Do Addco Swaybars fit? - TCCoA Forums
 1Likes
  • 1 Post By Wile E. Coyote Jr.
post #1 of 9 (permalink) Old 02-18-2017, 11:02 AM Thread Starter
Due to using moog strut rod bushings over and over they actually damaged my subframe. I bought the kit with stainless sleeves and OE Ford Bushings this time and 2 new control arms and now Im going to be paying someone to change it for me. I figure while its out I can put a larger sway bar in there. Half the posts I read are someone complaining the larger sway bars are hitting something and dont fit. My car is bone stock, will I have any trouble installing the Adco 1 1/4 front sway bar?
93mark8rules is offline
post #2 of 9 (permalink) Old 02-18-2017, 01:10 PM
The 1-1/4" bar fits fine. It is the 1-3/8" bar that hits. Also, just so you know, the whole front subframe has to be lowered to replace the front sway bar, definitely not a "while you are in there" kind of thing.
post #3 of 9 (permalink) Old 02-18-2017, 01:17 PM
Slightly Disjointed
Only thing you'll find with either size is the oil filter becomes a bigger pain to remove. The Addcos are shaped like the 3.8/5.0 bars.
post #4 of 9 (permalink) Old 02-18-2017, 05:15 PM
CDsDontBurn's Avatar
Getting a oil filter relocation kit is recommended when getting the 1-1/4 (and especially for the 1-3/8) bars because of that.
CDsDontBurn is offline
post #5 of 9 (permalink) Old 02-19-2017, 07:53 AM Thread Starter
What oil filter relocation kit do you recommend? I want to put the kit in before I give him the car to put the new sub frame in.
post #6 of 9 (permalink) Old 02-19-2017, 02:09 PM
There's a few out there. I got one from a member here a while ago, but I forget what brand / model it was. All I know is that the filter adapter takes the FL1A oil filter instead of the FL500S filter.
post #7 of 9 (permalink) Old 02-19-2017, 02:59 PM
Slightly Disjointed
Most important thing is the lines, Don't cheap out on a kit with rubber hoses
post #8 of 9 (permalink) Old 02-21-2017, 04:36 PM Thread Starter
Wait are we talking about a 90degree adapter or a complete relocation?
post #9 of 9 (permalink) Old 02-21-2017, 05:47 PM
Wile E. Coyote Jr.'s Avatar
complete relocation
CDsDontBurn likes this.
Lurking
Wile E. Coyote Jr. is offline
