So I wanted coil overs in the front... - Page 2 - TCCoA Forums
post #31 of 98 (permalink) Old 03-19-2014, 11:49 PM
Dumped96bird's Avatar
What diameter sleeve are you using?
07 Civic SI Sedan-Daily
96 Thunderbird-Project
65 Mustang coupe-Project/Garage Art
http://www.1320addiction.com
Dumped96bird is offline
post #32 of 98 (permalink) Old 03-23-2014, 08:31 PM Thread Starter
SATURN5's Avatar
2.5"
http://www.summitracing.com/parts/AAF-ALL64143
84 SVO Bright Amber Met, B234F 16V Volvo head conversion, RPE custom intake, header, FMIC, 38MM BOV, RPE modified diamond pistons, Crower rods, HE351 Holset, 44MM WG/dump, A1000/sumped tank, -8AN lines, 72lb injectors, 03 Cobra hydroboost, rack, brakes, IRS, Bilsteins/coil overs, MM lower control arms, RPE bumpsteer kit, T-tops
96 Mark VIII Black, black, Bullitts, Hub swapped/redrilled rear hubs, full RPE chassis brace kit, Maruader TC, Jmod
68 F100 Flareside CVIFS/M8IRS, 32V, T45, Cobra brakes, hydroboost, 3.55, 03 Cobra wheels
RAW Performance Engineering
SATURN5 is offline
post #33 of 98 (permalink) Old 04-18-2014, 10:02 PM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
Originally Posted by SATURN5 View Post
QA1 10" 650lb spring. I started here based on someone here at TCCOA who converted a Koni to coil overs and it worked out well for him.
Probably me, lol. Seriously impressed with your work, looks great man.
Originally Posted by Robe View Post
Nice fab skills. I am in the process of fabricating some brackets to use a bilstein coil-over shock on the front of my car. I was wondering if you knew how harsh of a ride the #650 springs are? I would like to go that much but am afraid to because my car is a daily driver.
For a DD, I personally wouldn't want to go more than about a 500# spring. The stiffest conventional lowering spring is something like 450# if I remember right. I kind of made an educated guess with the 650#, and it worked well, but both of my cars that my coilovers have been on have been race cars, so not much (in the case of my '97), or no (my '91) time on the street.
The beauty of this set up is that the springs are dirt cheap, so if they're too stiff or too soft for your liking, you can change it, and a 2.5" sring is available in whatever rate you want
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #34 of 98 (permalink) Old 04-19-2014, 08:30 AM
VicRattlehead's Avatar
Click buy ship install...
https://supercoupeperformance.com/pa...spx?partId=954
CMP Drag Racing
VicRattlehead is offline
post #35 of 98 (permalink) Old 04-19-2014, 01:01 PM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #36 of 98 (permalink) Old 04-19-2014, 09:39 PM
Originally Posted by VicRattlehead View Post
I hate the upper mounts on those.
post #37 of 98 (permalink) Old 04-19-2014, 11:06 PM
fast Ed's Avatar
I ran a the numbers using this: http://www.ridetech.com/info/spring-rate-calculator/
http://www.markviii.org/info/specsmain.html
Curb weight: 3761lbs
Weight Dist: 67/37 2520/1241lbs
Front corner weight: 1260lbs
That 67/33 weight distribution sounds suspect to me, more like what a bad FWD car would have. If you look at the 97-98 in that chart from the Mark VIII site, those cars magically had 53.7/44.3, which seems more plausible. There is nothing on the Gen 2 Mark VIII to change the balance that much compared to the earlier cars. I'd suggest recalculating the spring rate based on the later specs.
Nice work on what you've done so far, and great intrawebs search skills coming up with the similar dimension inserts to use.
cheers
Ed
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #38 of 98 (permalink) Old 04-20-2014, 05:25 PM Thread Starter
SATURN5's Avatar
Thanks all. I've been busy with other stuff so I've not finished the second strut. Hopefully here in a couple weeks I'll get it done, get them on and have a report.
SATURN5 is offline
post #39 of 98 (permalink) Old 05-20-2014, 02:49 AM
EvilMooseofDoom's Avatar
Not to distract, but how did that 68 Ford turn out?
So yeah, I bought two Lincolns in a week.
My LarryLand Automotive Facebook Page:
https://www.facebook.com/pages/Larry...61642343862942
My Scribd.com garbage: http://www.scribd.com/larry_vanzandt
EvilMooseofDoom is offline
post #40 of 98 (permalink) Old 05-20-2014, 08:34 AM Thread Starter
SATURN5's Avatar
In progress.... Hoping to epoxy prime the cab this weekend.
Build thread.
http://www.asphaltplayground.net/for...8-F100-project
SATURN5 is offline
post #41 of 98 (permalink) Old 05-20-2014, 02:23 PM
rbrown's Avatar
The insert is for a Mitz 3000 GT. Lots of interwebs searching came up with it. Length extended, collapsed, and vehicle weight made it the closest match. Cheapest price I found was $135 shipped.
Which year 3000?
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #42 of 98 (permalink) Old 05-20-2014, 07:13 PM Thread Starter
SATURN5's Avatar
Originally Posted by rbrown View Post
Which year 3000?
91-99.
http://www.ebay.com/itm/Bilstein-34-...item338eff4d9b
SATURN5 is offline
post #43 of 98 (permalink) Old 05-22-2014, 08:50 PM
Build thread.
Have we driven this thing yet?
To be entirely honest, I'd rather build a truck similar to this one, versus sticking with a MK8....
post #44 of 98 (permalink) Old 05-27-2014, 06:28 PM Thread Starter
SATURN5's Avatar
It's going to be the Mk8 replacement... lol
Need to update my sig tho... I put in 4.10's instead.
SATURN5 is offline
post #45 of 98 (permalink) Old 10-18-2014, 09:43 AM
Interceptor's Avatar
Send a message via Yahoo to Interceptor
Have you had a chance to finish this project? I know some others including myself were looking for alternatives. I was looking at the Koni Race inserts. Pricey and they would require a modified housing. I was mainly just interested in an insert but you've made a very cool coilover setup.
1993 Tbird LX 5.0 Midnight Opal
1996 Mark VIII Diamond Anniversary Edition
Cordovan Metallic
Interceptor is offline
post #46 of 98 (permalink) Old 10-18-2014, 07:26 PM
MaddMartigan's Avatar
It seems like that the inserts are all the M12 guys really care about here. Unless I misunderstand, the Bilstein inserts should work just like the Koni inserts and if we follow the same procedure we can put them on our cars.
Am I missing something?
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #47 of 98 (permalink) Old 10-19-2014, 01:55 AM
No. I applaud SATURN5 for finding a insert that should work for our cars. The fact that he used the same and designed a coilover setup is even better! The only difference I see between this insert and the discontinued Koni is that the Bilstein may require a spacer in the MN12 shock housing.
Cordovan Metallic
post #48 of 98 (permalink) Old 10-19-2014, 05:27 AM
OK. That may make sense. I guess we need some measurements of the Bilstein part and the same measurements from the Konis. The curb weight is almost the same between the Mitsubishi 3000GT and our cars.
We already have coilovers so I don't see a reason to get rid of what we have. That just complicates things so I wouldn't do it unless it was absolutely necessary.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #49 of 98 (permalink) Old 10-21-2014, 04:45 PM
Baby Huey
warmaster259's Avatar
I really need to at least do these inserts, my car feels like a bag of ass with the beefed up Bilstein Cobra convertible shocks out back and worn out KYB's up front. I call it a BS drag setup lol, it lets the front lift quite easily.
Jim
warmaster259 is offline
post #50 of 98 (permalink) Old 01-02-2015, 10:07 PM
Did this project ever get completed? What happened to the pictures?
FRPP 42# injectors
3.73 gears
OMGHI2U
post #51 of 98 (permalink) Old 09-30-2015, 08:24 PM
So, it looks like this thread dried up. I think I'm going to give it a try. Since I don't want to lose my stock shocks (they are sports IIRC), I bought a couple of cheap OEM replacements on Amazon to use as donors. Those cost about ~$14 a piece. $28 in pure throw away isn't all that bad. The down side is that the Bilstein part 34-050224 is about $160 a piece but I guess that's not too bad for a solid performance part.
I plan to use my OEM style springs. They are Sprint springs IIRC but either way they are not what this thread originally started using.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #52 of 98 (permalink) Old 10-01-2015, 01:27 AM
Hooray!
(Virtual Hug)
I think he's working on replacing the MK8 rear suspension in that truck project with a Cobra IRS. I'm not sure why, but I'm curious.
post #53 of 98 (permalink) Old 10-03-2015, 05:58 AM
Well, I went ahead and ordered the Bilsteins. I got them from Amazon via TRU for about $154 a piece. In for a penny, in for a pound I guess.
I won't have everything I need for at least a week.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #54 of 98 (permalink) Old 10-07-2015, 08:14 PM
Man, I really wish we had his pictures.
Anyway, I got he Bilsteins. The stock upper mount will have to be drilled out to accommodate the larger diameter bolt on the top of the shock.
That's my first issue to address.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #55 of 98 (permalink) Old 10-08-2015, 05:46 PM
That's the same problem that keeps us from using the Double-Adjustable Koni Race inserts.
Koni 8611 Series Double Adjustable Race Strut Inserts 8611-1259 $409.97ea @SR
Well, that and the $818, lol.
Grog6 is online now
post #56 of 98 (permalink) Old 10-08-2015, 07:59 PM
OK, I did one tonight. We'll just jump straight to the pictures.
Here is my starting point:
Here it is with the guts removed (note: too much tubing here.):
Here is the body with the insert sitting beside it:
It will fit in the tube but requires a press (luckily I have a 20 ton):
Here is the finished product beside the original product:
Several thoughts:
You need a press.
You have to cut off more material than you think.
Try and remember to drill out the bottom of the shock body BEFORE you press the shock in and also remember to remove the nut from the bottom.
Honestly I hope this works. I'm out about $350 if not because of what you have to do to make this work.
I still have to drill out the top mount and then I can swap all of this into the car.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #57 of 98 (permalink) Old 10-09-2015, 08:11 PM
No one cares about this?
FRPP 42# injectors
3.73 gears
OMGHI2U
post #58 of 98 (permalink) Old 10-09-2015, 10:14 PM
Slightly Disjointed
I do! I'm most curious to hear the results
post #59 of 98 (permalink) Old 10-10-2015, 05:21 AM
Same here, I'm quietly lurking in the shadows!
post #60 of 98 (permalink) Old 10-10-2015, 05:55 AM
OK. Today is the day I plan to finish up and install them. Wish me luck.
FRPP 42# injectors
3.73 gears
OMGHI2U
