Strut Rod Bushings Gone Again - TCCoA Forums
post #1 of 15 (permalink) Old 02-08-2017, 09:49 PM Thread Starter
392Bird's Avatar
Strut Rod Bushings are shot again (2 years). I don't remember what brand these were, but they Suck.
What are the best recommended Brand on these since Ford ones are long gone?
Bruce
-----1993 Bird 5.0------
295/45/17 MT DR on the rear
Click for Full Project
392Bird is offline
post #2 of 15 (permalink) Old 02-09-2017, 01:05 AM
Wile E. Coyote Jr.'s Avatar
I went with the Quick Steer improved design bushings. Quick steer is owned by Federal Mogul, which also owns Moog. These were cheaper than Moog but they feel just as good. I got them off of rock auto. The material used to make the bushings isn't listed but it feels like polyurethane.
Lurking
Wile E. Coyote Jr. is offline
post #3 of 15 (permalink) Old 02-09-2017, 07:46 AM
jco1385's Avatar
You can still get the Ford parts, and they are still the only recommended replacement for this location. I'd start by asking the vendors on here (Bill, Jay, Victor, etc) and looking on eBay.
Edit for eBay links:
FORD OEM Front Suspension-Bushing only F7SZ3A225AA | eBay
FORD OEM Front Suspension-Bushings E9SZ3B271A | eBay
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #4 of 15 (permalink) Old 02-09-2017, 12:26 PM
Agreed, ford parts only for this location, and the bushings are still available. The part that is no longer available is the strut rod bushing sleeve, however if yours is destroyed, there is a member on here who sells a stainless steel re-usable one, which is pricey, but you will never have issues with it again.
post #5 of 15 (permalink) Old 02-09-2017, 04:56 PM
Well now I feel like I screwed up. Has anyone tried the ones I got or is it a general consensus that you should only use ford?
Lurking
post #6 of 15 (permalink) Old 02-09-2017, 05:13 PM
Many people have tried those ones. The polyurethane is not an appropriate material there because it has to flex as the suspension moves up and down, and poly cracks instead of flexing. You need ones made out of rubber, and so far no aftermarket supplier has made rubber ones.
post #7 of 15 (permalink) Old 02-09-2017, 07:26 PM
Don't waste your time installing those.
By the way...
Recommended Suspension Bushings for MN12's and FN10's
rodsv6cougar@cs.com
post #8 of 15 (permalink) Old 02-09-2017, 07:30 PM
Slightly Disjointed
Thermoplastic. Same thing as poly basically but these seem even more notoriously failure prone.
Any of you thinking long term on this? People have managed to get first gen Mustang(65-73) Polys to work before on these, so it should be possible to use their abundantly available rubber ones..
post #9 of 15 (permalink) Old 02-09-2017, 09:13 PM
Should I return these and buy the ford ones, or use them for the time being
Lurking
post #10 of 15 (permalink) Old 02-09-2017, 09:20 PM
Slightly Disjointed
Return and buy ford, you will be eventually
post #11 of 15 (permalink) Old 02-09-2017, 09:31 PM
By the way...
Ok. Thanks man
Lurking
post #12 of 15 (permalink) Old 02-10-2017, 01:35 AM
S4gunn's Avatar
Q: Do you have a deal on alignment or will you DIY that yourself? Since changing the frame side strut rod bushings will change caster, unless you have some kind of free lifetime alignment deal, I would just buy the Ford ones.
-g
S4gunn is offline
post #13 of 15 (permalink) Old 02-10-2017, 02:50 AM
94badbird's Avatar
Is there anything to replace aftermarket wise that helps prolong the life of these bushings? I also too have to change mine and it will only be every mn12 ive owned now.
94badbird is offline
post #14 of 15 (permalink) Old 02-10-2017, 05:28 PM
I just learned yesterday from the others that aftermarket isn't good in this situation, try to get OEM rubber ones. XR7 told me 66 stang ones should work so I ordered a set of those cause they seem to be cheaper are a lot easier to find.
There is a link posted by RaceCougar if you go up with more info on this
Lurking
post #15 of 15 (permalink) Old 02-10-2017, 05:34 PM
Slightly Disjointed
I didn't say they worked, I said they might work. People have used the poly but as far as I know nobody has tried factory rubber. Good luck
