Rear Disk Brake Interchangeability/Differences - Page 2 - TCCoA Forums
post #31 of 38 (permalink) Old 12-04-2012, 09:40 AM
renello79's Avatar
I meant for the rear. I should have been more specific
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #32 of 38 (permalink) Old 12-04-2012, 06:59 PM
fast Ed's Avatar
Originally Posted by RalphP View Post
For all of them? Good to note.
I knew the GT/V6 rotors were the same, but thought the Cobras got bigger rotors (13").
Sorry, I wasn't clear. I meant that 94-04 GT & V6 were the same, but yes, Cobra, Bullitt, and Mach I got the 13" rotors.
fast Ed is offline
post #33 of 38 (permalink) Old 12-04-2012, 08:51 PM
renello79's Avatar
So there's upgrade options for the rear calipers and pads that I won't need to sell a kidney to pay for?
Phrum Steve
sold, sadly
post #34 of 38 (permalink) Old 12-05-2012, 12:17 AM
Depends on whose kidney, and how good your metalworking skills are
AFAIK, all alternatives require relocating the rear calipers. Now that I've said that, someone may pop in here with one that works.
You can swap to the 89 calipers, brackets, and rotors - they're a bit beefier.
THAT said - someone noted that Gen1 Dodge Vipers use the same shape/size brake pad, so it should be possible to upgrade the pads some.
OTGH - do you lock up your wheels now? When you hit ABS, are all four wheels thrumming, or just the front? If the back is already locking/ABS'ing on you, more brake won't do any good until you fix the tires. And since the front brakes do most of the braking ANYWAY ...
RalphP is offline
post #35 of 38 (permalink) Old 02-06-2013, 09:03 PM
EvilMooseofDoom's Avatar
Wasn't there someone selling the MN-12 rear rotors with the Mustang bolt pattern, or was it that I was smoking something again?
EvilMooseofDoom is offline
post #36 of 38 (permalink) Old 05-30-2013, 10:05 PM
17Mark71's Avatar
Can the 97 Sport front rotors be used on the rear with XR7Dave's (from SCCoA) rear bracket mount? Isn't the front rotor from a Sport 11.65?
'97 Sport Option'd T-Bird
DSS Shortblock, PI Heads, 262AH Cams, Kooks, SVO SC with stock pulley,
42 lb injectors, 70mm TB, '02 GT MAF, Vogtland Springs, Mk VIII DS,
Marauder TC, 17" SVT T-Bird Rims, Michelin PS2 235/50/17, True Duals,
4.10 gears, J-modded tranny
300RWHP 335RWTQ
Member of www.midwestthundercats.com
17Mark71 is offline
post #37 of 38 (permalink) Old 05-31-2013, 02:12 AM
Thickness is wrong, rears are much thinner.
So yeah, I bought two Lincolns in a week.
My LarryLand Automotive Facebook Page:
https://www.facebook.com/pages/Larry...61642343862942
My Scribd.com garbage: http://www.scribd.com/larry_vanzandt
post #38 of 38 (permalink) Old 06-07-2013, 05:11 PM Thread Starter
BlueEyes's Avatar
Yea don't put them on the back.
-Kelly
Fuelly
BlueEyes is offline
