Strut Rod Bushings - More Evidence Against Moog - Page 2 - TCCoA Forums
 3Likes
post #31 of 38 (permalink) Old 05-05-2017, 10:38 AM
Slightly Disjointed
Originally Posted by MaddMartigan View Post
I think that we're haggling over pennies in the end. If you've had these fail on you at the wrong time then you're going to be in deep shit (see my evidence). The stainless steel sleeves are intended to keep you from having to ever replace them again. If you want to experiment with all of the variations then you have the tools and opportunity to do it. The two alignments that had to be done for the car already cost more than these parts. I'm tired of paying for services that I don't need to cover because of replacing parts so frequently.
My gripe is that the rubber bushings will have to be replaced some day, maybe a long time from now, and by that point the OEM rubber will probably be unavailable, negating the advantage of the reusable sleeves which probably won't work with any other bushing. I'd rather find an alternative, rather than cement the well known problem.
Thunderstruck95 likes this.
post #32 of 38 (permalink) Old 05-05-2017, 11:52 AM Thread Starter
MaddMartigan's Avatar
I'm not worried about it. The rubber bushings I had lasted 20+ years. In 20+ years my car will either be in the salvage yard or turned to it's base elements.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #33 of 38 (permalink) Old 05-05-2017, 01:53 PM
Stockpile!
post #34 of 38 (permalink) Old 05-05-2017, 02:15 PM
Thunderstruck95's Avatar
Or go this route-
This also lets you go with a Coyote when you are tired of playing with engines designed in 1992.
1995 T-Bird. PI 4.6. Bullitt intake. Big MHS cams. 4,200 Dirty Dogg converter. Kooks headers. Full exhaust. 4" Drive Shaft. 4:10s.
Waiting on a tune.
1997 Lincoln Mark VIII FX2 Sand Dune Machine.
Thunderstruck95 is offline
post #35 of 38 (permalink) Old 05-05-2017, 02:23 PM Thread Starter
Originally Posted by Thunderstruck95 View Post
Or go this route-
I'll stick with my engine designed in 1961. However, if my car lives long enough to worry about it, the AJE K member is the next logical play. I doubt that it's going to matter however.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #36 of 38 (permalink) Old 05-05-2017, 03:12 PM
Slightly Disjointed
I'd rather have crappy thermoplastic than spherical rod ends for pivots personally
And the modular debuted in 1991, get your facts straight lol
post #37 of 38 (permalink) Old 05-05-2017, 03:41 PM
S4gunn's Avatar
Hrm - it's interesting that you'd consider going that route as the next logical step in your vehicle's progression. Do you already have a hub swap? For me, it will likely be a mustang swap, a fuel cell, or both.
-g
S4gunn is online now
post #38 of 38 (permalink) Old 05-05-2017, 03:53 PM Thread Starter
-g
Hub swap - Check
Mustang swap - Don't know what that means
Fuel Cell - Probably if/when my gas tank develops a problem
FRPP 42# injectors
3.73 gears
OMGHI2U
