbird LX 4.6- 20% tint, removed air silencer and not much else! (Mustang hubs, Cobra brakes, Vogtland springs, Mark VIII LCAs, Sport shocks and more waiting to be installed)
2013 DIB GT 301A 6-speed- 15% tint, Kooks 1 7/8 mid lengths, off-road x and cat back, Barton 2-post bracket, JPC clutch line, Koni Yellows, Maximum Motorsports C/C plates, BMR K-member, A-arms, UCA & Mount, LCAs and relo brackets, Steeda Ultralites and PHB, Shaftmasters DS, Brembo wheels- Tuned by AED
Dave_6 is offline
post #48 of 70 (permalink) Old 03-20-2014, 12:49 AM
KEVIN8989's Avatar
I got the raybestos ones too they look like this. http://s129.photobucket.com/user/Kev...72a1f.jpg.html I just hope they work.
post #49 of 70 (permalink) Old 03-20-2014, 05:32 AM
I got the raybestos ones too they look like this. I just hope they work.
Looks good to me.
-Scott
post #50 of 70 (permalink) Old 03-20-2014, 05:52 AM Thread Starter
Yep, those are the correct design.
rodsv6cougar@cs.com
post #51 of 70 (permalink) Old 03-20-2014, 01:03 PM
jco1385's Avatar
Are those 2 pics of the same bushings? The second pic looks just like the wrong ones. The first pic looks like it has the plastic rings on it.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #52 of 70 (permalink) Old 03-20-2014, 04:18 PM Thread Starter
Those are two different bushings. The first picture is the correct design. The second picture is the flawed design.
rodsv6cougar@cs.com
post #53 of 70 (permalink) Old 03-20-2014, 04:21 PM
KEVIN8989's Avatar
The other pic is the moog`s I have returned the one in the plastic is the new Raybestos I just received
post #54 of 70 (permalink) Old 03-21-2014, 06:50 PM
nall_one's Avatar
never did get a reply back from federal mogul on those things... guess ill have to order myself some of those raybestos as well.
the speedbump out of my work is getting sooooo irritating since my rear-end has little to no travel with those moogs in their...
nall_one is offline
post #55 of 70 (permalink) Old 03-22-2014, 11:49 PM
take them out of the plastic bags and make sure they rotate relatively easy. You should be able to hold the center section with your fingers and rotate the outer part.
post #56 of 70 (permalink) Old 03-23-2014, 02:31 AM
Y'know, if they use the right material in the new design, they'd be better - as in "teflon sleeves instead of rubber" or whatever they're using.
Or something else that would allow the two metal bushings to rotate properly.
Fuelly
RalphP is offline
post #57 of 70 (permalink) Old 07-22-2014, 02:13 PM
Just received my Raybestos bushings from Amazon and they are indeed the correct design. $41 a piece and 2-day shipping included with my Amazon Prime Membership. Better stock up on these in case every suspension/chassis engineer out there decides to have a brain-fart when trying to re-design these to make them crappier for the next 20 years lol
post #58 of 70 (permalink) Old 07-22-2014, 06:49 PM
Maic's Avatar
Originally Posted by racecougar View Post
An issue has recently come to light that I felt warranted documenting and spreading the word about. It seems that in addition to the original design of the rear upper control arm to subframe bushings there is also a flawed design that's been infiltrating the market over the past few years. Both designs have shown up in the same packaging, under the same part numbers, through multiple brands. The only way to be certain you're receiving the correct part is to open the box(es) prior to payment and verifying visually.
This is the bushing you DON'T want to install:
Those consist of a metal core with a off-center, elliptical, hole inside a metal sleeve which is rubber bonded to an outer shell. Turning the inner core via the bolt allows for camber adjustment, however with the sleeve bonded to the outer shell, the control arm can't move without winding up the bushing. Whoever designed/manufactured the bushing either didn't grasp or simply disregarded the original, correct design; something that seems to happen all to often when it comes to aftermarket parts. Installing these bushings results in a relatively harsh ride and very limited rear suspension travel.
These are the bushings you DO want to install (original design):
These allow camber adjustment and full range of motion without windup, just as they should.
Be wary of poorly designed/manufactured parts out there, folks!
Great catch RaceCat' (oops, racecougar" )
Been a while, but i remember that i have the correct ones.
Anyway' with your great Post/Info, you increased the reasons why people should pay to access certain Sub-Forums and help the site.
Keep it up and thanks for the 411.
Maic.
Maic is offline
post #59 of 70 (permalink) Old 01-08-2015, 01:25 PM
well thought i would add to this,ordered a set from rockauto moog and it was the newer design,sending them back.The last set i bought a couple of years ago were the correct ones for my 5 speed it was raybestos,but i noticed rockauto didnt list them anymore.
sleeper bird is offline
post #60 of 70 (permalink) Old 01-30-2016, 10:26 PM
Woodman's Avatar
Well, I couldn't get SuperCoupePerfomance to take paypal, so I orderded off of Rock Auto. They don't carry the Raybestos Upper arm to frame bushing anymore, so I ordered the AC Delco instead. I'll check it once it arrives and let y'all know if it is correct.
Woodman is offline
