Rotors - TCCoA Forums
 4Likes
  • 1 Post By RalphP
  • 1 Post By XR7-4.6
  • 1 Post By theterminator93
  • 1 Post By XR7-4.6
post #1 of 15 (permalink) Old 04-09-2017, 04:23 PM Thread Starter
Resident Gun Guru
SHADOW's Avatar
Question Rotors
Ive already read most of the posts concerning brake upgrades.......
I already have a full front and rear Disc Brakes R Us conversion. 13" fronts and 11.65" rears. I need to replace my rotors, primarily fronts, but rears arent far behind. I cannot afford replacement rotors from DBRU.
Anyone know where I can get these large rotors with the 4.25 bolt pattern at a reasonable price ?
Need ASAP........
13.66 @ 100.4 mph
1.94 60' time
"If you stick with the basics, you never have to go back to them"
SHADOW is offline
post #2 of 15 (permalink) Old 04-09-2017, 05:19 PM
Pick up the Mustang rotors and have the local machine shop redrill them?
That's all I've got.
CDsDontBurn likes this.
Fuelly
RalphP is offline
post #3 of 15 (permalink) Old 04-09-2017, 05:39 PM
Slightly Disjointed
Get a set for a Mustang and file the holes oblong to fit the bolt pattern, on the front the hub center is the same between them so they'll be centered no matter how imprecise you are with the file. The rears you can do the same but you'll need a hubcentric ring for the rotor since the rear hubs aren't stepped
Woodman likes this.
post #4 of 15 (permalink) Old 04-09-2017, 06:56 PM Thread Starter
Resident Gun Guru
SHADOW's Avatar
Ok Matt, you lost me with the hubcentric ring......lol
Lets see if I got this right....... I could take these 13" mustang rotors from rock auto, that I accidentally ordered and file the holes out slightly oblong and they will work on the front ?
And the 11.65" rears for a mustang, that I got from rock auto......need to be sold, because my 30 day return policy expired ? Or I need better instructions.......lol
13.66 @ 100.4 mph
1.94 60' time
SHADOW is offline
post #5 of 15 (permalink) Old 04-09-2017, 07:42 PM
On the rears, you'll either need to get a shop to drill them, or you'll have to find rings to fit between the hubs and the center of the rotors, since the rears aren't hub-centric, but are stud-centric.
That is, the HUB doesn't center the rotor, but the STUDS do; so it's a bit more twitchy.
On the FRONT, the HUB centers, so you can obround the front holes out to the inside and they'll work just fine for brakes.
Fuelly
RalphP is offline
post #6 of 15 (permalink) Old 04-09-2017, 08:51 PM
Woodman's Avatar
Since he's already been running the 11.65 rear rotors, shouldn't he already have the hubcentric rings for them? Or are the ones he has old enough to be Thunderbird specific that are no longer made?
Long story short OP, the rear rotors can have the lug holes made oblong, so long as you have a ring to put between the hub of your car and the inner race of the rotor to fill the space. Same as if you bought aftermarket wheels, you should get hubcentric rings to fill the space so that the wheel is centered on the hub, instead of by the bolts. Otherwise, if you don't have those you can end up with issues that mimic wheel imbalance.
Woodman is online now
post #7 of 15 (permalink) Old 04-10-2017, 06:58 PM Thread Starter
Resident Gun Guru
SHADOW's Avatar
Thanks Ralph and all that responded. Sounds like the front will be an easy fix......
Where would i find the ring for the rears ?
Woodman.....these rotors are still made as a direct fit for the tbirds by discbrakesrus.com but they are rather expensive..... I bought fronts and rears, rotors and calipers when tccoa did a group purchase years back. I actually have the first prototype braided stainless lines the company ever made for the tbirds......
13.66 @ 100.4 mph
1.94 60' time
SHADOW is offline
post #8 of 15 (permalink) Old 04-10-2017, 07:54 PM
Wow... been a while since I've seen your name in the recent posts list!
I picked up plain-Jane Raybestos 13" rotors off RockAuto and used a Dremel to enlarge the holes by about 1/8-3/16" towards the center. Worked like a charm. Using a file to do this I think might make one go insane.
Woodman likes this.
post #9 of 15 (permalink) Old 04-12-2017, 07:41 AM
Rayo's Avatar
I'm always hearing Woodman and Matt suggest this..
I'm just imagining one of the members here actually using a file, and driving themselves into a spastic seizure accompanied by insanity..lol
1991 Ford Thunderbird Sport
Rayo is offline
post #10 of 15 (permalink) Old 04-12-2017, 07:16 PM Thread Starter
Resident Gun Guru
SHADOW's Avatar
Hey Terminator......yes, been a long time. Went through a lot of challenges the last few years.......change in career and finances for a while. The trans had some problems and the car got parked for a while. My best friend, tbirdbrain, passed away unexpectedly. He was building my new drive train. His wife brought my trans and rear end to me, but I havent had a way to bring my motor back to south carolina yet.
Ive finally been able to get back to rebuilding. The rear got new shocks and will have new rotors as soon as i get this problem ironed out. I bought rockauto 11.65 mustang rotors by accident.
The front gets new struts, upper and lower control arms with ball joints, inner and outer tie rods and rotors too. Again i bought rockauto 13" mustang rotors. As soon as I complete this project I hope to be taking the car to Robert to have him install my trans............are the raypestos 13" you got for a mustang ? i could find any that size for the tbird ?
Did some searching about hubcentric rings to correct my rear rotors but dont know what size i need ?
13.66 @ 100.4 mph
1.94 60' time
SHADOW is offline
post #11 of 15 (permalink) Old 04-12-2017, 07:45 PM
Yeah, we've had lots of good folks move on in the last few years. JL, Preston, Doug, Mike V... just to name a few.
Yeah, the Raybestos rotors I bought were for a 'Stang. Their part number was 66844.
post #12 of 15 (permalink) Old 04-12-2017, 09:32 PM
Woodman's Avatar
I'll let you know how it goes when I try it.
post #13 of 15 (permalink) Old 04-12-2017, 09:40 PM
Slightly Disjointed
You know files are made in grits and sizes beyond the ones used for fingernails right?
Woodman likes this.
post #14 of 15 (permalink) Old 04-16-2017, 05:17 PM Thread Starter
Resident Gun Guru
SHADOW's Avatar
I get how to grind them out xr7.....lol........but still need the hub centric rings on the rear ? Im ignorant....anyone know the size ? Educate me ?
13.66 @ 100.4 mph
1.94 60' time
SHADOW is offline
post #15 of 15 (permalink) Old 04-19-2017, 06:01 PM
The holes in the rotors have a bit of play by design; and the hole in the middle is a different size, so you need some metal rings in the gap, or you will never have an even balance on the wheels, because the rotor is 0.0xx off center, so you go down the road going whoomp-whoomp-whoomp each time the light spot comes up.
With more tires, it's more fun.
The hub centric rings are just gap-fillers.
That's why our rotors and wheels fit tightly in the middle.
Good to see you back!
I just want to know what to do about the yellow painted front stud, if you replace the front bearings...
