coil over suspension idea - TCCoA Forums
 3Likes
  • 1 Post By S4gunn
  • 1 Post By XR7-4.6
  • 1 Post By Bad-Hoschy
post #1 of 8 (permalink) Old 10-03-2016, 05:19 PM Thread Starter
hi folks
what do you guys think of a cantilever coil over setup like on the pic below ???
Bad-Hoschy is offline
post #2 of 8 (permalink) Old 10-03-2016, 06:15 PM
Woodman's Avatar
Originally Posted by Bad-Hoschy View Post
hi folks
For front or rear?
What are the advantages over a standard coil over setup? Better road manners? Better track manners?
Woodman is offline
post #3 of 8 (permalink) Old 10-03-2016, 06:32 PM
Slightly Disjointed
Pipe dream
post #4 of 8 (permalink) Old 10-03-2016, 07:20 PM
Aside from the pipe dream aspect of it, this would have to be accompanied by a 4-cylinder conversion, since there is absolutely no room above the MN12 frame rails to mount a set of coil-overs.
post #5 of 8 (permalink) Old 10-04-2016, 01:21 AM
S4gunn's Avatar
While we are all smoking the reefer, I vote Ford 300 conversion.
The bell housing is the same as the SBF so it should mate to an M5R2.
-g
KEVIN8989 likes this.
S4gunn is offline
post #6 of 8 (permalink) Old 10-04-2016, 09:19 AM
Slightly Disjointed
M5R2? I'm thinking rear mounted transaxle!
Woodman likes this.
post #7 of 8 (permalink) Old 10-04-2016, 05:09 PM Thread Starter
Originally Posted by Woodman View Post
For front or rear?
just throwing ideas around ,because the scp setup is for what i get to expensive and other than the scp setup there is no coil over for the t bird not even adjustable shocks like konis any more, i ask koni if they would make me a set ,they won*t .It would be a different story if scp would sell the brakets seperate for maybe 200 $$ i could fab the rest
there would be not really an advantage over regular coil overs but more parts to choose from.
Woodman likes this.
post #8 of 8 (permalink) Old 10-04-2016, 06:56 PM
MaddMartigan's Avatar
It seems like this has been discussed and at least one of us came up with a solution that seems to work just fine. If you want to be inventive then just come up with a better top mount for me and I'll gladly be your guinea pig.
Coil Over Thread
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
