Mustang PBR Calipers to Thunderbird Conversion and problems - Page 4 - TCCoA Forums
post #91 of 130 (permalink) Old 05-28-2013, 06:41 PM
Originally Posted by jco1385 View Post
Sorry for the trouble you're having. The banjos that were included were the ones OEM for those calipers. I can't say they were the same year as I went through and got a bunch of brakes at once, but I pulled each and put it's banjo back so they wouldn't get confused. I hope you get it worked out.
Well bangster just mentioned that the threads are different so if you cant thread it in easy then its a no go but yeah the calipers likely came from 2 different cars as the rust and dirt build up up seemed to be different from each other. So different years isnt a problem if they both take the same banjo. In this case they both work with either banjo. This is my daily so better to be thorough before just slapping them on and finding trouble later. After I get the piston boots all sorted out Im heading to this shop to see why its taking 2 months for a custom set of SS lines that fit like OEM.
Anyone actually know how you can tell if you have the wrong banjo?
post #92 of 130 (permalink) Old 07-19-2013, 07:39 PM
germz1986's Avatar
got all my parts needed to do this tonight after work
Will be installing tomorrow after i take son to go see Turbo
will report how it all went, seems to be very straight forward, and excellent write up to follow.
1997 Royal Blue Metallic 4.6l
Pioneer P8400H
Diamond Audio D6 5x7's Driven by Hiffonics 4ch
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
germz1986 is offline
post #93 of 130 (permalink) Old 07-21-2013, 01:01 PM
Just the one note - you'll need to trim either the spindle, or the mounting ear, to avoid interference after the brakes wear down a bit. Not by much, but some.
RalphP is offline
post #94 of 130 (permalink) Old 07-21-2013, 07:28 PM
germz1986's Avatar
Hiya, ya i trimmed the mounting ear, also had to trim the brake line block where the banjo bolt goes through. Everything mounted and ready to roll, except i messed up the line block on the driver side, had to order a new one, will be here tomorrow.
But other than that, everything went really smooth and easy.
Pioneer P8400H
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
post #95 of 130 (permalink) Old 07-25-2013, 02:42 PM
germz1986's Avatar
So, got a bad caliper driver side, got it replaced last night. All installed and bled, FRAKING awesome brakes.
Stops so smooth and without effort.
Very happy with the results, and TY to the op on the awesome write up.
If anyone who hasn't done this yet and you need brakes, do your self a favor and get to it :P
Pioneer P8400H
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
post #96 of 130 (permalink) Old 07-25-2013, 09:43 PM
*ahem*
I wholeheartedly concur with this assessment
RalphP is offline
post #97 of 130 (permalink) Old 07-27-2013, 02:48 PM
nall_one's Avatar
yep, love mine to death! best thing i ever did, and i would recommend anyone who has plans for more power start here first! i even went all disk and replaced my drums out back, so the difference was probably a bit more dramatic on my side of things.
super easy swap, just hack off a bit of the brakeline block on the one side and grind down the upper ear of the calipers a bit on each side.
95 Deep Jewel Green 40th Anniversary Bird / Stock SOHC 170k FRPP PI intake swap, filter relocated! 97 Mk8 4R70W, Jmod, 3L27 / energy susp rear spindle, and cobra arm bushings, Tru-Cool Max/radiator cooler bypassed, 93 Mk8 shaft, and LCAs, 225/60r16 Michelin Defenders on Windstar twin 5spokes, Vogtland 1.6drop springs, Tokico Blues, PBR, and rear-disk swap, 89 SC swaybars
nall_one is offline
post #98 of 130 (permalink) Old 07-31-2013, 11:00 PM
Send a message via AIM to fkostyun
Did the swap a few weeks ago on mine! What a difference! I found a nice 2000 and fresh 1999 Mustang at the boneyard - $29.99 later I had the full set of brakes! I'd already had a set of brand new hoses that I'd bought from Rockauto years ago that I put on.
This was defiantly one of the best upgrades I've done to the car - had to do a quick stop the other day, and the brakes now want to put me through the windshield it stops so well!
fkostyun is offline
post #99 of 130 (permalink) Old 08-07-2013, 06:19 PM
Is the phenolic piston a dealbreaker? Advance has them for about $50 each with coupons - but they don't have steel pistons.
Also, the 2004 uses the same banjo as the bird, correct..?
tbirdguy is offline
post #100 of 130 (permalink) Old 08-07-2013, 07:10 PM Thread Starter
Phenolic piston advantages are: lighter, insulate heat, won't rust, not affected by heat or moisture and run tighter clearances.
Steel piston advantages are: stronger, wear slower, rebuildable, and won't crack like phenoic.
TBird banjo bolts WILL NOT fit Mustang PBRs.
~Rick
TCCoA Sig
post #101 of 130 (permalink) Old 08-07-2013, 10:11 PM
Seems all the vendors are selling phenolic...
According to NAPA:
Mustang:
1999-2002 - Inlet Size : M10 X 1
2003-2004 = Inlet Size : M10 X 1.5
Bird(93-97):
I've read others used Tbird banjo bolts on their 03-04 calipers...
Are the PBR bolts longer?
tbirdguy is offline
post #102 of 130 (permalink) Old 08-07-2013, 11:47 PM
Correction - the earlier PBRs use a different banjo bolt.
The 2003/2004 use the same bolt as the TBirds.
FordParts.COM shows the 2003/2004 as being a coarse M10. So is the TBird one.
The 1999-2002 is a fine M10.
Corollary: If possible, use a 2003/2004 caliper set. In any case, always get matching banjo bolts.
RalphP is offline
post #103 of 130 (permalink) Old 08-08-2013, 01:23 AM
I find if you order calipers for a 04 you get them with a 10mx1.5 thread banjo bolt the same as our cars, 99 were 10mx1.0 and the banjo bolts cost a fortune. For anyone worried about grinding the spindle don't I take just a little off the caliper and a little off the spindle and have plenty of clearance. Forget chasing the parts at junkyards just order reman calipers and dump the stock calipers as cores they value the same and nobody ever complains. You also get calipers you don't have to worry about being bad.
post #104 of 130 (permalink) Old 08-08-2013, 07:49 AM
Getting reman 04s is a no brainier for $47each. Salvage ones will likey cost more (for me anyway because there are no good yards here and everything is overpriced or I have to ship), and there are new crush washers, pins, sliders, etc. You can also use your banjo bolts. There is also a lifetime warranty.
I've replaced countless calipers and no one as much opened a box. The other caliper sells for about the same, it is not like returning a box of rocks.
You can also do a test fit without the pads to confirm any clearance issues and minimize grinding.
One last thing, I read some people use two left hand hoses to eliminate some grinding? How does that work with the mounting? I guess you have to drill a slot in the frame?
tbirdguy is offline
post #105 of 130 (permalink) Old 08-08-2013, 08:08 AM
I found some low cost braided an hoses that simplify the front, I literally bought a case of the kits.The problem is they have standard sae threads on the adapter meaning you either have to reflare the line if you are cheap like me or buy the $8 metric adapter. It's not a huge deal but that $8 drives the cost up quickly. I haven't had so much luck on the rear the lines are a bit short I put them on my car but I was redoing the steel at the time and changed the mounting location to get a proper fit. I have made a short piece of line with the correct fittings on both ends to make the lines work on the rear but again it becomes time or money.
post #106 of 130 (permalink) Old 11-22-2013, 06:01 PM
germz1986's Avatar
WELL, since the Bird is gone "RIP"
I get to do this all over again on the New Cougar.
got some nice cross drilled R1Concepts rotors on order, picking up the mustang calipers/pads tomorrow
soon as the rotors get here i'll have real brakes again
Pioneer P8400H
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
post #107 of 130 (permalink) Old 12-22-2013, 05:04 PM
germz1986's Avatar
Finally found time to install all this stuff in boxes
Considering it was my 2nd prb conversion (did my red bird), went very smooth and quick, also replaced rotors and pads out back.
I have Real Brakes again
Pioneer P8400H
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
post #108 of 130 (permalink) Old 12-22-2013, 07:58 PM
i just got a set of dual piston calipers off a late model grand marquis will they work?
chestnut101 is offline
post #109 of 130 (permalink) Old 12-22-2013, 08:09 PM
did this conversion a few months ago and what a huge difference the only problem is I am getting a lot more brake dust on my rims ....I know the pads are bigger which means more brake dust but I think its a little to much anybody else have this problem?.....and yes I got the pads on right I did read almost every article before I did the conversion like I always do
transtech520 is offline
post #110 of 130 (permalink) Old 12-22-2013, 09:52 PM
No, they won't simply bolt on (with minor clearancing) like the Mustang PBRs outlined here.
Bangster is offline
post #111 of 130 (permalink) Old 12-22-2013, 09:53 PM
Other than using a different pad, I had problems first time because I thought that inner and outer pads are the same, and they are not. I got uneven wear.
Bangster is offline
post #112 of 130 (permalink) Old 12-22-2013, 10:32 PM
Ok guess I am going to double check if I have them on right but they are wearing even I look at the front brakes every time I have it up on the lift (nice thing to have access to) to make sure nothing is leaking
post #113 of 130 (permalink) Old 12-23-2013, 03:47 AM
Are they the same brand and model pad that were on the old caliper? Some pads are dustier than others.
post #114 of 130 (permalink) Old 12-23-2013, 05:52 AM
don't know what they other ones were they were on the car when I got it but these are the onesI put on that came with the brand new centric calipers..... calipers,brackets,pads,and the came with all the hardware including banjo bolts and washers are all centric and while I was there put on new hoses and rotors ...not a bad deal cost me $215.00 for everything ended up not needing the pbr brackets I got from the yard but still have them in my box at work though
post #115 of 130 (permalink) Old 12-23-2013, 12:33 PM
germz1986's Avatar
Ya dusting seems to be more related to the pad you buy,
I have had great success with the Wearever Platinum pads from advance auto. Dont seem to dust a whole lot, grab well, and are very quiet
Pioneer P8400H
Alpine Type R 12's
PRB Brakes
Tweecer Tuned by me
post #116 of 130 (permalink) Old 12-23-2013, 12:41 PM
Was going to get wagner themo quit after i go threw this set
post #117 of 130 (permalink) Old 12-24-2013, 04:03 PM
nall_one's Avatar
anything ceramic wont dust your rims.
its the semi-metallics that have a lot of dusty stuff in them that make for a messy rim in the wet weather.
just grab yourself something that says ceramic on it from the local parts store like wagners or brakebestselect ceramics, etc and you'll be fine.
ceramics also resist brake fade from heat, and they tend to squeal less.
that being said i have seen them glaze over with extreme abuse and loose nearly all brake performance, but that can happen to any pad really.
nall_one is offline
post #118 of 130 (permalink) Old 12-25-2013, 02:59 PM
Mgino96tbird46's Avatar
The one time I had really bad dusting was when I installed the pads wrong, I confused the inners with the outers. I actually put two dents in the face of the pistons because of that. Oops! Definitely make sure you use ceramic pads. Anything else is just....."meh".
1996 Thunderbird LX. Gone, but not forgotten Oct 1995-March 24 2016
1998 Mustang GT premium. Auto, stock, and slow. Daily beater.
Mgino96tbird46 is offline
post #119 of 130 (permalink) Old 01-08-2014, 10:06 AM
jco1385's Avatar
This may not be relevant to the current conversation, but I found this pic while flipping thru old pictures in photobucket. This is a comparison pic of the Sport option 16" brake caliper versus the 2000 Mustang PBR caliper.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #120 of 130 (permalink) Old 04-08-2014, 11:47 AM
I just want to clarify a few things. I just bought a slightly used pair of OEM '04 Cobra calipers (off of a Mystichrome if it matters). Based on what I've read on just this page, my stock banjo bolts will work with these calipers? If so, all I have to do is grind either the RH caliper a bit where the hose goes on or grind the hose itself? Then grind the calipers at the top edge to clear the spindle?
1995 Thunderbird LX 4.6- 20% tint, removed air silencer and not much else! (Mustang hubs, Cobra brakes, Vogtland springs, Mark VIII LCAs, Sport shocks and more waiting to be installed)
2013 DIB GT 301A 6-speed- 15% tint, Kooks 1 7/8 mid lengths, off-road x and cat back, Barton 2-post bracket, JPC clutch line, Koni Yellows, Maximum Motorsports C/C plates, BMR K-member, A-arms, UCA & Mount, LCAs and relo brackets, Steeda Ultralites and PHB, Shaftmasters DS, Brembo wheels- Tuned by AED
Dave_6 is offline
