Rear Brakes Dragging - TCCoA Forums
 12Likes
post #1 of 33 (permalink) Old 02-13-2017, 05:39 AM Thread Starter
MaddMartigan's Avatar
I realize that this is a fairly n00b question but I know you've all been bored.
I swapped over to SN95 hubs and put the relocation brackets in place and swapped over to the bigger rotors in the rear. Now I've got a problem with the rear pads dragging (really bad). The calipers are new, the pads are new, the rotors are new. From what I've read the suggestion is that I need to lubricate the slide pins. I guess I wouldn't have thought that I needed to do that.
Any thoughts?
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #2 of 33 (permalink) Old 02-13-2017, 07:01 AM
Lubricate the slide pins; lubricate the calipers where the pads drag; and check the brake hoses.
Fuelly
RalphP is online now
post #3 of 33 (permalink) Old 02-13-2017, 07:18 AM Thread Starter
OK, lubricate the slide pins: Will do.
Lubricate the calipers where the pads drag: Say what now, what now? I'm not sure I follow this part.
Check the brake hoses: Checked. They are SS hoses.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #4 of 33 (permalink) Old 02-13-2017, 07:44 AM
Natesriv's Avatar
Is the e-brake cable pulling it slightly? I did a rear conversion on my Sonic and I had to loosen it at the e-brake a few turns.. Different setup all together, but just curious.....
Natesriv is offline
post #5 of 33 (permalink) Old 02-13-2017, 09:35 AM
Slightly Disjointed
We're the pistons fully in when you installed them, and if so we're they aligned with the pad tabs?
post #6 of 33 (permalink) Old 02-13-2017, 09:41 AM Thread Starter
I actually followed the procedure for that. I disengaged the retaining clip to release all tension on the central spring to let it unload and then pushed the clip back in place.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #7 of 33 (permalink) Old 02-13-2017, 09:42 AM Thread Starter
This may be something I didn't do. I did crank them in the best I could (my brake tool sucks) but aligning them to the tabs is likely the problem. I will disassemble and reassemble with that in mind.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #8 of 33 (permalink) Old 02-13-2017, 10:33 AM
Natesriv's Avatar
I got one of these from Advance Auto... big time saver on those rear screws..
Natesriv is offline
post #9 of 33 (permalink) Old 02-13-2017, 11:50 AM Thread Starter
I have the exact same one and it doesn't work worth a damn on our calipers. It's slightly better than a flat screwdriver.
I bought this because I'm tired of this challenge and having tools is better than not: Cartman 21 piece brake service kit
FRPP 42# injectors
3.73 gears
OMGHI2U
post #10 of 33 (permalink) Old 02-13-2017, 12:08 PM
Natesriv's Avatar
Dang! That's a good price!
Natesriv is offline
post #11 of 33 (permalink) Old 02-13-2017, 12:40 PM
Slightly Disjointed
The key with the "cube" tool is mounting the caliper on the spindle WITHOUT the rotors and pads so you can shove your full weight on the wrench as you turn. The proper tool you can just conveniently twist with the caliper in one hand and the wrench in the other.
Grog6 likes this.
post #12 of 33 (permalink) Old 02-13-2017, 12:52 PM
Here's a picture:
Mach1Motorsports likes this.
Fuelly
post #13 of 33 (permalink) Old 02-13-2017, 01:41 PM Thread Starter
Here's a picture:
I've got this kind of caliper lubricant: Permatex 24110 Ultra Disc Brake Caliper Lube, 8 oz.
I assume that this is the kind of "lube" we're talking about.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #14 of 33 (permalink) Old 02-13-2017, 01:45 PM
Natesriv's Avatar
and copper grease on the back of the pads to prevent vibration...
Natesriv is offline
post #15 of 33 (permalink) Old 02-13-2017, 04:39 PM
r429460's Avatar
Channel locks work too.
Are the calipers stock or are they mustang?
Quickest N/A Modular MN12.
11.97@ 109.35
3880 lbs. w/driver.
Bradenton Spring Brake Shootout 03/04/2017.
r429460 is offline
post #16 of 33 (permalink) Old 02-13-2017, 04:50 PM Thread Starter
They are stock. Apparently from a 94+ MN12.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #17 of 33 (permalink) Old 02-13-2017, 07:11 PM
Woodman's Avatar
Did you clearance the calipers?
Woodman is offline
post #18 of 33 (permalink) Old 02-13-2017, 08:10 PM Thread Starter
Absolutely. It won't actually fit without doing that.
Woodman likes this.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #19 of 33 (permalink) Old 02-14-2017, 01:39 PM
CDsDontBurn's Avatar
Here's a picture:
I get why the slide pins, slide pin housings, and back of the pads, but why lube up the pad mounting tabs and pad mounts??
CDsDontBurn is offline
post #20 of 33 (permalink) Old 02-14-2017, 04:06 PM
Woodman's Avatar
To prevent metal on metal binding/friction.
When I was a kid learning how to do brakes, my dad only ever showed me the pins. And they are the absolute most critical part to lube, but the other contact surfaces are also equally important for the same reason.
The brakes get VERY hot, and having the proper lubricant on the metal to metal contact points will make sure that not only the brakes slide smoothly towards the caliper to stop the car, but also release smoothly and quickly to prevent extra parasitic loss. Since the pads move along the mounting tabs and pad mounts as they compress/release, those have to have lube or they'll stick.
CDsDontBurn likes this.
Woodman is offline
post #21 of 33 (permalink) Old 02-14-2017, 04:39 PM
Slightly Disjointed
I've never lube the backs of pads, just the slide pins.
post #22 of 33 (permalink) Old 02-14-2017, 07:24 PM
Mach1Motorsports's Avatar
One more note On Floating Calipers
While proper lubrication is important to the proper operation of the brakes, i would lean towards the e-brake being possibly too tight. If you were able to slide the calipers with the new pads over the rotors, you pushed the piston back enough for the brakes to function without drag. The llack of lubrication is more likely to lead to uneven pad wear than cause dragging also.
Ido recommend however rechecking everything before driving. Some additional notes are below.
No one mentioned it, but any area that requires grease also requires at least a quick attempt at cleaning. A wire brush is best for this and gets of the dust, rust, old grease etc.
After spending a few years running a 7 bay repair shop, i can tell you that poorly prepped brakes are more of a reason for uneven pad wear than bad calipers, though most mechanics will blame the caliper to make more money. At least many calipers come wih brackets and pins and that does solve the issue, and hydraulic parts should be replaced or rebuilt every 2nd or 3rd brake job.
Floating calipers (any caliper with pistons ONLYon one side of the caliper/rotor) are all junk, created and used to save money and ease assembly. All early disc brakes were fixed calipers like the Kelsey Hayes 4 piston type found on 65-67 Mustangs and other Fords. By 1968 the lousy single piston floating caliper was introduced and it is largely unnchanged today.
I also never use brake grease on the back of the pad. Ionly use disc brake quiet. As far as applying grease to the lubrication points, i think its better to grease the inside surface of the caliper where the brake pad mounting tabs ride, rather than directly on the pad tabs. Just brush some into the channel before instanng the pads.
Woodman likes this.
96 Saleen Cobra 55k
98 Mark VIII 91K
97 Mark VIII LSC 175k
94 Mark VIII 122k
84 Bronco 351 HO 115K
66 Mercury Monterey 390
49 Lincoln 2 dr
70 Mustang Mach 1 351C 4V Restored
Mach1Motorsports is offline
post #23 of 33 (permalink) Old 02-14-2017, 10:32 PM
The lube on the back isn't to lubricate, but to help dampen sound caused by the pads vibrating while braking.
Some speed / rotor / pad / road / etc. combinations can cause some really weird moans ... with nothing wrong.
Some folks also use a silicon pad; there's a harder elastomer that's available; but the main thing is to do something to dampen the sound a bit.
Oh, and also to let the pads slide a small bit on the pistons in case there's any play at all there *grins*
Woodman likes this.
Fuelly
post #24 of 33 (permalink) Old 02-15-2017, 04:17 PM
Something to remember with our emergency brakes:
The cable moving around in the breeze can tighten up the calipers, that's what there's a Big-Ass Wire Tie around it and the Cable mount on the Caliper from the factory, holding it together so it won't move sideways.
You have to put that back, or you can easily get dragging calipers.
Our cars have been thru several owners in some cases, and these might be gone; it's worth checking to see if they're there.
If you're not pulling the clip on the Ebrake Adjustment (in the rear middle of the cable), and removing the cables from the caliper, BEFORE you start fucking with the caliper removal, you are really fucking up; and making this a miserable job.
Every time you wiggle the caliper with respect to the cable, the piston will tighten back up; and that's the hardest part or doing these brakes, making the Freaking piston go in.
Woodman likes this.
post #25 of 33 (permalink) Old 02-15-2017, 07:00 PM
Woodman's Avatar
Pictures of the setup?
Woodman is offline
post #26 of 33 (permalink) Old 02-15-2017, 07:47 PM
Wile E. Coyote Jr.'s Avatar
When I replaced my rear calipers only one side had a black zip tie, and it was broke. Should I wire others back up? Were should I mount it too? (I forgot where exactly I pulled it from)
Lurking
Wile E. Coyote Jr. is offline
post #27 of 33 (permalink) Old 02-16-2017, 07:21 PM Thread Starter
Problem solved. Matt made the call. The driver's side piston wasn't aligned with the nubs on the back of the pad. The driver's side showed obvious dragging and was the one that was heating up really bad. I fixed that problem.
I also lubed the slide pins. They weren't dry but they weren't very lubricated.
The brake caliper tool set worked like a champ. The piece they list for Ford didn't fit but there was one that worked perfectly (K2 IIRC) and it's hard to imagine ever doing the rear brakes without the kit to screw down the caliper piston.
This was a pretty lively thread for such a dumbass mistake on my part.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #28 of 33 (permalink) Old 02-16-2017, 07:45 PM
Black_Cat's Avatar
I've always done brake jobs like the above illustration, it has worked flawlessly every time. Quiet, normal operation with no problems. If there is a contact point (other than pad to rotor) I'm lubricating it.
Woodman likes this.
I drive an endangered species...they are being crushed at an alarming rate. Please do your part to preserve the Cougar species, and ensure they live on into the future.
1995 Mercury Cougar XR-7 4.6L 2V 5 Speed
1998 Lincoln Mark VIII LSC Collector's Edition Car#94
2009 BMW 535i M Sport Package
Black_Cat is offline
post #29 of 33 (permalink) Old 02-16-2017, 07:49 PM Thread Starter
I generally lube all the contact points too. It seems like a good idea on brakes as well.
Woodman likes this.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #30 of 33 (permalink) Old 02-16-2017, 09:07 PM
Reading this gave me a little motivation to get my butt into gear and fix the [front] brakes on my two rides...
Woodman likes this.
