Post your brake setup - TCCoA Forums
post #1 of 21 (permalink) Old 03-13-2012, 10:08 AM Thread Starter
Post your brake setup and give other members an idea for better braking power.
Post your:
  • Year, Make and Model
  • Type of Caliper
  • Brake Pads
  • Rotors
  • Brake lines
  • Brake fluid
  • Post any improvements over stock setup
  • Post pictures
post #2 of 21 (permalink) Old 03-13-2012, 01:29 PM
Slightly Disjointed
  • 1994 Cougar XR7, factory ABS and 4 wheel disc
  • Type of Caliper: Front - Cobra PBR with 40mm pistons, Rear - stock vargas
  • Pads: Front - OEM Cobra pads, Rear - Duralast Gold
  • Rotors: Front - OEM Cobra, Rear - redrilled OEM
  • Brake lines: Stock
  • Brake fluid: Valvoline Dot 3/4
  • Night and day difference over the 10" brakes. Feel could be a bit better but SS lines should solve that
post #3 of 21 (permalink) Old 03-13-2012, 02:15 PM
S4gunn's Avatar
95 Ford Thunderbird LX 3.8L Lemons Track Car
* Stock ABS system
* SS lines: Classic Tube via SpinningWheels-SC (slightly better deal)
* Fluid: ATE Super Blue DOT4
Front:
* PBR Dual Piston Mustang GT Calipers - remanufactured from A1 Cardone via Rockauto
* Rotors: Brembos OEM. stock size via Rockauto
* Pads: Porterfield R4-e carbon-kevlar endurance compound (cost as much as the entire conversion w/o the SS lines). You can get a deal from porterfield with a NASA member number.
Rear:
* Calipers: stock
* Rotors: stock. whatever came with the car
* Pads: Warner Severe Duty Fleet via rockauto
Impression:
* Selection represents the best value for this platform with the exception of the stupidly expensive pads. After 2 whole days of racing, we have 60% of our pads left on the front. I'd probably consider Carbotech RP2 endurance compound (roughly same price at ~$175-200). I've heard they last through more heat cycles than the Porterfields (we'll find out after our next race).
* Significantly better braking over stock (distances and feel).
* We could out brake the majority of the 24 Hours of Lemons field (too bad we didn't have much power to do anything about it at the end of the corner).
* We didn't experience a single instance of brake fade on our track test day (3 hours of having the car constantly on the track) or in our first race (14 hours of on track time on a twisty course -- Sears Point).
* Only cons: these pads make a crazy amount of dust and don't work so well until they get warmed up (not an issue on the track but not necessarily a good idea for a DD). I'd probably go with Warner Severe Duty Fleet pads for ~$35 for a daily driver. Other folks with heavy cars (Crown vics, etc) recommended these pads for Lemons racing. They are our backups.
S4gunn is offline
post #4 of 21 (permalink) Old 03-13-2012, 05:26 PM
1990 Mercury Cougar XR7
PBR dual-piston front; stock Mark 8 single-piston rear
Duralast Gold pads
Cross-drilled and slotted rotors (I think those came from KVR)
Classic tube SS brake hoses
Valvoline Synthetic DOT 3/4 fluid
B&M Line locks on Front Brakes
Non-ABS Master Cylinder Assembly
It stops pretty darn quick.
rodsv6cougar@cs.com
post #5 of 21 (permalink) Old 03-13-2012, 05:53 PM
1997 Thunderbird LX 4.6
99-04 Mustang GT Dual Piston PBR front calipers, stock disc rear
Raybestos "Advanced Technology" ceramic front pads, NAPA semi-metallic rear
Raybestos "Advanced Technology" 10.8" front rotors, NAPA rear
Stock brake lines
DOT-3 fluid
Improvements: More raw stopping power, firmer pedal and quicker pedal response (will be upgrading to braided lines for even better response soon)
post #6 of 21 (permalink) Old 03-13-2012, 06:22 PM
Seasoned Geek
Frt 13" Special Edition Bullitt Mustang Front Calipers / Standard rear disk
post #7 of 21 (permalink) Old 03-13-2012, 08:04 PM
CometGSR's Avatar
• 1995 Ford Thunderbird LX V8
•1999 Ford Mustang GT Dual Piston (PBR) Calipers
•Monroe Ceramic Breakes
•Car Quest Premium Rotors
•Poly Armor Lines
•DOT4
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #8 of 21 (permalink) Old 03-13-2012, 10:14 PM
DLF
DLF's Avatar
• '98 Mark VIII LSC, '95 Thunderbird SC
• F - Brembo 4-Piston; R - Stock
• F - Brembo; R - Stock
• Cross-Drilled and Slotted Cobra Rotors (F&R) using Brembo Blanks
• Custom Braided Stainless Steel (Paragon Performance)
• Valvoline Synthetic DOT 3/4
• WOW!
My Web Site
DLF is offline
post #9 of 21 (permalink) Old 03-15-2012, 10:17 AM
Resident drifter
slidebird91's Avatar
1997 Thunderbird 4.6L V8
Front:
13" one piece cross drilled rotor cadmium plated
Wilwood 4 piston calipers
Wilwood Bp-20 "smart" pads
custom caliper brackets
-3 brake lines
Super Blue racing brake fluid
Rear:
stock size rotor cross drilled cadmium plated
stock calipers
KVR "carbon fiber" semi-metallic pads
-3 brake lines
super blue racing brake fluid
E-brake:
asd 10" pull back e-brake
custom bracket
wilwood 4 piston calipers
"A" compound brake pads
-3 brake lines
wilwood racing brake fluid
slidebird91 is offline
post #10 of 21 (permalink) Old 03-15-2012, 01:10 PM
okay, picture stock looking brakes, front disk, drum in the rear.
Now, take off roughly 1200lbs from said car.
There's my better brakes.
post #11 of 21 (permalink) Old 03-28-2012, 01:12 PM
BlueEyes's Avatar
94 LX
Front: 13" rotors, PBR 2 piston aluminum calipers
Rear: 90 SC rear disk brakes, Brake Performance rotors
Classic Tube SS brake lines front and rear.
-Kelly
Fuelly
BlueEyes is offline
post #12 of 21 (permalink) Old 05-18-2012, 01:55 PM
BlueEyes's Avatar
Brake Test Results
The other day I had to have my 94 LX inspected here in Utah so I could get my plates/tags and they did this brake test I've never seen before where they pull the car up onto a machine and slam on the brakes and it analyzes data from the stop. I thought it was pretty interesting although I don't know how accurate it is.
Here is the paperwork they gave me on it, doesn't look bad considering the front rotors are at minimum thickness and need to be replaced. Looks like it was pulling to the right just a hair in the front.
-Kelly
Fuelly
BlueEyes is offline
post #13 of 21 (permalink) Old 05-18-2012, 04:54 PM
S4gunn's Avatar
Fascinating, Kelly.
I've always seen brakes rated on stopping distance from 60MPH (typically in feet).
I wonder if one could calculate that based on this data and then extrapolate for different vehicle weights.
Hrm.
-g
S4gunn is offline
post #14 of 21 (permalink) Old 05-18-2012, 06:29 PM
Superduty's Avatar
Get pics later. Forgot em the other day after the upgrade.
* 95 T-Bird (factory drum rear brakes)
* None ABS
* 01 Mustang GT PBR calipers in front and Mark8 calipers Rear
* Motorcraft pads front/rear
* Motorcraft rotors front/rear
* Wagner rubber brake lines
* Dot 3 brake fluid (completely flushed)
Hugh difference over my stock set up. Feels like I cut my stopping distance in 1/2 lol. Highly recommend this upgrade for a drum equipped car if your on a budget...
Superduty is offline
post #15 of 21 (permalink) Old 05-18-2012, 07:22 PM
Brakes
Ford Racing 10TH Anniversary Cobra Calipers
by PBR from Buy Ford Racing
with
AIMCO Drilled and Slotted 13" Rotors from db1Racing.com
DOT 4 ATE Super Blue Racing Brake Fluid
My Brakes Bleed Ford Blue!
post #16 of 21 (permalink) Old 05-18-2012, 10:00 PM
BlueEyes's Avatar
* None ABS
The difference after my brake upgrades is like night and day. Now I'm used to driving the LX with the better brakes and no ABS then I jump in the 90 SC with stock brakes and ABS and I have come close to hitting a few people. When I drive the SC I have to keep reminding myself I can't stop as fast.
-Kelly
Fuelly
BlueEyes is offline
post #17 of 21 (permalink) Old 05-18-2012, 10:05 PM
BlueEyes's Avatar
Fascinating, Kelly.
Hrm.
-g
It may be possible Gunn, I'll have to leave that to the mathematicians though. I think the problem is there is no speed or distance references in the data. Only deceleration and weight to go by from what I can see.
Just FYI: This report came from Jiffy Lube so accuracy is probably questionable. The reason why I take my cars to Jiffy Lube for state inspections is they don't do any major repairs so they don't look too closely. Example: On the LX to pass inspection they made me buy a set of wiper blades because one was ripped on the end about an inch but failed to say anything about the 2 small cracks in the windshield, one headlight wasn't working (wiring problem with the socket) and the rear window 3rd brake light wasn't working. All of those things would have made it fail inspection but were not things they could have fixed right there.
-Kelly
Fuelly
BlueEyes is offline
post #18 of 21 (permalink) Old 03-06-2014, 09:07 PM
JayBird95's Avatar
racecougar...Did you cut out the fender well, or is it just for the picture...Buy the way, I like that oil relocate.
2" drop springs, auto start, shaved exterior handles(now have poppers) and trunk lock, clear corner lights, Power Stop red powder coated brake calipers and cross-drilled and slotted rotors, not much to the motor just changed out the stock violin box with 4" tubing and K&N, L.E.D. interior and dash lights(some on the exterior to), some other odd & ends, and a banging system!
My Pictures http://s1329.photobucket.com/user/JayBird95/profile/
JayBird95 is offline
post #19 of 21 (permalink) Old 03-07-2014, 06:04 AM
Thanks. The front portion of the fender liners were trimmed equally on both sides. You can see that a section remains in place at the edge of the bumper cover in the picture above, and that the rear section also remains in this picture.
rodsv6cougar@cs.com
post #20 of 21 (permalink) Old 03-11-2014, 10:09 PM
nall_one's Avatar
95 Tbird
just your standard PBR swap with a reardrum delete
wagners up front brakebest selects in back
Bosch rotors in front and Breakbest in back
standard rubber replacements from Brakebest
Dot3
Crasy amount of difference from factory, i havent had to lock em up often but it sure dose feel like its going to rip the subframe out from under the car and let the rest keep going
95 Deep Jewel Green 40th Anniversary Bird / Stock SOHC 170k FRPP PI intake swap, filter relocated! 97 Mk8 4R70W, Jmod, 3L27 / energy susp rear spindle, and cobra arm bushings, Tru-Cool Max/radiator cooler bypassed, 93 Mk8 shaft, and LCAs, 225/60r16 Michelin Defenders on Windstar twin 5spokes, Vogtland 1.6drop springs, Tokico Blues, PBR, and rear-disk swap, 89 SC swaybars
nall_one is offline
post #21 of 21 (permalink) Old 03-23-2014, 09:03 PM
Black_Cat's Avatar
1995 Mercury Cougar XR-7
Front: Mustang Cobra Two Piston Calipers
- 13" Slotted and Cross-drilled Rotors
- Ceramic Pads
Rear Calipers: Stock Single Piston rear calipers
- 11.65" Cobra rotors
- Wearever gold pads
Brake Lines: Stainless Steel StopFlex lines all four corners.
Fluid: ATE SuperBlue DOT 4 Racing Fluid
Thoughts: This car stops so hard your eyes feel like they will pop out.
Pictures: Coming Soonish
I drive an endangered species...they are being crushed at an alarming rate. Please do your part to preserve the Cougar species, and ensure they live on into the future.
1995 Mercury Cougar XR-7 4.6L 2V 5 Speed
1998 Lincoln Mark VIII LSC Collector's Edition Car#94
2009 BMW 535i M Sport Package
Black_Cat is offline
